Fix some typos in spi drivers
Signed-off-by: Pengfei Fan <fanpengfei1@eswincomputing.com>
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
The official devicetree bindings specifies spi-num-chipselects as the
name. Use it.
Signed-off-by: Michael Walle <michael@walle.cc>
Reviewed-by: Vladimir Oltean <vladimir.oltean@nxp.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
The official ls1028a binding of the driver uses the following as
compatibles:
compatible = "fsl,ls1028a-dspi", "fsl,ls1021a-v1.0-dspi";
Add the missing compatible to the driver and update the device tree.
We can use the fallback "fsl,ls1021a-v1.0-dspi", because the endianness
is determined by the little-endian property and not by the compatible
string itself. Further, we won't need and specific details on the DMA
configuration (which is different on the LS1021A). If it's ever needed,
we can later add the more specific "fsl,ls1028a-dspi" compatible to the
driver.
Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
At present ofnode is present in the device even if it is never used. With
of-platdata this field is not used, so can be removed. In preparation for
this, change the access to go through inline functions.
Most drivers use these access methods but a few do not. Update them.
In some cases the access is not permitted, so mark those with a FIXME tag
for the maintainer to check.
Acked-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Acked-by: Pratyush Yadav <p.yadav@ti.com>
Use the new sequence number in all cases. Drop the rockchip case because
the sequence number should be 0 anyway, and assigning to the sequence
number is not permitted.
At present various drivers etc. access the device's 'seq' member directly.
This makes it harder to change the meaning of that member. Change access
to go through a function instead.
The drivers/i2c/lpc32xx_i2c.c file is left unchanged for now.
Try to maintain some consistency between these variables by using _plat as
a suffix for them.
This name is far too long. Rename it to remove the 'data' bits. This makes
it consistent with the platdata->plat rename.
Rename this to be consistent with the change from 'platdata'.
We use 'priv' for private data but often use 'platdata' for platform data.
We can't really use 'pdata' since that is ambiguous (it could mean private
or platform data).
Rename some of the latter variables to end with 'plat' for consistency.
This construct is quite long-winded. In earlier days it made some sense
since auto-allocation was a strange concept. But with driver model now
used pretty universally, we can shorten this to 'auto'. This reduces
verbosity and makes it easier to read.
Coincidentally it also ensures that every declaration is on one line,
thus making dtoc's job easier.
- Bug fixes and updates on ls2088a,ls1028a, ls1046a, ls1043a, ls1012a
- lx2-watchdog support
- layerscape: pci-endpoint support, spin table relocation fixes and
cleanups
- fsl-crypto: RNG support and bug fixes
Communication with some SPI slaves just won't cut it if these delays
(before the beginning, and after the end of a transfer) are not added to
the Chip Select signal.
These are a straight copy from Linux:
Documentation/devicetree/bindings/spi/spi-fsl-dspi.txt
drivers/spi/spi-fsl-dspi.c
Signed-off-by: Vladimir Oltean <vladimir.oltean@nxp.com>
[Rebased]
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
When you enable CONFIG_OF_LIVE, you will end up with a lot of
conversions.
To generate this commit, I used coccinelle excluding drivers/core/,
include/dm/, and test/
The semantic patch that makes this change is as follows:
<smpl>
expression dev;
-devfdt_get_addr(dev)
+dev_read_addr(dev)
</smpl>
This reverts commit 5d3a21df6694ebd66d5c34c9d62a26edc7456fc7, reversing
changes made to 56d37f1c564107e27d873181d838571b7d7860e7.
Unfortunately this is causing CI failures:
https://travis-ci.org/github/trini/u-boot/jobs/711313649
conversions.
<smpl>
expression dev;
+dev_read_addr(dev)
</smpl>
Drop the nondm code from fsl_dspi.c since there
is no board or any other code using for it.
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Move this uncommon header out of the common header.
Move this header out of the common header.
Update to prevent a byte of zeros being transmitted between
each byte in the tx buffer when providing both a tx buffer
and a rx buffer.
Signed-off-by: Jared Bents <jared.bents@rockwellcollins.com>
Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
Remove spi_init definition which never used on
respective code since from many years.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
CONFIG_SPI
This partly involves updating code that assumes that CONFIG_SPI implies
things that are specific to the MPC8xx SPI driver. For now, just update
the CONFIG tests. This also involves reworking the default for
CONFIG_SYS_DEF_EEPROM_ADDR so that we don't set it when we cannot make a
reasonable default, as it does not cause any compile failures.
It is good practice to include common.h as the first header. This ensures
that required features like the DECLARE_GLOBAL_DATA_PTR macro,
configuration options and common types are available.
Fix up some files which currently don't do this. This is necessary because
driver model will soon start using global data and configuration in the
dm/read.h header file, included via dm.h. The gd->fdt_blob value will be
used to access the device tree and CONFIG options will be used to
determine whether to support inline functions in the header file.
These support the flat device tree. We want to use the dev_read_..()
prefix for functions that support both flat tree and live tree. So rename
the existing functions to avoid confusion.
In the end we will have:
1. dev_read_addr...() - works on devices, supports flat/live tree
2. devfdt_get_addr...() - current functions, flat tree only
3. of_get_address() etc. - new functions, live tree only
All drivers will be written to use 1. That function will in turn call
either 2 or 3 depending on whether the flat or live tree is in use.
Note this involves changing some dead code - the imx_lpi2c.c file.
At present devices use a simple integer offset to record the device tree
node associated with the device. In preparation for supporting a live
device tree, which uses a node pointer instead, refactor existing code to
access this field through an inline function.
Fix various misspellings of:
* deprecated
* partition
* preceding,preceded
* preparation
* its versus it's
* export
* existing
* scenario
* redundant
* remaining
* value
* architecture
Reviewed-by: Jagan Teki <jteki@openedev.com>
Replace numerical bit shift with BIT macro
in fsl_*spi.c
:%s/(1 << nr)/BIT(nr)/g
where nr = 0, 1, 2 .... 31
Cc: York Sun <yorksun@freescale.com>
Cc: Haikun Wang <Haikun.Wang@freescale.com>
Signed-off-by: Jagan Teki <jteki@openedev.com>
This is a convenient way for a driver to get the hardware address of a
device, when regmap or syscon are not being used. Change existing callers
to use it as an example to others.
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
fdt_addr_t is changed to phys_addr_t. The format in debug should be updated
to %pa to match the type.
Signed-off-by: York Sun <yorksun@freescale.com>
CC: Simon Glass <sjg@chromium.org>
Fix below build warnings on armv8,
drivers/spi/fsl_dspi.c: In function ‘fsl_dspi_ofdata_to_platdata’:
drivers/spi/fsl_dspi.c:667:2:
warning: format ‘%x’ expects argument of type ‘unsigned int’,
but argument 2 has type ‘fdt_addr_t’ [-Wformat=]
debug("DSPI: regs=0x%x, max-frequency=%d, endianess=%s, num-cs=%d\n",
lib/fdtdec.c: In function ‘fdtdec_get_addr_size’:
lib/fdtdec.c:105:4:
warning: format ‘%lx’ expects argument of type ‘long unsigned int’,
but argument 3 has type ‘fdt_size_t’ [-Wformat=]
debug("addr=%08lx, size=%08lx\n",
Signed-off-by: Haikun Wang <haikun.wang@freescale.com>
Move the Freescale DSPI driver over to driver model.
Signed-off-by: Haikun Wang <Haikun.Wang@freescale.com>
