path: root/drivers/serial/serial_x86.c
2015-01-13x86: Use ePAPR defined properties for x86-uartBin Meng
Use ePAPR defined properties for x86-uart: clock-frequency and current-speed. Assign the value of clock-frequency in device tree to plat->clock of x86-uart instead of using hardcoded number. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-18x86: Rename coreboot-serial to x86-serialBin Meng
