path: root/drivers/soc
2019-04-11soc: keystone: Merge into ti specific directoryVignesh R
Merge drivers/soc/keystone/ into drivers/soc/ti/ and convert CONFIG_TI_KEYSTONE_SERDES into Kconfig. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-04-11soc: ti: k3: add navss ringacc driverGrygorii Strashko
The Ring Accelerator (RINGACC or RA) provides hardware acceleration to enable straightforward passing of work between a producer and a consumer. There is one RINGACC module per NAVSS on TI AM65x SoCs. The RINGACC converts constant-address read and write accesses to equivalent read or write accesses to a circular data structure in memory. The RINGACC eliminates the need for each DMA controller which needs to access ring elements from having to know the current state of the ring (base address, current offset). The DMA controller performs a read or write access to a specific address range (which maps to the source interface on the RINGACC) and the RINGACC replaces the address for the transaction with a new address which corresponds to the head or tail element of the ring (head for reads, tail for writes). Since the RINGACC maintains the state, multiple DMA controllers or channels are allowed to coherently share the same rings as applicable. The RINGACC is able to place data which is destined towards software into cached memory directly. Supported ring modes: - Ring Mode - Messaging Mode - Credentials Mode - Queue Manager Mode TI-SCI integration: Texas Instrument's System Control Interface (TI-SCI) Message Protocol now has control over Ringacc module resources management (RM) and Rings configuration. The Ringacc driver manages Rings allocation by itself now and requests TI-SCI firmware to allocate and configure specific Rings only. It's done this way because, Linux driver implements two stage Rings allocation and configuration (allocate ring and configure ring) while TI-SCI Message Protocol supports only one combined operation (allocate+configure). Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Vignesh R <vigneshr@ti.com>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2015-11-10Various Makefiles: Add SPDX-License-Identifier tagsTom Rini
After consulting with some of the SPDX team, the conclusion is that Makefiles are worth adding SPDX-License-Identifier tags too, and most of ours have one. This adds tags to ones that lack them and converts a few that had full (or in one case, very partial) license blobs into the equivalent tag. Cc: Kate Stewart <kstewart@linuxfoundation.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2014-10-23soc: keystone_serdes: generalize configuration mechanismKhoronzhuk, Ivan
The cmu, comlane, lane configuration mechanism are similar for sub systems as well such as PCI or sRIO, but they have different values based on input clock and output bus rate. According to this compact driver to simplify adding different configuration settings based on clock and rate. Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-10-23soc: keystone_serdes: generalize to be used by other sub systemsHao Zhang
SerDes driver is used by other sub systems like PCI, sRIO etc. So modify it to be more general. The SerDes driver provides common API's that can also be extended for other peripherals SerDes configurations. Signed-off-by: Hao Zhang <hzhang@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-10-23soc: keystone_serdes: enhance to use cmu/comlane/lane specific configurationsHao Zhang
Enhance the driver to use cmu/comlane/lane specific configurations instead of 1 big array of configuration. Signed-off-by: Hao Zhang <hzhang@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-10-23soc: keystone_serdes: create a separate SGMII SerDes driverKhoronzhuk, Ivan
This patch split the Keystone II SGMII SerDes related code from Ethernet driver and create a separate SGMII SerDes driver. The SerDes driver can be used by others keystone subsystems like PCI, sRIO, so move it to driver/soc/keystone directory. Add soc specific drivers directory like in the Linux kernel. It is going to be used by keysotone soc specific drivers. Signed-off-by: Hao Zhang <hzhang@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
