path: root/drivers/spi/designware_spi.c
2015-10-27spi: designware_spi: Use GENMASKJagan Teki
Replace numeric mask hexcodes with GENMASK macro in designware_spi Cc: Stefan Roese <sr@denx.de> Cc: Marek Vasut <marex@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2015-10-27spi: designware_spi: Use BIT macroJagan Teki
Replace numerical bit shift with BIT macro in designware_spi :%s/(1 << nr)/BIT(nr)/g where nr = 0, 1, 2 .... 31 Cc: Stefan Roese <sr@denx.de> Cc: Marek Vasut <marex@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2015-08-31dm: Use dev_get_addr() where possibleSimon Glass
This is a convenient way for a driver to get the hardware address of a device, when regmap or syscon are not being used. Change existing callers to use it as an example to others. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org>
2015-03-30spi: designware_spi: revisit FIFO size detection againAxel Lin
By specification the FIFO size would be in a range 2-256 bytes. From TX Level prospective it means we can set threshold in the range 0-(FIFO size - 1) bytes. Hence there are currently two issues: a) FIFO size 2 bytes is actually skipped since TX Level is 1 bit and could be either 0 or 1 byte; b) FIFO size is incorrectly decreased by 1 which already done by meaning of TX Level register. Fixes: 501943696ea4 (spi: designware_spi: Fix detecting FIFO depth) Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Pavel Machek <pavel@denx.de> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2015-01-29dm: spi: Move the per-child data size to the uclassSimon Glass
This is common to all SPI drivers and specifies a structure used by the uclass. It makes more sense to define it in the uclass. Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-06dt: socfpga: Rename snps, dw-spi-mmio to snps, dw-apb-ssiMarek Vasut
Linux now also contains SPI driver, yet the name is 'snps,dw-apb-ssi'. Fix the naming before we have to support both names. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@opensource.altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Pavel Machek <pavel@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Vince Bridgers <vbridger@opensource.altera.com> Reviewed-by: Stefan Roese <sr@denx.de> Acked-by: Pavel Machek <pavel@denx.de> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2015-01-06spi: designware_spi: Fix detecting FIFO depthAxel Lin
Current code tries to find the highest valid fifo depth by checking the value it wrote to DW_SPI_TXFLTR. There are a few problems in current code: 1) There is an off-by-one in dws->fifo_len setting because it assumes the latest register write fails so the latest valid value should be fifo - 1. 2) We know the depth could be from 2 to 256 from HW spec, so it is not necessary to test fifo == 257. In the case fifo is 257, it means the latest valid setting is fifo = 256. So after the for loop iteration, we should check fifo == 2 case instead of fifo == 257 if detecting the FIFO depth fails. This patch fixes above issues. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2014-12-06spi: designware_spi: Some fixes / changesStefan Roese
As suggested by Pavel, here some fixes to the designware SPI driver: - Spelling fixes - Comment for timeout added - Removed n_bytes completely (bits_per_word is enough for this) - Unput clock now not defined via macro. The function to get the clock value is now called directly from within the driver Signed-off-by: Stefan Roese <sr@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Vince Bridgers <vbridger@altera.com> Cc: Marek Vasut <marex@denx.de> Acked-by: Pavel Machek <pavel@denx.de> Cc: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2014-12-06spi: Add designware master SPI DM driver used on SoCFPGAStefan Roese
This patch adds the driver for the Designware master SPI controller. This IP core is integrated on the Altera SoCFPGA. This implementation is a driver model (DM) implementation. So multiple SPI drivers can be used. Thats necessary, since SoCFPGA also integrates the Cadence QSPI controller used to connect the SPI NOR flashes. Without DM, using multiple SPI drivers is not possible. This driver is very loosely based on the Linux driver. Most of the Linux driver is removed. Only the polling loop for the transfer is really used from this driver, as we don't support interrupts and DMA right now. This is tested on the SoCrates SoCFPGA board using the SPI pins on the P14 header. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Vince Bridgers <vbridger@altera.com> Cc: Marek Vasut <marex@denx.de> Cc: Pavel Machek <pavel@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Cc: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
