2004-08-02 | * Patch by Andreas Engel, 12 Jul 2004: | wdenk | |
Replaced hardcoded PL011 clock frequency with config variable. Fixed wrong CONFIG_CMD_DFL doc. * Patch by Thomas Viehweger, 09 Jun 2004: make it possible to remove chpart when there is only one partition | |||
2004-03-14 | Code cleanup; make several boards compile & link.LABEL_2004_03_14_2340 | wdenk | |
2004-03-14 | * Patch by Philippe Robin, 09 Mar 2004: | wdenk | |
Added ARM Integrator AP, CP and Versatile PB926EJ-S Reference Platform support. * Patch by Masami Komiya, 08 Mar 2004: Don't overwrite server IP address or boot file name when the boot server does not return values * Patch by listmember@orkun.us, 5 Mar 2004: Removed compile time restriction on CFG_I2C_SPEED for DS1338 RTC |
