path: root/drivers/serial
2010-02-12convert common files to new SoC accessJens Scharsig
* add's a warning to all files, which need update to new SoC access * convert common files in cpu/../at91 and a lot of drivers to use c stucture SoC access Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2010-02-03ns16550: kick watchdog while waiting for a characterLadislav Michl
ns16550 busyloops waiting for incoming byte causing watchdog to reboot while waiting for a key press. A call to WATCHDOG_RESET in NS16550_getc loop fixes it. Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2010-01-23SPEAr : usbd driver support for SPEAr SoCsVipin KUMAR
SPEAr SoCs contain a synopsys usb device controller. USB Device IP can work in 2 modes - DMA mode - Slave mode The driver adds support only for slave mode operation of usb device IP. This driver is used along with standard USBTTY driver to obtain a tty interface over USB on the host Signed-off-by: Vipin <vipin.kumar@st.com>
2009-12-20OMAP3 Add usb device supportTom Rix
This change adds the usb device support for musb. Omap3 platform support added at the same level as davinci. The interface for usbtty to use the musb device support was added. Verified on omap3 beagle, zoom1 and zoom2. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-11-27Add a unified s3c24x0 header filekevin.morfitt@fearnside-systems.co.uk
This patch adds a unified s3c24x0 cpu header file that selects the header file for the specific s3c24x0 cpu from the SOC and CPU configs defined in board config file. This removes the current chain of s3c24-type #ifdef's from the s3c24x0 code. Signed-off-by: Kevin Morfitt <kevin.morfitt@fearnside-systems.co.uk> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-11-27s5pc1xx: serial: fix the error check logicMinkyu Kang
Because of Frame error, Parity error and Overrun error are occured only receive operation, need to masking when error checking. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-11-27s3c64xx: move s3c64xx header files to asm-arm/arch-s3c64xxMinkyu Kang
This patch moves the s3c64xx header files from include/ to include/asm-arm/arch-s3c64xx Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-11-27Move s3c24x0 header files to asm-arm/arch-s3c24x0/kevin.morfitt@fearnside-systems.co.uk
This patch moves the s3c24x0 header files from include/ to include/asm-arm/arch-s3c24x0/. checkpatch.pl showed 2 errors and 3 warnings. The 2 errors were both due to a non-UTF8 character in David M?ller's name: ERROR: Invalid UTF-8, patch and commit message should be encoded in UTF-8 #489: FILE: include/asm-arm/arch-s3c24x0/s3c2410.h:3: + * David M?ller ELSOFT AG Switzerland. d.mueller@elsoft.ch As David's name correctly contains a non-UTF8 character I haven't fixed these errors. The 3 warnings were all because of the use of 'volatile' in s3c24x0.h: WARNING: Use of volatile is usually wrong: see Documentation/volatile-considered-harmful.txt #673: FILE: include/asm-arm/arch-s3c24x0/s3c24x0.h:35: +typedef volatile u8 S3C24X0_REG8; +typedef volatile u16 S3C24X0_REG16; +typedef volatile u32 S3C24X0_REG32; I'll fix these errors in another patch. Tested by running MAKEALL for ARM8 targets and ensuring there were no new errors or warnings. Signed-off-by: Kevin Morfitt <kevin.morfitt@fearnside-systems.co.uk> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-10-24s5pc1xx: SMDKC100: fix compile warningsMinkyu Kang
fix the following compile warnings warning: dereferencing type-punned pointer will break strict-aliasing rules Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-10-13Clean-up of s3c24x0 drivers excluding nand driverkevin.morfitt@fearnside-systems.co.uk
This patch re-formats the arm920t s3c24x0 driver files, excluding the nand driver, in preparation for changes to add support for the Embest SBC2440-II Board. The changes are as follows: - re-indent the code using Lindent - make sure register layouts are defined using a C struct - replace the upper-case typedef'ed C struct names with lower case non-typedef'ed ones - make sure registers are accessed using the proper accessor functions - run checkpatch.pl and fix any error reports It assumes the following patch has been applied first: - [U-Boot][PATCH-ARM] CONFIG_SYS_HZ fix for ARM902T S3C24X0 Boards, 05/09/2009 - patches 1/4 and 2/4 of this series Tested on an Embest SBC2440-II Board with local u-boot patches as I don't have any s3c2400 or s3c2410 boards but need this patch applying before I can submit patches for the SBC2440-II Board. Also, temporarily modified sbc2410x, smdk2400, smdk2410 and trab configs to use the mtd nand driver (which isn't used by any board at the moment), ran MAKEALL for all ARM9 targets and no new warnings or errors were found. Signed-off-by: Kevin Morfitt <kevin.morfitt@fearnside-systems.co.uk> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-10-13s5pc1xx: support serial driverMinkyu Kang
This patch includes the serial driver for s5pc1xx. s5pc1xx uart driver needs own register setting and clock configuration. So, need to special driver. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-07-18stdio/device: rework function naming conventionJean-Christophe PLAGNIOL-VILLARD
So far the console API uses the following naming convention: ======Extract====== typedef struct device_t; int device_register (device_t * dev); int devices_init (void); int device_deregister(char *devname); struct list_head* device_get_list(void); device_t* device_get_by_name(char* name); device_t* device_clone(device_t *dev); ======= which is too generic and confusing. Instead of using device_XX and device_t we change this into stdio_XX and stdio_dev This will also allow to add later a generic device mechanism in order to have support for multiple devices and driver instances. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-06arm: Kirkwood: Basic SOCs supportPrafulla Wadaskar
Kirkwood family controllers are highly integrated SOCs based on Feroceon-88FR131/Sheeva-88SV131/arm926ejs cpu core. SOC versions supported:- 1) 88F6281-A0 define CONFIG_KW88F6281_A0 2) 88F6192-A0 define CONFIG_KW88F6192_A0 Other supported features:- 1) get_random_hex() fucntion 2) PCI Express port initialization 3) NS16550 driver support Contributors: Yotam Admon <yotam@marvell.com> Michael Blostein <michaelbl@marvell.com Reviewed-by: Ronen Shitrit <rshitrit@marvell.com> Acked-by: Stefan Rose <sr@denx.de> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2009-06-21serial_mx31: allow it to work with mx27 too and rename to serial_mxcIlya Yanok
UART hardware on i.MX27 is the same as on the i.MX31 so we just need to provide the driver with correct address of the registers. Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2009-06-12ZOOM2 Add serial support.Tom Rix
Zoom2 serial is in general supplied by one of the 4 UARTS on the debug board. The default serial is from the USB connector on left side of the debug board. The USB connector will produce 2 of the 4 UARTS. On your host pick the first enumeration. The details of the setting of the serial gpmc setup are not available. The values were provided by another party. The serial port set up is the same with Zoom1. Baud rate 115200, 8 bit data, no parity, 1 stop bit, no flow. The kernel bootargs are console=ttyS3,115200n8 Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-06-12lh7a40x: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
2009-06-12pxa: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
2009-06-12arm/dcc: add xscale supportJean-Christophe PLAGNIOL-VILLARD
2009-06-12arm/dcc: use static support to allow to use it at anytimeJean-Christophe PLAGNIOL-VILLARD
the dcc can be used at the start of the cpu Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-05-15Fix e-mail address of Gary Jennejohn.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-04-28mips/vcth: Use generic 16550 uart driverDetlev Zundel
As the common code also handles baudrate switching, which the board specific vct.c driver did not support, this is one of the rare occassions where deleting code actually adds a feature :) Signed-off-by: Detlev Zundel <dzu@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
2009-04-06Support for PXA27X UDC.Remy Bohmer
This Patch adds Support for PXA27X UDC. (Rebased to drivers/usb reorganisation) Signed-off-by: Vivek Kutal <vivek.kutal@azingo.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-04-06drivers/usb: regorganisationJean-Christophe PLAGNIOL-VILLARD
move to linux usb driver organisation as following drivers/usb/gadget drivers/usb/host drivers/usb/musb Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-04-05Update CHANGELOG, coding style cleanup.Wolfgang Denk
2009-04-04at91rm9200: move serial shutdown code to serial driversJean-Christophe PLAGNIOL-VILLARD
introduce serial_exit for this purpose. Use it only when the rm9200 serial driver is active Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-04at91rm9200: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
add CONFIG_AT91RM9200_USART to activate the driver Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-04at91sam9: add watchdog supportJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-03Rename common ns16550 constants with UART_ prefix to prevent conflictsDetlev Zundel
Fix problems introduced in commit 7b5611cdd12ca0cc33f994f0d4a4454788fc3124 [inka4x0: Add hardware diagnosis functions for inka4x0] which redefined MSR_RI which is already used on PowerPC systems. Also eliminate redundant definitions in ps2mult.h. More cleanup will be needed for other redundant occurrences though. Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-03-30s3c24x0: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
2009-03-30imx: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
2009-03-29arm720t/clps7111: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
add CONFIG_CLPS7111_SERIAL to activate the driver Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-03-29lpc2292: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
add CONFIG_LPC2292_SERIAL to activate the driver Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-03-29ks8695: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
add CONFIG_KS8695_SERIAL to activate the driver Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-03-29imx31: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
2009-03-29netarm: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
add CONFIG_NETARM_SERIAL to activate the driver Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-03-29sa1100: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
add CONFIG_SA1100_SERIAL to activate the driver Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-03-29s3c44b0: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
2009-03-21Replaced endpoint numbers with appropriate macros in usbtty.c.Vivek Kutal
2009-02-22arm: add uart dcc supportJean-Christophe PLAGNIOL-VILLARD
Serial driver via the EmbeddedICE macrocell's DCC channel using co-processor 14. It does include a timeout to ensure that the system does not totally freeze when there is nothing connected to read. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-02-21drivers/serial/ns16550: move ifdef into Makefile COBJS-$(...)Mike Frysinger
2009-02-19Create configuration option for restricted ns16550 functionsRon Madrid
This patch will create a configuration option for a minimum configuration for the ns16550 serial driver at drivers/serial/ns16550.c and will apply this new configuration option to the SIMPC8313.h config file in order to fix the NAND bootstrap build error. This option will exclude all functions with exception of NS16550_putc and NS16550_init. This will be used primarily to save space and remove unused code from builds in which space is limited. Signed-off-by: Ron Madrid <ron_madrid@sbcglobal.net>
2009-02-15Added usbtty_configured() check. Fixed attribute(packed) warnings.Atin Malaviya
V3: Fixed line-wrap problem due to user error in mail! Added usb_configured() checks in usbtty_puts() and usbtty_putc() to get around a hang when usb is not connected and the user has set up multi-io (setenv stdout serial,usbtty etc). Got rid of redundant __attribute__((packed)) directives that were causing warnings from gcc. Signed-off-by: Atin Malaviya <atin.malaviya@gmail.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-02-06Coldfire: Applied baudrate formula of serial_init to serial_setbrgRichard Retanubun
Applied the patch for baudrate divider value truncation for serial_init to serial_setbrg as well. Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com>
2009-01-31ixp: move serial to drivers/serialJean-Christophe PLAGNIOL-VILLARD
2009-01-24serial: Rename driver vcth to vct to support other board variantsStefan Roese
Moved driver vcth.c to vct.c to better reflect the VCT board series. This driver is now used by the VCT platforms: vct_premium vct_platinum vct_platinumsvc Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-16sh: serial: use readx/writex accessorsJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-01-16sh: serial: coding style cleanupJean-Christophe PLAGNIOL-VILLARD
2008-12-10sh: Update SuperH serial driverNobuhiro Iwamatsu
The address of SCFSR register is wrong at SH7720/SH7721. This patch fix this. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-12-10serial: Add vcth UART driverStefan Roese
This patch adds the UART driver for the upcoming VCTH board support. Signed-off-by: Stefan Roese <sr@denx.de>
2008-12-09usbtty/omap: update to current APIJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Remy Böhmer <linux@bohmer.net>
