drivers/serial/serial.c
The conflict above was a trivial case of adding one init
function in each branch, and manually resolved in merge.
The driver makes it possible to use an application UART as
the U-Boot output console for Freescale i.MX23/i.MX28 devices.
Signed-off-by: Andreas Wass <andreas.wass@dalelven.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Use default_serial_puts() instead of its own implementation.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Acked-by: Michal Simek <monstr@monstr.eu>
Fixup an easy conflict over adding the clk_get prototype and USB_OTG
defines for am33xx having moved.
arch/arm/include/asm/arch-am33xx/hardware.h
Rename some CONFIG_TI814X to a more generic CONFIG_TI81XX
Signed-off-by: Antoine Tenart <atenart@adeneo-embedded.com>
[trini: Adapt for CONFIG_OMAP_COMMON changes, AM43XX]
Add AM43xx support in the required places
Register arm_dcc with drivers/serial/serial.c
Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
Removed stdio structure ops support on arm_dcc
driver, and need to register with serial core
so-that it can access like remianing serial drivers.
The mv_udc driver is broken for a while and doesn't even compile.
This patch fixes the issues and gets the driver into working state
again. This driver was tested on Freescale i.MX233/i.MX28 .
Cc: Lei Wen <leiwen@marvell.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
[trini: Fixup common/cmd_io.c]
Fix a trivial conflict in arch/arm/dts/exynos5250.dtsi about gpio and
serial.
This patch adds FDT support to the serial s5p driver.
At present disabling the serial console (from the device tree) crashes
U-Boot. Add checks for this case, so that execution can continue without
a serial console.
It also enables the serial_s5p driver recognize the silent_console option.
Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com>
Signed-off-by: Gabe Black <gabeblack@google.com>
Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com>
spl/Makefile
The omap2420H4 was the only mainline omap24xx board. Prior to being
fixed by Jon Hunter in time for v2013.04 it had been functionally broken
for a very long time. Remove this board as there's not been interest in
it in U-Boot for quite a long time.
drivers/serial/Makefile
This patch adds lpuart support for Vybrid VF610 platform.
Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
Signed-off-by: Alison Wang <b18965@freescale.com>
This patch enables the uart tx/rx fifo. Now that fifo is enabled,
the uart read/write functions are modfied to check the UFSTAT register
for fifo status instead of UTRSTAT (as required with fifo's enabled).
Tested by booting linux kernel. Before enabling tx/rx fifo
"Uncompressing linux" message is garbled and after enabling it is proper.
Signed-off-by: Alim Akhtar <alim.akhtar@samsung.com>
Signed-off-by: Akshay Saraswat <akshay.s@samsung.com>
The Freescale MPC8220 Power Architecture processors have long reached
EOL; Freescale does not even list these any more on their web site.
Remove the code to avoid wasting maitaining efforts on dead stuff.
Cc: Andy Fleming <afleming@gmail.com>
- Move blackfin serial driver to the generic driver folder.
- Move blackfin serial headers to blackfin arch head folder.
- Update the include path to blackfin serial header in start up code.
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
drivers/video/exynos_fb.c
Following the removal of the smdk6400 board, the s3c64xx SoC becomes unused, so
remove associated code. It will still be possible to restore it later from the
Git history if necessary.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Flush UART3 xmit on enable if TEMT is broken
On some OMAP3 devices when UART3 is configured for boot mode before SPL starts
only THRE bit is set. We have to empty the transmitter before initialization
starts. This patch avoids the use of CONFIG_SYS_NS16550_BROKEN_TEMT.
Signed-off-by: Manfred Huber <man.huber@arcor.de>
Tested-by: Javier Martinez Canillas <javier@dowhile0.org>
Tested-by: Andreas Bießmann <andreas.devel@googlemail.com>
'bool' is defined in random places. This patch consolidates them into a
single header file include/linux/types.h, using stdbool.h introduced in C99.
All other #define, typedef and enum are removed. They are all consistent with
true = 1, false = 0.
Replace FALSE, False with false. Replace TRUE, True with true.
Skip *.py, *.php, lib/* files.
Signed-off-by: York Sun <yorksun@freescale.com>
TI814X requires the same quirks as AM33XX to be enabled.
Signed-off-by: Matt Porter <mporter@ti.com>
Reviewed-by: Tom Rini <trini@ti.com>
Albert's rework of the linker scripts conflicted with Simon's making
everyone use __bss_end. We also had a minor conflict over
README.scrapyard being added to in mainline and enhanced in
u-boot-arm/master with proper formatting.
arch/arm/cpu/ixp/u-boot.lds
arch/arm/cpu/u-boot.lds
arch/arm/lib/Makefile
board/actux1/u-boot.lds
board/actux2/u-boot.lds
board/actux3/u-boot.lds
board/dvlhost/u-boot.lds
board/freescale/mx31ads/u-boot.lds
doc/README.scrapyard
include/configs/tegra-common.h
Build tested for all of ARM and run-time tested on am335x_evm.
Increase buffer sizes at driver and tty level to accommodate kermit
large packet support.
Signed-off-by: Shiraz Hashim <shiraz.hashim@st.com>
This cast does not seem correct, since we should be writing to a pointer,
not a ulong.
This fixes the following warning on nds32:
-ns16550.c:49: warning: passing argument 2 of 'writeb' makes pointer from integer without a cast
In master we had already taken a patch to fix the davinci GPIO code for
CONFIG_SOC_DM646X and in u-boot-ti we have additional patches to support
DA830 (which is CONFIG_SOC_DA8XX && !CONFIG_SOC_DA850). Resolve these
conflicts manually and comment the #else/#endif lines for clarity.
arch/arm/include/asm/arch-davinci/gpio.h
drivers/gpio/da8xx_gpio.c
Implements the tstc() interface for the serial driver. Multiplexing
the console between the serial port and a keyboard uses a polling
method of checking if characters are available; this means that the
serial console must be non-blocking when attempting to read
characters.
Signed-off-by: Taylor Hutt <thutt@chromium.org>
Commit 8b710b1 started removing code for the unmaintained "ns9750dev"
board; the board support is still broken, and not included anywhere in
the Makefile or boards.cfg. Remove the remaining dead code.
This saved 640 bytes on MPC8536DS (a board with two of the six
ports defined).
- arm_dcc_dev is already initialized.
- Remove unused rc variable
Warning log:
arm_dcc.c: In function 'drv_arm_dcc_init':
arm_dcc.c:145:6: warning: unused variable 'rc' [-Wunused-variable]
CONFIG_ARM_DCC_MULTI should be also removed in the patch
"serial: Remove CONFIG_SERIAL_MULTI from serial drivers"
(sha1: a3827250606895ec2dd4b8d867342b7cabf3692f)
Because the driver defines serial_* functions
which cause conflict with serial.c (multiple definition of serial_*)
Removing CONFIG_SERIAL_MULTI function also require to define
default_serial_console for cases where another serial driver
is not available in the system.
Some platforms (e.g. IGEPv2 board) has a broken ns16550 UART that
does not set the TEMT bit when the transmitter is empty in SPL.
This makes U-Boot to hang while waiting for TEMT to be set.
Add a new option to avoid this:
16550 UART set the Transmitter Empty (TEMT) Bit when all output
has finished and the transmitter is totally empty. U-Boot waits
for this bit to be set to initialize the serial console. On some
broken platforms this bit is not set in SPL making U-Boot to
hang while waiting for TEMT. Define this option to avoid it.
Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
README
arch/arm/cpu/armv7/exynos/clock.c
board/samsung/universal_c210/universal.c
drivers/misc/Makefile
drivers/power/power_fsl.c
include/configs/mx35pdk.h
include/configs/mx53loco.h
include/configs/seaboard.h
Remove the hard-coded baudrate handler and use a callback instead
If the pl011 is connected to another device which has hardware
flow-control on, characters are never received by the pl011.
Asserting RTS when flow-control is off will have no effect.
This is in line with how Linux behaves.
Signed-off-by: Joshua Housh <joshua.housh@calxeda.com>
Tested-by: Marek Vasut <marex@denx.de>
On kzm9g board (rmobile SoC), autoboot fails if serial console cable is not
connected. When serial cable is not connected, serial error occurs and
some garbage comes in data register.
sh_serial_tstc() in serial_sh.c does not check error status and misunderstand
there is some input data. It is the reason that autoboot fails.
This patch adds checking error status in sh_serial_tstc().
This patch is based on v2013.01-rc1 tag of u-boot master git.
Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
TEMT is set when the transmitter is totally empty and all output has
finished.
This prevents output problems (including a loss of synchronization
observed on p2020 that persisted for quite a while) if SPL has output
still on its way out.
v2: fixed typo in subject, and explained what the bit does in the changelog
CONFIG_NS16550_MIN_FUNCTIONS is used by small SPLs to gain access to basic
ns16550 output code without pulling in things not needed by the SPL.
This previously only worked with non-MULTI configs. Recently MULTI was
made mandatory, and MIN_FUNCTIONS fails like this:
drivers/serial/libserial.o: In function `calc_divisor.clone.0':
serial_ns16550.c:(.text.calc_divisor.clone.0+0x24): undefined reference to `get_bus_freq'
drivers/serial/libserial.o: In function `_serial_getc':
(.text._serial_getc+0x30): undefined reference to `NS16550_getc'
drivers/serial/libserial.o: In function `_serial_tstc':
(.text._serial_tstc+0x30): undefined reference to `NS16550_tstc'
drivers/serial/libserial.o: In function `_serial_setbrg':
(.text._serial_setbrg+0x3c): undefined reference to `NS16550_reinit'
make[1]: *** [/tmp/u-boot/spl/u-boot-spl] Error 1
make: *** [/tmp/u-boot/spl/u-boot-spl.bin] Error 2
With MIN_FUNCTIONS we don't need anything from this file, so don't build
it. The conditional needs to be in the file itself rather than the
makefile, because the config symbols are only imported to the makefiles
once, not separately for the SPL phase of the build.
This patch is fixing the following errors
s3c64xx.c:175: error: variable 's3c64xx_serial_drv' has initializer but incomplete type
s3c64xx.c:176: error: unknown field 'name' specified in initializer
s3c64xx.c:176: warning: excess elements in struct initializer
s3c64xx.c:176: warning: (near initialization for 's3c64xx_serial_drv')
s3c64xx.c:177: error: unknown field 'start' specified in initializer
s3c64xx.c:177: warning: excess elements in struct initializer
s3c64xx.c:177: warning: (near initialization for 's3c64xx_serial_drv')
s3c64xx.c:178: error: unknown field 'stop' specified in initializer
s3c64xx.c:178: warning: excess elements in struct initializer
s3c64xx.c:178: warning: (near initialization for 's3c64xx_serial_drv')
s3c64xx.c:179: error: unknown field 'setbrg' specified in initializer
s3c64xx.c:179: warning: excess elements in struct initializer
s3c64xx.c:179: warning: (near initialization for 's3c64xx_serial_drv')
s3c64xx.c:180: error: unknown field 'putc' specified in initializer
s3c64xx.c:180: warning: excess elements in struct initializer
s3c64xx.c:180: warning: (near initialization for 's3c64xx_serial_drv')
s3c64xx.c:181: error: unknown field 'puts' specified in initializer
s3c64xx.c:181: warning: excess elements in struct initializer
s3c64xx.c:181: warning: (near initialization for 's3c64xx_serial_drv')
s3c64xx.c:182: error: unknown field 'getc' specified in initializer
s3c64xx.c:182: warning: excess elements in struct initializer
s3c64xx.c:182: warning: (near initialization for 's3c64xx_serial_drv')
s3c64xx.c:183: error: unknown field 'tstc' specified in initializer
s3c64xx.c:183: warning: excess elements in struct initializer
s3c64xx.c:183: warning: (near initialization for 's3c64xx_serial_drv')
s3c64xx.c: In function 's3c64xx_serial_initialize':
s3c64xx.c:188: warning: implicit declaration of function 'serial_register'
s3c64xx.c: At top level:
s3c64xx.c:191: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'struct'
u-boot's byteorder headers did not contain endianness attributions
for use with sparse, causing a lot of false positives. Import the
kernel's latest definitions, and enable them by including compiler.h
and types.h. They come with 'const' added for some swab functions, so
fix those up, too:
include/linux/byteorder/big_endian.h:46:2: warning: passing argument 1 of '__swab64p' discards 'const' qualifier from pointer target type [enabled by default]
Also, note: u-boot's historic __BYTE_ORDER definition has been
preserved (for the time being at least).
We also remove ad-hoc barrier() definitions, since we're including
compiler.h in files that hadn't in the past:
macb.c:54:0: warning: "barrier" redefined [enabled by default]
In addition, including compiler.h in byteorder changes the 'noinline'
definition to expand to __attribute__((noinline)). This fixes
arch/powerpc/lib/bootm.c:
bootm.c:329:16: error: attribute '__attribute__': unknown attribute
bootm.c:329:16: error: expected ')' before '__attribute__'
bootm.c:329:25: error: expected identifier or '(' before ')' token
powerpc sparse builds yield:
include/common.h:356:22: error: marked inline, but without a definition
the unknown-reason inlining without a definition is considered obsolete
given it was part of the 2002 initial commit, and no arm version was
'fixed.'
also fixed:
ydirectenv.h:60:0: warning: "inline" redefined [enabled by default]
and:
Configuring for devconcenter - Board: intip, Options: DEVCONCENTER
make[1]: *** [4xx_ibm_ddr2_autocalib.o] Error 1
make: *** [arch/powerpc/cpu/ppc4xx/libppc4xx.o] Error 2
powerpc-fsl-linux-size: './u-boot': No such file
4xx_ibm_ddr2_autocalib.c: In function 'DQS_autocalibration':
include/asm/ppc4xx-sdram.h:1407:13: sorry, unimplemented: inlining failed in call to 'ppc4xx_ibm_ddr2_register_dump': function body not available
4xx_ibm_ddr2_autocalib.c:1243:32: sorry, unimplemented: called from here
and:
In file included from crc32.c:50:0:
crc32table.h:4:1: warning: implicit declaration of function '___constant_swab32' [-Wimplicit-function-declaration]
crc32table.h:4:1: error: initializer element is not constant
crc32table.h:4:1: error: (near initialization for 'crc32table_le[0]')
[trini: Remove '#endif' in include/common.h around setenv portion]
