path: root/drivers/serial/serial-uclass.c
2018-01-29serial: Make full device search optionalAlexander Graf
Commit 608b0c4ad4e5ec0c ("serial: Use next serial device if probing fails") added code to search for more serial devices if the default one was not probed correctly. Unfortunately, that breaks omap3_evm. So while investigating why that is the case, let's disable the full search for everyone but bcm283x where it is needed. Fixes: 608b0c4ad4e5ec0c ("serial: Use next serial device if probing fails") Reported-by: Derald D. Woods <woods.technical@gmail.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-28serial: Use next serial device if probing failsAlexander Graf
Currently our serial device search chokes on the fact that the serial probe function could fail. If it does, instead of searching for the next usable serial device, it just quits. This patch changes the fallback logic so that even when a serial device was not probed correctly, we just try the next ones until we find one that works. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-24serial: serial-uclass: Add generic serial RX buffer supportStefan Roese
Pasting longer lines into the U-Boot console prompt sometimes leads to characters missing. One problem here is the small 16-byte FIFO of the legacy NS16550 UART, e.g. on x86 platforms. This patch now introduces a Kconfig option to enable RX buffer support for all DM based serial drivers. With this option enabled, I was able paste really long lines into the U-Boot console, without any characters missing. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-31dm: console: Check for serial devices properlySimon Glass
With driver model the serial device is often not called "serial". Mark driver-model stdio devices so that they can be detected and we can look up the uclass. This is a more reliable way of finding out whether the console is connected to a serial device or not. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-27spl: make SPL and normal u-boot stage use independent SYS_MALLOC_F_LENAndy Yan
Some platforms have very limited SRAM to run SPL code, so there may not be the same amount space for a malloc pool before relocation in the SPL stage as the normal U-Boot stage. Make SPL and (the full) U-Boot stage use independent SYS_MALLOC_F_LEN, so the size of pre-relocation malloc pool can be configured memory space independently. Signed-off-by: Andy Yan <andy.yan@rock-chips.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> [fixed up commit-message:] Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-11dm: serial: Add livetree supportSimon Glass
Add support for a live device tree to the core serial uclass. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Tested-on: Beaver, Jetson-TK1
2017-07-11dm: serial: Separate out the core serial-device finding codeSimon Glass
This function is quite long. Move the core code into a separate function in preparation for adding livetree support. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Tested-on: Beaver, Jetson-TK1
2017-07-06serial: make serial_stub_* to static functionsMasahiro Yamada
Add missing static to serial_stub_puts(). Unexport serial_stub_{getc,tstc} because they are used locally. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: core: Update lists_bind_fdt() to use ofnodeSimon Glass
Adjust this function to use an ofnode instead of an offset, so it can be used with livetree. This involves updating all callers. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-17serial: serial-uclass: Use force parameter in stdio_deregister_dev()Stefan Roese
On my x86 platform I've noticed, that calling dm_uninit() or the new function dm_remove_devices_flags() does not remove the desired device at all. Debugging showed, that the serial uclass returns -EPERM in serial_pre_remove(). This patch sets the force parameter when calling stdio_deregister_dev() resulting in a removal of the device. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-23Convert CONFIG_SYS_STDIO_DEREGISTER to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_STDIO_DEREGISTER This option should never be enabled in SPL, so use CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) when checking the option. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Re-sync] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-07-14dm: serial: Add support for of-platdataSimon Glass
When this feature is enabled, we cannot access the device tree to find out which serial device to use. Just use the first serial driver we find. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-17x86: Allow use of serial soon after relocationSimon Glass
At present on x86 machines with use cache-as-RAM, the memory goes away just before board_init_r() is called. This means that serial drivers are no-longer unavailable, until initr_dm() it called, etc. Any attempt to use printf() within this period will cause a hang. To fix this, mark the serial devices as 'unavailable' when it is no-longer available. Bring it back when serial_initialize() is called. This means that the debug UART will be used instead for this period. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-03-14dm: serial-uclass: Move a carriage return before a line feedAlison Wang
In general, a carriage return needs to execute before a line feed. The patch is to change serial DM driver serial-uclass.c based on this rule. Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-12dm: serial: Allow the UART driver to be dropped from the imageSimon Glass
In very very space-constrained devices even the full UART driver is too large. In this case the debug UART can still be used in some cases. Add options to enable the UART driver in SPL and U-Boot proper. Enable both options by default. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Thomas Chou <thomas@wytron.com.tw>
2015-12-10dm: serial: Minor coding style cleanup of some commentsStefan Roese
Fix incorrect comment alignments. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-04dm: serial: Deal with stdout-path with an aliasSimon Glass
Sometimes stdout-path contains a UART alias along with speed, etc. For example: stdout-path = "serial0:115200n8"; Add support for decoding this. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-08-18of: clean up OF_CONTROL ifdef conditionalsMasahiro Yamada
We have flipped CONFIG_SPL_DISABLE_OF_CONTROL. We have cleansing devices, $(SPL_) and CONFIG_IS_ENABLED(), so we are ready to clear away the ugly logic in include/fdtdec.h: #ifdef CONFIG_OF_CONTROL # if defined(CONFIG_SPL_BUILD) && !defined(SPL_OF_CONTROL) # define OF_CONTROL 0 # else # define OF_CONTROL 1 # endif #else # define OF_CONTROL 0 #endif Now CONFIG_IS_ENABLED(OF_CONTROL) is the substitute. It refers to CONFIG_OF_CONTROL for U-boot proper and CONFIG_SPL_OF_CONTROL for SPL. Also, we no longer have to cancel CONFIG_OF_CONTROL in include/config_uncmd_spl.h and scripts/Makefile.spl. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2015-08-10dm: serial: Add a REQUIRE_SERIAL_CONSOLE option for boards with no serial portHans de Goede
Currently the serial code assumes that there is always at least one serial port (and panics / crashes due to null pointer dereferences when there is none). This makes it impossible to use u-boot on boards where there is no (debug) serial port, because e.g. all uart pins are muxed to another function. This commit adds a CONFIG_REQUIRE_SERIAL_CONSOLE Kconfig option, which defaults to y (preserving existing behavior), which can be set to n on such boards to make them work. This commit only implements this for CONFIG_DM_SERIAL=y configs, as allowing running without a serial port for CONFIG_DM_SERIAL=n configs is non trivial, and is not necessary at this moment. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-05dm: serial: Correct logic in serial_find_console_or_panic()Simon Glass
In a final attempt to find a console UART this function uses the first first available serial device. However the check for a valid device is inverted. This code is only executed when there is in fact no serial UART, but at present it can fail to reach the panic_str() call in this case, and start trying to use a non-existent UART. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-06-10sandbox: Move CONFIG_SANDBOX_SERIAL to KconfigSimon Glass
Move this over to Kconfig and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-06-10dm: serial: Don't support CONFIG_CONS_INDEX with device treeSimon Glass
This feature should be deprecated for new boards, and significantly adds to SPL code size. Drop it. Instead, we can use stdout-path in the /chosen node. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-23dm: Add a panic_str() function to reduce code sizeSimon Glass
The printf() in panic() adds about 1.5KB of code size to SPL when compiled with Thumb-2. Provide a smaller version that does not support printf()-style arguments and use it in two commonly compiled places. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-16dm: core: Add dev_get_uclass_priv() to access uclass private dataSimon Glass
Add a convenience function to access the private data that a uclass stores for each of its devices. Convert over most existing uses for consistency and to provide an example for others. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-03-25dm: serial: remove bogus include <ns16550.h>Masahiro Yamada
Serial-uclass should be generically implemented without depending a particular hardware. Fortunately, nothing in include/ns16550.h is referenced from drivers/serial/serial-uclass.c, so remove this bogus include. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: Add support for all targets which requires MANUAL_RELOCMichal Simek
Targets with CONFIG_NEEDS_MANUAL_RELOC do not use REL/RELA relocation (mostly only GOT) where functions aray are not updated. This patch is fixing function pointers for DM core and serial-uclass to ensure that relocated functions are called. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-29dm: core: Add a flag to control sequence numberingSimon Glass
At present we try to use the 'reg' property and device tree aliases to give devices a sequence number. The 'reg' property is often actually a memory address, so the sequence numbers thus-obtained are not useful. It would be better if the devices were just sequentially numbered in that case. In fact neither I2C nor SPI use this feature, so drop it. Some devices need us to look up an alias to number them within the uclass. Add a flag to control this, so it is not done unless it is needed. Adjust the tests to test this new behaviour. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-27fdt: remove fdtdec_get_alias_node() functionMasahiro Yamada
The fdt_path_offset() checks an alias too. fdtdec_get_alias_node(blob, "foo") is equivalent to fdt_path_offset(blob, "foo"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-24Merge git://git.denx.de/u-boot-dmTom Rini
Conflicts: drivers/serial/serial-uclass.c Signed-off-by: Tom Rini <trini@ti.com>
2014-11-21dm: Allow stdio registration to be droppedSimon Glass
Provide a CONFIG_DM_STDIO option to enable registering a serial device with the stdio library. This is seldom useful in SPL, so disable it by default when building for SPL. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-21dm: serial: Support changing the baud rateSimon Glass
Implement this feature in the uclass so that the baudrate can be changed with 'setenv baudrate <rate>'. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-21dm: serial: Move current serial port pointer to global_dataSimon Glass
In general we can't store things in the data section until we have inited SDRAM. Some platforms allow this (e.g. those with SPL) but some don't. Move the pointer to global_data so that it will work on all platforms. Without this fix the serial port will not work prior to relocation with driver model on some platforms. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-23dm: serial: consolidate common code moreMasahiro Yamada
Commit b8893327e9d2 (dm: serial: Put common code into separate functions) consolidated getc() and putc(). This commit does more puts() and tsts(). Also rename locally used functions to _serial_*() for clarification because we have similar functions names here are there in this file. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-10-23dm: serial: remove unnecessary castingMasahiro Yamada
The type (void *) can be directly passed to a function that takes a specific pointer type. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-10-23dm: serial: fix console putcMasahiro Yamada
Commit b8893327e9d2 (dm: serial: Put common code into separate functions) consolidated getc() correctly, but introduced another bug to putc(); serial_stub_putc() passes sdev->priv to serial_putc_dev(), but serial_putc_dev() uses cur_dev instead of the given argument. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-10-23dm: serial: Support CONFIG_CONS_INDEX if availableSimon Glass
Try to use this option to select the correct uart for the console. This mimics the behaviour of drivers/serial.c. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2014-10-23dm: serial: Reset the watchdog while waiting in getc()Simon Glass
We have moved the busy-wait loop out of drivers and into the uclass. This means that we must reset the watchdog when busy-waiting. Note: some drivers may still have a busy-wait even with driver model, as a transition mechanism. Driver model will tolerate this, and is can be cleaned up when all users of the driver use driver model. An example is ns16550. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2014-10-22dm: serial: Put common code into separate functionsSimon Glass
Avoid duplicating the code which deals with getc() and putc(). It is fairly simple, but may expand later. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-10serial-uclass: Fix compilation errorHans de Goede
2014-10-06stdio: Add force parameter to stdio_deregisterHans de Goede
In some cases we really want to move forward with a deregister, add a force parameter to allow this, and replace the dev with a nulldev in this case. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-09-23dm: serial: Don't require device tree to configure a consoleSimon Glass
Allow serial_find_console_or_panic() to work without a device tree. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-10dm: Add a uclass for serial devicesSimon Glass
Serial devices support simple byte input/output and a few operations to find out whether data is available. Add a basic uclass for serial devices to be used by drivers that are converted to driver model. Signed-off-by: Simon Glass <sjg@chromium.org>
