path: root/drivers/spi/cf_spi.c
2011-04-13add CONFIG_SPI_IDLE_VAL for cf_spi.c to allow use of spi_mmcWolfgang Wegner
This patch adds CONFIG_SPI_IDLE_VAL to cf_spi.c The default setting is 0x0 to behave same as current version, in case CONFIG_SPI_MMC is set, the value is set to 0xFFFF (all ones). In either case, the value can be overwritten by board configuration. Signed-off-by: Wolfgang Wegner <w.wegner@astro-kom.de> Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-07-14Coldfire: Consolidate DSPI driverTsiChung Liew
Unify both MCF5227x and MCF5445x DSPI driver in CPU to driver/spi folder for common use. Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
