Try to maintain some consistency between these variables by using _plat as
a suffix for them.
This name is far too long. Rename it to remove the 'data' bits. This makes
it consistent with the platdata->plat rename.
We use 'priv' for private data but often use 'platdata' for platform data.
We can't really use 'pdata' since that is ambiguous (it could mean private
or platform data).
Rename some of the latter variables to end with 'plat' for consistency.
This construct is quite long-winded. In earlier days it made some sense
since auto-allocation was a strange concept. But with driver model now
used pretty universally, we can shorten this to 'auto'. This reduces
verbosity and makes it easier to read.
Coincidentally it also ensures that every declaration is on one line,
thus making dtoc's job easier.
A few functions have changed to return pin numbers or I2C addresses. The
error checking for some of the callers is therefore wrong. Fix them.
This function currently accepts the IRQ-polarity type. Fix it to use the
GPIO type instead.
This chip is used on coral and we need to generate ACPI tables for sound
to make it work. Add a driver that does just this (i.e. at present does
not actually support playing sound).
[bmeng: Use the correct acpi_irq_polarity enum number]
Move this uncommon header out of the common header.
Move this header out of the common header.
At present dm/device.h includes the linux-compatible features. This
requires including linux/compat.h which in turn includes a lot of headers.
One of these is malloc.h which we thus end up including in every file in
U-Boot. Apart from the inefficiency of this, it is problematic for sandbox
which needs to use the system malloc() in some files.
Move the compatibility features into a separate header file.
At present an error does not stop the sound-output loop. This is incorrect
since nothing can be gained by trying to continue. Fix it.
At present there is no positive indication that U-Boot has finished
sending sound data. This means that it is not possible to power down an
audio codec, for example. Add a new method that is called once all sound
data has been sent.
Add a new method for this, called when the sound_play() call is done.
This function belongs in time.h so move it over and add a comment.
Add a sound driver for tegra devices. This connects the audio hub, I2S
controller and audio codec to allow sound output.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Add a driver which supports transmitting digital sound to an audio codec.
This uses fixed parameters as a device-tree binding is not currently
defined.
Acked-by: Jon Hunter <jonathanh@nvidia.com>
Add a driver for the audio hub. This is modelled as a misc device which
supports writing audio data from I2S.
Rockchip use 'arch-rockchip' instead of arch-$(SOC) as common
header file path, so that we can get the correct path directly.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Enable sound on samus using the broadwell I2S and an RT5677 audio codec.
Add a sound driver for samus which ties together the audio codec and
I2S controller.
For now broadwell_sound is commented out in the makefile since we cannot
compile it without sound support enabled. The next commit fixes this.
This audio codec is used on samus. Add a driver for it.
I2S is used to send digital audio data to an audio codec. Add support for
this on broadwell.
Add a sound driver which can output simple beeps using this legacy timer.
Add sound support for link, using the HDA codec implementation.
When testing the sound system we don't need the hear the beeps. The
testing works by checking the data that would be emitted. Add a
device-tree property to silence the sound, and enable it for testing.
The Intel High-definition Audio is a newer-generation audio system which
provides for transfer of a large number of audio stream, each containing
up to 16 channels.
Add support for HDA as a library which can be used by other drivers.
U-Boot currently uses only two channels (stereo).
Some audio codecs such as Intel HDA do not need to use digital data to
play sounds, but instead have a way to emit beeps. Add this interface as
an option. If the beep interface is not supported, then the sound uclass
falls back to the I2S interface.
This method in the sound API is optional since some drivers can do this
when probing or as part of SoC init. Mark it as such.
At present there is still some samsung-specific code in the audio codecs.
Remove it so that these can be used by other SoCs.
Fix a typo that appears many times in this file.
This chip is used by spring. Add a driver for it and update the
samsung_sound driver to pick it up.
Add a sound driver for rk3288 supporting chromebook_jerry. This uses the
I2S driver, and existing audio codec and the clock/pinmux support.
Add a driver for I2S which allows audio data to be sent from the SoC to
the audio codec. The sample rate and other settings are hard-coded for now
as there is no suitable device-tree binding available.
At present the 'beep' sound generates a waveform for only one channel even
if two are being used. This means that the beep is twice the frequency it
should be. Correct this by making it a parameter.
The fix in a previous commit was correct for sandbox but not for other
boards.
Fixes: 03f11e87a8 ("sound: Correct data output in sound_create_square_wave()")
At present these parameters are hard-coded in the sdl interface code.
Allow them to be specified by the driver instead.
Return a valid error code instead of -1.
Fix a few files whos license headers were not converted to SPDX.
All users of sound are converted to use driver model. Drop the old code
and the CONFIG_DM_SOUND option.
Update snow's device tree and config to use driver model for sound. Also
update the others as best we can.
Spring does not appear to have audio support in the kernel. The smdk5250
and smdk5420 boards use a wolfson codec which I cannot test with. So the
only boards that is tested and known to work are snow, pit and pi.
Add support for this new codec which is used by pit.
The register-access code is useful for any maxim codec. Move it out into
its own file.
Move the existing hardware drivers over to use driver model.
The current ID enums start from 1 but there does not seem to be any reason
that they cannot start with 0. Adjust the code to avoid the +1 in
codec_init().
The sound driver pulls together the audio codec and i2s drivers in order
to actually make sounds. It supports setup() and play() methods. The
sound_find_codec_i2s() function allows locating the linked codec and i2s
devices. They can be referred to from uclass-private data.
Add a uclass and a test for sound.
The i2s bus is commonly used with audio codecs. It provides a way to
stream digital data sychronously in both directions. U-Boot only supports
audio output, so this uclass is very simple, with a single tx_data()
method.
Add a uclass and a test for i2s.
An audio codec provides a way to convert digital data to sound and vice
versa. Add a simple uclass which just supports setting the parameters for
the codec.
This structure contains information that is likely needed by any i2s
driver so it seems useful to attach it to the (forthcoming) i2c uclass.
For now, just rename it.
The U-Boot sound system provides basic support for beeping. At present it
does not use driver model, but it needs to be converted. Add an option to
enable driver model for sound. For now it is not connected to anything.
Future work will add drivers which use this option. It will then be
removed once everything is converted.
For snow the codec is at address 0x11 on the i2c bus, in 7-bit format.
The device tree and code are in 8-bit format (i.e. shifted left one bit).
Fix both. Fix pit in a similar way.
