path: root/drivers/smiLynxEM.c
2004-09-08* Patch by Detlev Zundel, 08 Sep 2004:LABEL_2004_09_09_0000wdenk
Update etags build target * Improve NetConsole support: add support for broadcast destination address and buffered input. * Cleanup compiler warnings for GCC 3.3.x and later * Fix problem in cmd_jffs2.c introduced by CFG_JFFS_SINGLE_PART patch
2004-03-25Code cleanupLABEL_2004_03_25_1630wdenk
2004-03-23* Patch by Pierre Aubert, 18 Mar 2004:wdenk
- Unify video mode handling for Chips & Technologies 69000 Video chip and Silicon Motion SMI 712/710/810 Video chip - Add selection of the video output (CRT or LCD) via 'videoout' environment variable for the Silicon Motion - README update * Patch by Pierre Aubert, 18 Mar 2004: include/common.h typo fix * Patches by Tolunay Orkun, 17 Mar 2004: - Add support for bd->bi_iic_fast[] initialization via environment variable "i2cfast" (CONFIG_I2CFAST) - Add "i2cfast" u-boot environment variable support for csb272
