2003-10-15 | * Patches by Xianghua Xiao, 15 Oct 2003:LABEL_2003_10_16_0200 | wdenk | |
- Added Motorola CPU 8540/8560 support (cpu/85xx) - Added Motorola MPC8540ADS board support (board/mpc8540ads) - Added Motorola MPC8560ADS board support (board/mpc8560ads) * Minor code cleanup | |||
2003-09-10 | * Add support for USB Mass Storage Devices (BBB) | wdenk | |
(tested with USB memory sticks only) * Avoid flicker on TRAB's VFD | |||
2003-09-05 | * Add support for SK98xx driverLABEL_2003_09_06_0055 | wdenk | |
* Add PCI support for SL8245 board * Support IceCube board configurations with 1 x AMD AM29LV065 (8 MB) or 1 x AM29LV652 (two LV065 in one chip = 16 MB); Run IPB at 133 Mhz; adjust the MII clock frequency accordingly * Set BRG_CLK on PM825/826 to 64MHz (VCO_OUT / 4, instead of 16 MHz) to allow for more accurate baudrate settings (error now 0.7% at 115 kbps, instead of 3.5% before) * Patch by Andreas Mohr, 4 Sep 2003: Fix a lot of spelling errors |
