path: root/drivers/serial/serial_sifive.c
2019-05-09serial: sifive: Change include orderJagan Teki
Like clk_get_by_index, there is requirement for clk_get_by_index_nodev. In this case to make common code functionalities for dev and nodev, clk_get_by_index is trying to get the index of clock by passing ofnode instead of actual dev like current gpio uclass does. In these scenarios with current order of include files the serial_sifive driver is unable to find CONFIG_ENV_SIZE. In file included from arch/riscv/include/asm/u-boot.h:23:0, from include/dm/of.h:10, from include/dm/ofnode.h:12, from include/clk.h:11, from drivers/serial/serial_sifive.c:6: include/environment.h:145:19: error: 'CONFIG_ENV_SIZE' undeclared here (not in a function); did you mean 'CONFIG_CMD_XIMG'? #define ENV_SIZE (CONFIG_ENV_SIZE - ENV_HEADER_SIZE) So, fix consists of changing the order of include files in serial_sifive.c to include first common.h file. Cc: Anup Patel <Anup.Patel@wdc.com> Cc: Rick Chen <rick@andestech.com> Cc: Paul Walmsley <paul.walmsley@sifive.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2019-02-27drivers: serial_sifive: Skip baudrate config if no input clockAtish Patra
It is possible that input clock is not available because clk device was not available and 'clock-frequency' DT property is also not available. In this case, instead of failing we should just skip baudrate config by returning zero. Signed-off-by: Atish Patra <atish.patra@wdc.com> Signed-off-by: Anup Patel <anup.patel@wdc.com> Reviewed-by: Alexander Graf <agraf@suse.de>
2019-02-27drivers: serial_sifive: Fix baud rate calculationAtish Patra
Compute the baud rate multipler with more precision. Signed-off-by: Atish Patra <atish.patra@wdc.com> Signed-off-by: Anup Patel <anup.patel@wdc.com> Reviewed-by: Alexander Graf <agraf@suse.de> Reviewed-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de>
2018-12-18drivers: serial: Add SiFive UART driverAnup Patel
This patch adds SiFive UART driver. The driver is 100% DM driver and it determines input clock using clk framework. Signed-off-by: Anup Patel <anup@brainfault.org> Reviewed-by: Palmer Dabbelt <palmer@sifive.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
