path: root/drivers/smc91111.h
2004-06-09Patch by Kurt Stremerch, 28 May 2004:wdenk
Add support for Exys XSEngine board Some code cleanup.
2004-06-09Patch by Yuli Barcohen, 20 May 2004:wdenk
Add support for Interphase iSPAN boards.
2004-03-25* Patch by Pavel Bartusek, 21 Mar 2004wdenk
Add Reiserfs support * Patch by Hinko Kocevar, 20 Mar 2004 - Add auto-release for SMSC LAN91c111 driver - Add save/restore of PTR and PNR regs as suggested in datasheet
2004-03-14* Patch by Stephan Linz, 09 Mar 2004wdenk
- Add support for the SSV ADNP/ESC1 (Nios Softcore) * Patch by George G. Davis, 9 Mar 2004: fix recent build failure for SA1100 target * Patch by Travis Sawyer, 09 Mar 2004: Support native interrupt mode for the IBM440GX. Previously it was running in 440GP compatibility mode.
2004-01-03Patches by Stephan Linz, 11 Dec 2003:wdenk
- more documentation for NIOS port - new struct nios_pio_t, struct nios_spi_t - Reconfiguration for NIOS Development Kit DK1C20: o move board related code from board/dk1c20 to board/altera/dk1c20 o create a new common source path board/altera/common and move generic flash access stuff into it o change/expand configuration file DK1C20.h - Add support for NIOS Development Kit DK1S10 - Add status LED support for NIOS systems - Add dual 7-segment LED support for Altera NIOS DevKits
2003-12-06* Patches by Stephan Linz, 3 Nov 2003:wdenk
- more endianess fixes for LAN91C111 driver - CFG_HZ configuration patch for NIOS Cyclone board * Patch by Stephan Linz, 28 Oct 2003: fix PHY_INT_REG vs. PHY_MASK_REG bug in drivers/smc91111.c * Patch by Steven Scholz, 20 Oct 2003: - make "mii info <addr>" show infor for PHY at "addr" only - Endian fix for miiphy_info()
2003-10-19* Patch by Steven Scholz, 18 Oct 2003:wdenk
Fix AT91RM9200 ethernet driver * Patch by Nye Liu, 17 Oct 2003: Fix typo in include/mpc8xx.h * Patch by Richard Woodruff, 16 Oct 03: Fixes for cpu/arm925/interrupt.c - Initialize timestamp & lastdec vars. - fix timestamp overflows. - fix lastdec overflow. - smarter normalization to allow udelay() below 1ms to work. * Patch by Scott McNutt, 16 Oct add networking support for the Altera Nios Development Kit, Cyclone Edition (DK-1C20) * Patch by Jon Diekema, 14 Oct 2003: add hint about doc/README.silent to README file
2003-06-06Patch by Robert Schwebel, April 02, 2003:wdenk
fix for SMSC91111 driver
