path: root/drivers/serial/serial.c
2015-12-05Fix typo: firstly -> first.Vagrant Cascadian
Signed-off-by: Vagrant Cascadian <vagrant@debian.org> Acked-by: Marek Vasut <marex@denx.de>
2015-10-23serial: remove altera serial initializationsThomas Chou
Both altera_jtag_serial_initialize() and altera_serial_initialize() are no longer used after they are converted to driver model. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de>
2015-04-22stm32f4: Add serial driverrev13@wp.pl
Signed-off-by: Kamil Lulko <rev13@wp.pl> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-02-24ARM: remove cm4008 and cm41xx board supportMasahiro Yamada
These are still non-generic boards. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Greg Ungerer <greg.ungerer@opengear.com> Acked-by: Marek Vasut <marex@denx.de>
2014-11-04serial: add prototypes for init functionsJeroen Hofstee
While at it, sort them. Cc: Tom Rini <trini@ti.com> Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-10-26Merge git://git.denx.de/u-boot-dmTom Rini
Fix a trivial conflict over adding <dm.h> Conflicts: arch/arm/cpu/armv7/omap3/board.c Signed-off-by: Tom Rini <trini@ti.com>
2014-10-25serial: make local functions staticJeroen Hofstee
2014-10-23serial: remove uniphier_serial_initialize() callMasahiro Yamada
The UniPhier serial driver has been converted to driver model. Let's remove uniphier_serial_initialize() call from the old serial driver framework. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-10-05serial: add UniPhier serial driverMasahiro Yamada
The driver for on-chip UART used on Panasonic UniPhier platform. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-09-10serial: Set up the 'priv' pointer when creating a serial deviceSimon Glass
The stdio_dev structure has a private pointer for its creator, but it is not set up by the serial system. Set it to point to the serial device so that it can be found by code called by stdio. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-07-23Add a flag indicating when the serial console is readySimon Glass
For sandbox we have a fallback console which is used very early in U-Boot, before serial drivers are available. Rather than try to guess when to switch to the real console, add a flag so we can be sure. This makes sure that sandbox can always output a panic() message, for example, and avoids silent failure (which is very annoying in sandbox). Signed-off-by: Simon Glass <sjg@chromium.org>
2014-07-23stdio: Pass device pointer to stdio methodsSimon Glass
At present stdio device functions do not get any clue as to which stdio device is being acted on. Some implementations go to great lengths to work around this, such as defining a whole separate set of functions for each possible device. For driver model we need to associate a stdio_dev with a device. It doesn't seem possible to continue with this work-around approach. Instead, add a stdio_dev pointer to each of the stdio member functions. Note: The serial drivers have the same problem, but it is not strictly necessary to fix that to get driver model running. Also, if we convert serial over to driver model the problem will go away. Code size increases by 244 bytes for Thumb2 and 428 for PowerPC. 22: stdio: Pass device pointer to stdio methods arm: (for 2/2 boards) all +244.0 bss -4.0 text +248.0 powerpc: (for 1/1 boards) all +428.0 text +428.0 Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Marek Vasut <marex@denx.de>
2014-05-12bd_info: remove bi_barudrate member from struct bd_infoMasahiro Yamada
gd->bd->bi_baudrate is a copy of gd->baudrate. Since baudrate is a common feature for all architectures, keep gd->baudrate only. It is true that bi_baudrate was passed to the kernel in that structure but it was a long time ago. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Cc: Simon Glass <sjg@chromium.org> Cc: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de> Acked-by: Michal Simek <monstr@monstr.eu> (For microblaze)
2014-05-06serial: zynq: Fix typo in suffix function nameMichal Simek
's/zynq_serial_initalize/zynq_serial_initialize/g' serial_initialize is used by all serial drivers. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-02-19Merge branch 'u-boot-pxa/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-02-07serial/serial_arc - add driver for ARC UARTAlexey Brodkin
Driver for non-standard on-chip UART, instantiated in the ARC (Synopsys) FPGA Boards such as ARCAngel4/ML50x Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Mischa Jonker <mjonker@synopsys.com> Cc: Francois Bedard <fbedard@synopsys.com> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2014-02-06ARM: serial: Remove the IXP UART driverMarek Vasut
This driver is no longer used, remove it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Michael Schwingen <michael@schwingen.org> Cc: Tom Rini <trini@ti.com>
2013-09-19drivers: serial_s3c44b0: delete an unused driverMasahiro Yamada
Since commit 5dc5f36 removed B2 board support, there are no boards enabling serial_s3c44b0. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Andrea Scian <andrea.scian@dave-tech.it>
2013-09-05Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: drivers/serial/serial.c The conflict above was a trivial case of adding one init function in each branch, and manually resolved in merge.
2013-08-21ARM: mxs: Added application UART driverAndreas Wass
The driver makes it possible to use an application UART as the U-Boot output console for Freescale i.MX23/i.MX28 devices. Signed-off-by: Andreas Wass <andreas.wass@dalelven.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Marek Vasut <marex@denx.de> Acked-by: Marek Vasut <marex@denx.de>
2013-08-13serial: arm_dcc: Register with serial coreJagannadha Sutradharudu Teki
Register arm_dcc with drivers/serial/serial.c Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-06-26serial: Use ARRAY_SIZE instead of reinventing itAxel Lin
Signed-off-by: Axel Lin <axel.lin@ingics.com>
2013-05-15Power: remove support for Freescale MPC8220Wolfgang Denk
The Freescale MPC8220 Power Architecture processors have long reached EOL; Freescale does not even list these any more on their web site. Remove the code to avoid wasting maitaining efforts on dead stuff. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andy Fleming <afleming@gmail.com>
2013-04-12arm: Remove support for unused s3c64xxBenoît Thébaudeau
Following the removal of the smdk6400 board, the s3c64xx SoC becomes unused, so remove associated code. It will still be possible to restore it later from the Git history if necessary. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-02-28ARM: ns9750dev: remove remainders of dead boardWolfgang Denk
Commit 8b710b1 started removing code for the unmaintained "ns9750dev" board; the board support is still broken, and not included anywhere in the Makefile or boards.cfg. Remove the remaining dead code. Signed-off-by: Wolfgang Denk <wd@denx.de>
2012-12-13env: Add a baudrate env handlerJoe Hershberger
Remove the hard-coded baudrate handler and use a callback instead Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-10-26arm: Remove support for NETARMMarek Vasut
This stuff has been rotting in the tree for a while now. Remove it. Signed-off-by: Marek Vasut <marex@denx.de>
2012-10-26arm: Remove support for s3c4510Marek Vasut
This stuff has been rotting in the tree for a year now. Remove it. Signed-off-by: Marek Vasut <marex@denx.de>
2012-10-26arm: Remove support for lpc2292Marek Vasut
2012-10-17kerneldoc: Annotate drivers/serial/serial.cMarek Vasut
Add kerneldoc annotations into serial core. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-10-17serial: Reorder get_current()Marek Vasut
Reorder the get_current() function to make it a bit more readable. The code does not grow and there is minor change in the code logic, where dev != NULL is now checked in any case. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-10-17serial: Reorder serial_assign()Marek Vasut
Reorder serial_assign() function to get rid of the extra level of indentation. Also, adjust the return value to be -EINVAL instead of positive one to be more consistent. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-10-17serial: Implement default_serial_puts()Marek Vasut
U-Boot contains a lot of duplicit implementations of serial_puts() call which just pipes single characters into the port in loop. Implement function that does this behavior into common code, so others can make easy use of it. This function is called default_serial_puts() and it's sole purpose is to call putc() in loop on the whole string passed to it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-10-15serial: Enhance the manual relocationMarek Vasut
Enhance the manual relocation of drivers operations structure by checking if the entries are NULL and increment them only if they are not. This allows for setting any entry to NULL and it will survive the manual relocation. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de>
2012-10-15serial: Move common/serial.c to drivers/serial/Marek Vasut
Move the common/serial.c into driver/serial/, since this file provides serial multiplexing functions and it is imperative to be linked with libserial.o instead of libcommon.o. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-10-15serial: ns16550: Rename serial.c to serial_ns16550.cMarek Vasut
This serial driver had wrong name of the source file for some time now. The name of the driver was serial.c instead of any more logical and fitting name. Thus, rename the driver source file to serial_ns16550.c and be done with it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Michal Simek <monstr@monstr.eu>
2012-10-15serial: ns16550: Move serial registration from serial_initialize()Marek Vasut
Move the registration of eserialN_device ports from default serial_initialize() into driver specific function called from serial_initialize(). This slims down the serial_initialize() call to a bare tracker of all possible serial port registration routines in U-Boot. The newly implemented ns16550_serial_initialize() function, which is implemented inside of the ns16550 serial driver allows encapsulation of eserialN_device within the ns16550 serial driver itself. Also, remove the exports of eserialN_device from include/serial.h as they are no longer needed. This is simply because the implementation of default_serial_console() is wrapped into the ns16550 serial driver and the default console is picked by CONFIG_SERIAL<N> macro in config file. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Michal Simek <monstr@monstr.eu>
2012-10-15serial: Properly spell out the structure member names of serial_driverMarek Vasut
Properly spell out the whole structure member names when an initialized varible is instantiated from the struct serial_driver. In case the structure definition for struct serial_driver undergoes reordering, there will be no impact on variables defined based on this structure. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: C Nauman <cnauman@diagraph.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Michal Simek <monstr@monstr.eu>
2012-08-10serial: CONSOLE macro is not usedMichal Simek
Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-27serial: reduce include platform file for marvell chipLei Wen
Build pass with following config: dkb_config aspenite_config edminiv2_config openrd_ultimate_config sheevaplug_config mv88f6281gtw_ge_config rd6281a_config guruplug_config km_kirkwood_config Signed-off-by: Lei Wen <leiwen@marvell.com> Acked-by: Wolfgang Denk <wd@denx.de>
2011-07-26serial: drop useless ctlr fieldMike Frysinger
The multi serial support has a "ctlr" field which almost no one uses, but everyone is forced to set to useless strings. So punt it. Funny enough, the only code that actually reads this field (the mpc8xx driver) has a typo where it meant to look for the SCC driver. Fix it while converting the check to use the name field. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Heiko Schocher <hs@denx.de> CC: Anatolij Gustschin <agust@denx.de> CC: Tom Rix <Tom.Rix@windriver.com> CC: Minkyu Kang <mk7.kang@samsung.com> CC: Craig Nauman <cnauman@diagraph.com> CC: Marek Vasut <marek.vasut@gmail.com> CC: Prafulla Wadaskar <prafulla@marvell.com> CC: Mahavir Jain <mjain@marvell.com>
2011-07-26serial: push default_serial_console to driversMike Frysinger
Rather than sticking arch/board/driver specific logic in the common serial code, push it all out to the respective drivers. The serial drivers declare these funcs weak so that boards can still override things with their own definition. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Heiko Schocher <hs@denx.de> CC: Anatolij Gustschin <agust@denx.de> CC: Tom Rix <Tom.Rix@windriver.com> CC: Minkyu Kang <mk7.kang@samsung.com> CC: Craig Nauman <cnauman@diagraph.com> CC: Prafulla Wadaskar <prafulla@marvell.com> CC: Mahavir Jain <mjain@marvell.com> Tested-by: Minkyu Kang <mk7.kang@samsung.com>
2011-02-21serial: add pantheon soc supportLei Wen
2010-12-16Serial: Add UART support for Marvell ARMADA 100 SoCs.Prafulla Wadaskar
ARMADA 100 SoCs has NS16550 compatible UART peripheral This patch enables the same for ARMADA100 platforms Signed-off-by: Mahavir Jain <mjain@marvell.com> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2010-06-17Add Orion5x support to 16550 device driverAlbert Aribaud
This patch provides access to the 16550-compatible serial device of the Orion5x SoC. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2010-04-24serial: struct serial_device: add uninit() entry for driversAnatolij Gustschin
Subsequent patch extends mpc512x serial driver to support multiple PSC ports. The driver will provide an uninit() function to stop the serial controller and to disable the controller's clock. Adding uninit() entry to struct serial_device allows disabling the serial controller after usage of a stdio serial device. This patch adds uninit() entry to the struct serial_device and fixes initialization of this structure in the code accordingly. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2009-07-06arm: Kirkwood: Basic SOCs supportPrafulla Wadaskar
Kirkwood family controllers are highly integrated SOCs based on Feroceon-88FR131/Sheeva-88SV131/arm926ejs cpu core. SOC versions supported:- 1) 88F6281-A0 define CONFIG_KW88F6281_A0 2) 88F6192-A0 define CONFIG_KW88F6192_A0 Other supported features:- 1) get_random_hex() fucntion 2) PCI Express port initialization 3) NS16550 driver support Contributors: Yotam Admon <yotam@marvell.com> Michael Blostein <michaelbl@marvell.com Reviewed-by: Ronen Shitrit <rshitrit@marvell.com> Acked-by: Stefan Rose <sr@denx.de> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2009-02-21drivers/serial/ns16550: move ifdef into Makefile COBJS-$(...)Mike Frysinger
