path: root/drivers/serial/usbtty.h
2012-03-28Enable high speed support for USB device framework and usbttyVipin KUMAR
This patch adds the support for high speed in usb device framework and usbtty driver. This feature has been kept within a macro CONFIG_USBD_HS, so the board configuration files have to define this macro to enable high speed support. Along with that specific peripheral drivers also need to define a function to let the framework know that the enumeration has happened at high speed. This function prototype is "int is_usbd_high_speed(void)" Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com>
2012-03-19USB:gadget:designware USB device controller (UDC) implementationVipin KUMAR
The earlier usb device controller driver was specific to spear platforms. This patch implements the usb device controller driver as a generic controller which can be reused by other platforms using this peripheral. Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Acked-by: Marek Vasut <marex@denx.de>
2011-12-06PXA: Rename CONFIG_PXA2[57]X to CONFIG_CPU_PXA2[57]XMarek Vasut
2011-10-17Move timestamp and version files into 'generated' subdirSimon Glass
There is a rather subtle build problem where the build time stamp is not updated for out-of-tree builds if there exists an in-tree build which has a valid timestamp file. So if you do an in-tree build, then an out-of-tree build your timestamp will not change. The correct timestamp_autogenerated.h lives in the object tree, but it is not always found there. The source still lives in the source tree and when compiling version.h, it includes timestamp_autogenerated.h. Since the current directory is always searched first, this will come from the source tree rather than the object tree if it exists there. This affects dependency generation also, which means that common/cmd_version.o will not even be rebuilt if you have ever done an in-tree build. A similar problem exists with the version file. This change moves both files into the 'generated' subdir, which is already used for asm-offsets.h. Then timestamp.h and version.h are updated to include the files from there. There are other places where these generated files are included, but I cannot see why these don't just use the timestamp.h and version.h headers. So this change also tidies that up. I have tested this with in- and out-of-tree builds, but not SPL. I have looked at various other options for fixing this, including sed on the dep files, -I- and -include flags to gcc, but I don't think they can be made to work. Comments welcome. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2010-03-21mod change 755 => 644 for multiple filesThomas Weber
I executed 'find . -name "*.[chS]" -perm 755 -exec chmod 644 {} \;' Signed-off-by: Thomas Weber <swirl@gmx.li> Add some more: neither Makefile nor config.mk need execute permissions. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-01-23SPEAr : usbd driver support for SPEAr SoCsVipin KUMAR
SPEAr SoCs contain a synopsys usb device controller. USB Device IP can work in 2 modes - DMA mode - Slave mode The driver adds support only for slave mode operation of usb device IP. This driver is used along with standard USBTTY driver to obtain a tty interface over USB on the host Signed-off-by: Vipin <vipin.kumar@st.com>
2009-12-20OMAP3 Add usb device supportTom Rix
This change adds the usb device support for musb. Omap3 platform support added at the same level as davinci. The interface for usbtty to use the musb device support was added. Verified on omap3 beagle, zoom1 and zoom2. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-04-06Support for PXA27X UDC.Remy Bohmer
This Patch adds Support for PXA27X UDC. (Rebased to drivers/usb reorganisation) Signed-off-by: Vivek Kutal <vivek.kutal@azingo.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-04-06drivers/usb: regorganisationJean-Christophe PLAGNIOL-VILLARD
move to linux usb driver organisation as following drivers/usb/gadget drivers/usb/host drivers/usb/musb Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2008-12-09usbtty/omap: update to current APIJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Remy Böhmer <linux@bohmer.net>
2007-11-25drivers/serial : move serial drivers to drivers/serialJean-Christophe PLAGNIOL-VILLARD
