path: root/drivers/serial
2018-12-18drivers: serial: Add SiFive UART driverAnup Patel
This patch adds SiFive UART driver. The driver is 100% DM driver and it determines input clock using clk framework. Signed-off-by: Anup Patel <anup@brainfault.org> Reviewed-by: Palmer Dabbelt <palmer@sifive.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2018-12-15serial: serial_stm32: Add reset supportPatrice Chotard
In some cases, UART is configured by early boot stage. To be sure of the initial state of UART and to avoid spurious chars on console, reset the serial block before configuring it. Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-12-12spl: fix build failure with !CONFIG_SPL_PCI_SUPPORTSekhar Nori
Building U-Boot with CONFIG_PCI and CONFIG_DM_PCI enabled, but CONFIG_SPL_PCI_SUPPORT disabled, results in following linker error: lib/built-in.o: In function `fdtdec_get_pci_bar32': lib/fdtdec.c:305: undefined reference to `dm_pci_read_bar32' fdtdec.c:305:(.text.fdtdec_get_pci_bar32+0x24): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `dm_pci_read_bar32' This is because reference to dm_pci_read_bar32() remains in lib/fdtdec.c while SPL build does not descend into drivers/pci directory in drivers/Makefile if CONFIG_SPL_PCI_SUPPORT is not enabled. Fix this by applying appropriate #define guards in lib/fdtdec.c. It looks like ns16550.c has the same problem, so fixed that too. To simplify this, CONFIG_SPL_PCI_SUPPORT is renamed to CONFIG_SPL_PCI (enables use of CONFIG_IS_ENABLED() macro). Suggested-by: Vignesh R <vigneshr@ti.com> Signed-off-by: Sekhar Nori <nsekhar@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-12-07serial: omap: Add code for early debuggingFelix Brack
This patch adds code missing when CONFIG_DEBUG_UART_OMAP is enabled as early debugging UART. The code is basically copied from the ns16550 driver. Signed-off-by: Felix Brack <fb@ltec.ch>
2018-12-07serial: bcm6858: remove driver and switch to bcm6345Álvaro Fernández Rojas
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com>
2018-12-07serial: bcm6345: switch to raw I/O functionsÁlvaro Fernández Rojas
2018-12-05serial: ns16550: Provide ->getinfo() implementationAndy Shevchenko
New callback will supply necessary information, for example, to ACPI SPCR table. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-12-05serial: ns16550: Read reg-io-width from device treeAndy Shevchenko
Cache the value of the reg-io-width property for the future use. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-12-05dm: serial: Introduce ->getinfo() callbackAndy Shevchenko
New callback will give a necessary information to fill up ACPI SPCR table, for example. Maybe used later for other purposes. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Simon Glass <sjg@chromium.org> Change ADR_SPACE_SYSTEM_IO to SERIAL_ADDRESS_SPACE_IO to fix build error: Signed-off-by: Simon Glass <sjg@chromium.org>
2018-12-05dm: serial: Add ->getconfig() callbackAndy Shevchenko
In some cases it would be good to know the settings, such as parity, of current serial console. One example might be an ACPI SPCR table to generate using these parameters. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-12-03Revert "serial: ns16550: fix debug uart putc called before init"Simon Goldschmidt
This reverts commit 6f57c34473d37b8da5e6a3764d0d377d748aeef1 since it does not seem to work at least on rk3399. The Rockchip Technical Reference Manual (TRM) for the rk3399 says the baud rate prescaler register is readable only when USR[0] is zero. Since this bit is defined as "reserved" in the socfpga cylcone5 TRM, let's rather drop this than making the ns16550 debug uart more platform specific. Reported-by: Roosen Henri <Henri.Roosen@ginzinger.com> Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com
2018-12-03drivers: serial: get rid of non DM mpc8xx driverChristophe Leroy
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2018-12-03drivers: serial: migrate mpc8xx to DMChristophe Leroy
2018-11-28serial: MediaTek: add high-speed uart driver for MediaTek SoCsRyder Lee
Many SoCs from MediaTek have a high-speed uart. This UART is compatible with the ns16550 in legacy mode. It has extra registers for high-speed mode which can reach a maximum baudrate at 921600. However this UART will no longer be compatible if it's in high-speed mode. Some BootROM of MediaTek's SoCs will change the UART into high-speed mode and the U-Boot must use this driver to initialize the UART. Signed-off-by: Weijie Gao <weijie.gao@mediatek.com> Tested-by: Ryder Lee <ryder.lee@mediatek.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-16serial: ns16550: add setconfig supportSimon Goldschmidt
Add possibility to update the serial parity used. Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2018-11-16serial: bcm6858: add serial supportPhilippe Reynes
This driver add the support of serial on bcm6858. It's based on serial for bcm6345. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
2018-11-14serial: Remove DM_FLAG_PRE_RELOC flag in various driversBin Meng
When a driver declares DM_FLAG_PRE_RELOC flag, it wishes to be bound before relocation. However due to a bug in the DM core, the flag only takes effect when devices are statically declared via U_BOOT_DEVICE(). This bug has been fixed recently by commit "dm: core: Respect drivers with the DM_FLAG_PRE_RELOC flag in lists_bind_fdt()", but with the fix, it has a side effect that all existing drivers that declared DM_FLAG_PRE_RELOC flag will be bound before relocation now. This may expose potential boot failure on some boards due to insufficient memory during the pre-relocation stage. To mitigate this potential impact, the following changes are implemented: - Remove DM_FLAG_PRE_RELOC flag in the driver, if the driver only supports configuration from device tree (OF_CONTROL) - Keep DM_FLAG_PRE_RELOC flag in the driver only if the device is statically declared via U_BOOT_DEVICE() - Surround DM_FLAG_PRE_RELOC flag with OF_CONTROL check, for drivers that support both statically declared devices and configuration from device tree Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-14serial: ns16550: fix debug uart putc called before initSimon Goldschmidt
If _debug_uart_putc() is called before _debug_uart_init(), the ns16550 debug uart driver hangs in a tight loop waiting for the tx FIFO to get empty. As this can happen via a printf sneaking in before the port calls debug_uart_init(), let's rather ignore characters before the debug uart is initialized. This is done by reading the baudrate divisor and aborting if is zero. Tested on socfpga_cyclone5_socrates. Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2018-11-14dm: core: Respect drivers with the DM_FLAG_PRE_RELOC flag in lists_bind_fdt()Bin Meng
Currently the comments of several APIs (eg: dm_init_and_scan()) say: @pre_reloc_only: If true, bind only drivers with the DM_FLAG_PRE_RELOC flag. If false bind all drivers. The 'Pre-Relocation Support' chapter in doc/driver-model/README.txt documents the same that both device tree properties and driver flag are supported. However the implementation only checks these special device tree properties without checking the driver flag at all. This updates lists_bind_fdt() to consider both scenarios. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Squashed in http://patchwork.ozlabs.org/patch/996473/ : Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-09dm: Fix typo - missed semicolonAndy Shevchenko
The commit 484fdf5ba058 ("dm: Add support for all targets which requires MANUAL_RELOC") introduces subtle typo, i.e. missed semicolon. Fixes: 484fdf5ba058 ("dm: Add support for all targets which requires MANUAL_RELOC") Cc: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2018-10-25Merge tag 'u-boot-imx-20181025' of git://git.denx.de/u-boot-imxTom Rini
Merged imx8 architecture, fix build for imx8 + warnings
2018-10-22serial: mxc: Add match string for i.mx6 quad/dual lite serialBernhard Messerklinger
Signed-off-by: Bernhard Messerklinger <bernhard.messerklinger@br-automation.com> Reviewed-by: Hannes Schmelzer <oe5hpm@oevsv.at> Tested-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2018-10-22serial: lpuart: support uclass clk apiPeng Fan
Modify most APIs to use udevice as the first parameter, then it will be easy to get the clk reference by using udevice pointer. Use uclass api to get lpuart clk when CONFIG_CLK is enabled. Signed-off-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2018-10-22serial: lpuart: Enable RX and TX FIFOYe Li
Enable the RX and TX FIFO in LPUART driver to avoid the input lost during U-Boot boot up. Signed-off-by: Ye Li <ye.li@nxp.com> Acked-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Anatolij Gustschin <agust@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2018-10-22serial_lpuart: Update lpuart driver to support i.MX8Peng Fan
Add i.MX8 compatible string and cpu type support to lpuart driver, to use little endian 32 bits configurations. Also, according to RM, the Receive FIFO Enable (RXFE) field in LPUART FIFO register is bit 3, so this definition should change to 0x08 (not 0x40) for i.MX8, otherwise the Receive FIFO is not disabled. Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Anatolij Gustschin <agust@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2018-10-09serial: Allow serial to be absent in TPLSimon Glass
At present this option applies to SPL, but it should be available in TPL also, and separately. Change to using CONFIG_IS_ENABLED(), add a new Kconfig option and fix up hang(). Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-09sandbox: Restore blocking I/O on exitSimon Glass
At present sandbox sets non-blocking I/O as soon as any input is read from the terminal. However it does not restore the previous state on exit. Fix this and drop the old os_read_no_block() function. This means that we always enable blocking I/O in sandbox (if input is a terminal) whereas previously it would only happen on the first call to tstc() or getc(). However, the difference is likely not important. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-09serial: sandbox: Allow serial output without device treeSimon Glass
At present sandbox assumes that device-tree control is active, but this may not be the case in SPL or TPL. Add some conditions to handle this. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-09sandbox: Add a debug UARTSimon Glass
Add support for the debug UART so that sandbox provides build testing for this feature. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-09-30serial: serial_stm32: Enable uart FIFO for STM32F7xx SoCsPatrice Chotard
Since commit 7b3b74d32127 ("serial: serial_stm32: Enable overrun") on STM32F7xx based boards, the first lines of serial output are missing during boot (we no more see the U-Boot release version, board model and DRAM size). By enabling the uart FIFO on STM32F7, the complete U-boot log can be sent correctly. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-09-26Merge tag 'signed-efi-next' of git://github.com/agraf/u-bootTom Rini
Patch queue for efi - 2018-09-26 A lot of goodness in this release. We're *very* close to running the UEFI Shell and SCT natively. The only missing piece are HII protocols. - FAT write support (needed for SCT) - improved FAT directory support (needed for SCT) - RTC support with QEMU -M virt - Sandbox support (run UEFI binaries in Linux - yay) - Proper UTF-16 support - EFI_UNICODE_COLLATION_PROTOCOL support (for UEFI Shell) - EFI_SIMPLE_TEXT_INPUT_EX_PROTOCOL support (for UEFI Shell) - Fix window size determination - Fix Tegra by explicitly unmapping RAM - Clean up handle entanglement - Lots of generic code cleanup [trini: Fixup merge conflict in include/configs/qemu-arm.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-09-25serial: omap: Add support for AM654 uart controllerLokesh Vutla
AM654 uses a UART controller that is compatible (partially) with existing OMAP UART, Introduce a compatible for adding support for this controller. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-09-23efi_loader: struct efi_simple_text_input_protocolHeinrich Schuchardt
%s/efi_simple_input_interface/efi_simple_text_input_protocol/ We should be consistent in the naming of the EFI protocol interface structures. The protocol is called EFI_SIMPLE_TEXT_INPUT_PROTOCOL. %s/ExtendedVerification/extended_verification/ Use consistent naming of function parameters. Do not use CamelCase. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-09-11arm: K3: Add initial support for TI's K3 generation of SoCsLokesh Vutla
Add support for Texas Instruments' K3 Generation Processor families. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-09-10serial: omap: Introduce DM specific omap serialLokesh Vutla
Add driver model support for OMAP_SERIAL while reusing the functions in ns16550.c Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Tested-by: Derald D. Woods <woods.technical@gmail.com>
2018-09-10serial: arm_dcc: Add DCC support for V7R based coresLokesh Vutla
DCC is supported on Cortex R series as well. Enable DCC support for V7R. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-09-10sandbox: Add serial testPatrice Chotard
2018-09-10serial: stm32: Replace setparity by setconfigPatrice Chotard
Replace stm32_serial_setparity by stm32_serial_setconfig which allows to set serial bits number, parity and stop bits number. Only parity setting is implemented. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-09-10dm: serial: Replace setparity by setconfigPatrice Chotard
Replace setparity by more generic setconfig ops to allow uart parity, bits word length and stop bits number change. Adds SERIAL_GET_PARITY/BITS/STOP macros. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-09-10serial: protect access to serial rx bufferPatrick Delaunay
Add test to avoid access to rx buffer when this buffer is empty. In this case directly call getc() function to avoid issue when tstc() is not called. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-08-10drivers: serial: document on_baudrate()Heinrich Schuchardt
Add parameter description. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-08-08mips: au1x00: Remove support for these SoCsTom Rini
The only platform left for the AU1x00 SoCs was the pb1x00 platform, an apparent clone of the dbau1x00 platform. As pb1x00 had no listed maintainer I am assuming that it is also orphaned. Remove this platform and then remove the unused SoC support. Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-07-26sandbox: Don't disable ctrlc() on sandbox if in raw modeJoe Hershberger
In raw mode, handle ctrl-c as normal. This allows normal ctrl-c behavior such as aborting a command that is timing out without completely terminating the sandbox executable. In [1], Simon disabled this. His reason for it was that it interferes with piping test scripts. Piping should be done in cooked mode, so this change should still not interfere. [1] commit 8969ea3e9f2db04a6b3675 ("sandbox: Disable Ctrl-C") Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-19serial: zynq: Use platdata for storing static data instead of privMichal Simek
Explanation from Simon Glass "Private data is created when the device is probed and freed when the device is removed. Platform data is created when the device is bound, and survives probe/remove cycles. Strictly speaking, platform data should be used to hold the decoded device tree properties. Private data should be used for run-time things the device needs to keep track of." Based on description the driver needs to be switch to use platdata instead of priv. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-09serial: ns16550: Add reset ctrl to driverLey Foon Tan
Add code to reset all reset signals as in serial DT node. A reset property is an optional feature, so do not fail if a reset property is not present. If a reset property is discovered, then use it to deassert, thus bringing the IP out of reset. Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> Reviewed-by: Marek Vasut <marex@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-09serial: Add Actions Semi OWL UART supportManivannan Sadhasivam
This commit adds Actions Semi OWL family UART support. This driver relies on baudrate configured by primary bootloaders. Signed-off-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-06-23serial: uniphier: set clock rate without clock-frequency propertyMasahiro Yamada
In Linux, the clock rate of the UART is given by the clock driver. If you try to follow that in U-Boot, you would end up with adding more u-boot,dm-pre-reloc properties, and also the clock driver would be too big for SPL, which is used for UniPhier ARMv7 platform. The current solution is to add 'clock-frequency' property to the UART nodes, but it does not exist in the DT files in Linux. I do not want to let DT diverge for U-Boot. Check the SoC compatible and set the clock rate according to it. This will be helpful to sync DT between Linux and U-Boot. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-06-23serial: uniphier: rename struct uniphier_serial_private_dataMasahiro Yamada
Just for making it shorter. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-06-15serial: zynq: Make zynq_serial_setbrg staticMichal Simek
This function is used only inside this driver that's why should be static. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-06-15serial: zynq: Initialize uart only before relocationMichal Simek
This issue was found when OF_LIVE was enabled that there are scrambled chars on the console like this: Chip ID: zu3eg Watchdog: Started��j� sdhci@ff160000: 0, sdhci@ff170000: 1 In: serial@ff010000 I found a solution for this problem exactly the same as I found later in serial_msm fixed by: "serial: serial_msm: initialize uart only before relocation" (sha1: 7e5ad796bcd65772a87da236ae21cd536ae3a4d2) What it is happening is that output TX fifo still contains chars to be sent and _uart_zynq_serial_init() resets TX fifo even in the middle of transfer. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
