path: root/drivers/serial/serial_ixp.c
2012-10-17serial: Use default_serial_puts() in driversMarek Vasut
Replace the in-place ad-hoc implementation of serial_puts() within the drivers with default_serial_puts() call. This cuts down on the code duplication quite a bit. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from serial driversMarek Vasut
Remove the support for not-CONFIG_SERIAL_MULTI part from serial port drivers and some board files. Since CONFIG_SERIAL_MULTI is now enabled by default, that part is a dead code. Remove it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-15serial: arm: Implement CONFIG_SERIAL_MULTI into ixp serial driverMarek Vasut
Implement support for CONFIG_SERIAL_MULTI into ixp serial driver. This driver was so far only usable directly, but this patch also adds support for the multi method. This allows using more than one serial driver alongside the ixp driver. Also, add a weak implementation of default_serial_console() returning this driver. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Michael Schwingen <michael@schwingen.org>
2011-06-23trigger hardware watchdog in IXP42x serial driverMichael Schwingen
Signed-off-by: Michael Schwingen <michael@schwingen.org>
2009-01-31ixp: move serial to drivers/serialJean-Christophe PLAGNIOL-VILLARD
