Add gpmi nfc and apbh dma support for mx50.
Signed-off-by: Terry Lv <r65388@freescale.com>
Porting MX233 UBOOT from 1.3.3 to V2009.01. Clear old cfg macro, such as
CFG_HZ. Change MAC address getting source from initial configuration to
On-Chip OTP.
Signed-off-by: Lionel Xu <r63889@freescale.com>
So far the console API uses the following naming convention:
======Extract======
typedef struct device_t;
int device_register (device_t * dev);
int devices_init (void);
int device_deregister(char *devname);
struct list_head* device_get_list(void);
device_t* device_get_by_name(char* name);
device_t* device_clone(device_t *dev);
which is too generic and confusing.
Instead of using device_XX and device_t we change this
into stdio_XX and stdio_dev
This will also allow to add later a generic device mechanism in order
to have support for multiple devices and driver instances.
Edited commit message.
Kirkwood family controllers are highly integrated SOCs
based on Feroceon-88FR131/Sheeva-88SV131/arm926ejs cpu core.
SOC versions supported:-
1) 88F6281-A0 define CONFIG_KW88F6281_A0
2) 88F6192-A0 define CONFIG_KW88F6192_A0
Other supported features:-
1) get_random_hex() fucntion
2) PCI Express port initialization
3) NS16550 driver support
Contributors:
Yotam Admon <yotam@marvell.com>
Michael Blostein <michaelbl@marvell.com
Reviewed-by: Ronen Shitrit <rshitrit@marvell.com>
Acked-by: Stefan Rose <sr@denx.de>
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
UART hardware on i.MX27 is the same as on the i.MX31 so we just
need to provide the driver with correct address of the registers.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
Zoom2 serial is in general supplied by one of the 4 UARTS on the debug board.
The default serial is from the USB connector on left side of the debug board.
The USB connector will produce 2 of the 4 UARTS. On your host pick the first
enumeration.
The details of the setting of the serial gpmc setup are not available.
The values were provided by another party.
The serial port set up is the same with Zoom1.
Baud rate 115200, 8 bit data, no parity, 1 stop bit, no flow.
The kernel bootargs are
console=ttyS3,115200n8
Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
the dcc can be used at the start of the cpu
Signed-off-by: Detlev Zundel <dzu@denx.de>
As the common code also handles baudrate switching, which the board
specific vct.c driver did not support, this is one of the rare
occassions where deleting code actually adds a feature :)
Acked-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
This Patch adds Support for PXA27X UDC.
(Rebased to drivers/usb reorganisation)
Signed-off-by: Vivek Kutal <vivek.kutal@azingo.com>
Signed-off-by: Remy Bohmer <linux@bohmer.net>
move to linux usb driver organisation
as following
drivers/usb/gadget
drivers/usb/host
drivers/usb/musb
introduce serial_exit for this purpose. Use it only when the rm9200
serial driver is active
add CONFIG_AT91RM9200_USART to activate the driver
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Fix problems introduced in commit
7b5611cdd12ca0cc33f994f0d4a4454788fc3124 [inka4x0: Add hardware
diagnosis functions for inka4x0] which redefined MSR_RI which is
already used on PowerPC systems.
Also eliminate redundant definitions in ps2mult.h. More cleanup will
be needed for other redundant occurrences though.
add CONFIG_CLPS7111_SERIAL to activate the driver
add CONFIG_LPC2292_SERIAL to activate the driver
add CONFIG_KS8695_SERIAL to activate the driver
add CONFIG_NETARM_SERIAL to activate the driver
add CONFIG_SA1100_SERIAL to activate the driver
Serial driver via the EmbeddedICE macrocell's DCC channel using
co-processor 14.
It does include a timeout to ensure that the system does not
totally freeze when there is nothing connected to read.
This patch will create a configuration option for a minimum configuration for
the ns16550 serial driver at drivers/serial/ns16550.c and will apply this new
configuration option to the SIMPC8313.h config file in order to fix the NAND
bootstrap build error. This option will exclude all functions with exception of
NS16550_putc and NS16550_init. This will be used primarily to save space and
remove unused code from builds in which space is limited.
Signed-off-by: Ron Madrid <ron_madrid@sbcglobal.net>
V3: Fixed line-wrap problem due to user error in mail!
Added usb_configured() checks in usbtty_puts() and usbtty_putc() to get around a hang
when usb is not connected and the user has set up multi-io (setenv stdout serial,usbtty etc).
Got rid of redundant __attribute__((packed)) directives that were causing warnings from gcc.
Signed-off-by: Atin Malaviya <atin.malaviya@gmail.com>
Applied the patch for baudrate divider value truncation for
serial_init to serial_setbrg as well.
Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com>
Moved driver vcth.c to vct.c to better reflect the VCT board series.
This driver is now used by the VCT platforms:
vct_premium
vct_platinum
vct_platinumsvc
The address of SCFSR register is wrong at SH7720/SH7721.
This patch fix this.
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
This patch adds the UART driver for the upcoming VCTH board support.
Signed-off-by: Remy Böhmer <linux@bohmer.net>
Several source files need to be compiled and linked when one or more
config options are selected. To allow for easy selection in the
Makefiles yet to avoild multiple compilation (which costs build time)
and especially multiple linking (which causes errors), we use
"COBJS = $(sort COBJS-y)" which eliminates duplicates.
By courtesy of Detlev Zundel who suggested this approach.
Signed-off-by: Andreas Engel <andreas.engel@ericsson.com>
They only differ in the init function.
This also adds the missing watchdog support for the PL011.
Renesas SH7723 has 5 SCIF, SD, Camera, LCDC and other.
This patch supports CPU register's header file and SCIF serial driver.
