path: root/drivers/serial/Kconfig
2018-01-29serial: Make full device search optionalAlexander Graf
Commit 608b0c4ad4e5ec0c ("serial: Use next serial device if probing fails") added code to search for more serial devices if the default one was not probed correctly. Unfortunately, that breaks omap3_evm. So while investigating why that is the case, let's disable the full search for everyone but bcm283x where it is needed. Fixes: 608b0c4ad4e5ec0c ("serial: Use next serial device if probing fails") Reported-by: Derald D. Woods <woods.technical@gmail.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-28bcm2835_pl011_serial: Add BCM2835 specific serial driverAlexander Graf
On bcm2835 we need to ensure we only access serial devices that are muxed to the serial output pins of the pin header. To achieve this for the pl011 device, add a bcm2835 specific pl011 wrapper device that does this check but otherwise behaves like a pl011 device. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-28bcm2835_mu_serial: Convert to KconfigAlexander Graf
Setting config options using headers is deprecated. This patch converts the BCM2835 Mini-UART to Kconfig. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-28pl01x: Convert CONFIG_PL01X_SERIAL to KconfigAlexander Graf
We want to use Kconfig logic to depend on whether pl01x devices are built in, so let's convert their inclusion selection to Kconfig. This round goes to pl01x. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-28pl011: Convert CONFIG_PL011_SERIAL to KconfigAlexander Graf
We want to use Kconfig logic to depend on whether pl01x devices are built in, so let's convert their inclusion selection to Kconfig. This round goes to pl011. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-28pl010: Convert CONFIG_PL010_SERIAL to KconfigAlexander Graf
We want to use Kconfig logic to depend on whether pl01x devices are built in, so let's convert their inclusion selection to Kconfig. This round goes to pl010. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-19serial: stm32: Rename serial_stm32x7.c to serial_stm32.cPatrice Chotard
Now this driver is used across stm32f4, stm32f7 and stm32h7 SoCs family, give it a generic name. Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Vikas Manocha <vikas.manocha@st.com>
2017-11-28arm: zynq: Move ZYNQ_SERIAL to KconfigMichal Simek
Move cadence/zynq serial driver via Kconfig Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-08serial: stm32x7: add STM32F4 supportPatrice Chotard
stm32f4 doesn't support FIFO and OVERRUN feature. The enable bit is not at the same location in CR1 register than for STM32F7 and STM32H7. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-09-22serial: stm32x7: add STM32H7 supportPatrice Chotard
STM32F7 and STM32H7 shares the same UART block, add STM32H7 compatible string. Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-13serial: nulldev: Add nulldev serial driverKeng Soon Cheah
Some device the serial console's initialization cannot run early during the boot process. Hence, nulldev serial device is helpful on that situation. For example, if the serial module was implemented in FPGA. Serial initialization is prohibited to run until the FPGA was programmed. This commit is to adding nulldev serial driver. This will allows the default console to be specified as a nulldev. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Keng Soon Cheah <keng.soon.cheah@ni.com> Cc: Chen Yee Chew <chen.yee.chew@ni.com>
2017-08-24serial: serial-uclass: Add generic serial RX buffer supportStefan Roese
Pasting longer lines into the U-Boot console prompt sometimes leads to characters missing. One problem here is the small 16-byte FIFO of the legacy NS16550 UART, e.g. on x86 platforms. This patch now introduces a Kconfig option to enable RX buffer support for all DM based serial drivers. With this option enabled, I was able paste really long lines into the U-Boot console, without any characters missing. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2017-08-24Revert "serial: ns16550: Add RX interrupt buffer support"Stefan Roese
This reverts commit 6822cf3ec7c8768b8727573b8f4b2cb3d870b881. As Bin Meng has tested and pointed out, we don't need the RX interrupt for the RX buffer support at all. Just reading all available characters into a buffer is sufficient to solve the problem with the dropped characters upon long lines pasted into the U-Boot prompt. Since this RX buffer support can be implemented in a generic way, without any device specifica (e.g. for the ns16550), I'll post a new patch with a new serial RX buffer support for DM, which all DM based serial drivers can use. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-08-03serial: sh: Convert to KconfigMarek Vasut
Convert the SH Serial to Kconfig using tools/moveconfig.py tool and a bit of manual adjustment to cater for failed conversions. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-07-31serial: stm32x7: Convert CONFIG_STM32X7_SERIAL to KconfigPatrice Chotard
Add CONFIG_STM32X7_SERIAL as a Kconfig option. Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Vikas Manocha <vikas.manocha@st.com>
2017-07-23serial: ns16550: Add RX interrupt buffer supportStefan Roese
Pasting longer lines into the U-Boot console prompt sometimes leads to characters missing. One problem here is the small 16-byte FIFO of the legacy NS16550 UART, e.g. on x86 platforms. This patch now introduces a Kconfig option to enable RX interrupt buffer support for NS16550 style UARTs. With this option enabled, I was able paste really long lines into the U-Boot console, without any characters missing. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> [trini: Guard ns16550_serial_remove with CONFIG_IS_ENABLED(SERIAL_PRESENT) to match struct assignment] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-12serial: mxc: Add debug uart supportJagan Teki
Add support for the debug UART to assist with early debugging. Enable it for i.CoreM6 as an example. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-08powerpc, 8xx: move Serial driver to drivers/serial/Christophe Leroy
At the same time, move to Kconfig Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2017-06-23serial, kconfig: fix menutextHeiko Schocher
fix menutext for the options SPL_DM_SERIAL and TPL_DM_SERIAL. Both have the same text as DM_SERIAL, which is confusing. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Stefan Roese <sr@denx.de>
2017-05-11serial: omap: Support debug UARTLokesh Vutla
Add debug UART functions to permit omap specific ns16550 to provide an early debug UART. This is mostly in common with DEBUG_UART_NS16550 except for Mode definition register which is required for selecting UART mode(16x auto-baud or 13x mode). Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-10serial: add serial driver for BCM6345Álvaro Fernández Rojas
It is based on linux/drivers/tty/serial/bcm63xx_uart.c Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-25sunxi: fix the default value of CONS_INDEX on non-A23/A33 SUN8IIcenowy Zheng
Only A23/A33 in SUN8I want a default value of CONS_INDEX of 5, for other chips the default value is 1 like other Allwinner SoCs. Fix this default value. The original wrong value has lead to wrong console on H3 Orange Pi boards. Fixes: 7095f8641863 ("sunxi: Convert CONS_INDEX to Kconfig") Signed-off-by: Icenowy Zheng <icenowy@aosc.io> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-20sunxi: Convert CONS_INDEX to KconfigMylène Josserand
Convert the CONS_INDEX configuration to Kconfig. Update sunxi's defconfigs to remove SYS_EXTRA_OPTIONS variable not needed anymore. Default value is 1 except for sun5i (equals 2) and sun8i (equals 5). Signed-off-by: Mylène Josserand <mylene.josserand@free-electrons.com> [Maxime: Added a depends on ARCH_SUNXI to avoid build breakages] Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-10serial: Add serial driver for Intel MIDAndy Shevchenko
Add a specific serial driver for Intel MID platforms. It has special fractional divider which can be programmed via UART_PS, UART_MUL, and UART_DIV registers. The UART clock is calculated as UART clock = XTAL * UART_MUL / UART_DIV The baudrate is calculated as baud rate = UART clock / UART_PS / DLAB Initialize fractional divider correctly for Intel Edison platform. For backward compatibility we have to set initial DLAB value to 16 and speed to 115200 baud, where initial frequency is 29491200Hz, and XTAL frequency is 38.4MHz. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2017-04-05dm: serial: Allow driver-model serial to be disabled for TPLSimon Glass
Add separate enable/disable controls for driver-model serial. While this is generally enabled in SPL it may not be in TPL, since serial output can be obtained with the debug UART with minimal code size. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-03-14STiH410: Add STi serial driverPatrice Chotard
This patch adds support to ASC (asynchronous serial controller) driver, which is basically a standard serial driver. This IP is common across other STMicroelectronics SoCs Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-14Kconfig: CONFIG_OF_PLATDATA doesn't really existTom Rini
There is no CONFIG_OF_PLATDATA, only CONFIG_SPL_OF_PLATDATA, so rename the two references to CONFIG_OF_PLATDATA to CONFIG_SPL_OF_PLATDATA. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-16arm: imx: add i.MX53 Beckhoff CX9020 Embedded PCPatrick Bruenn
Add CX9020 board based on mx53loco. Add simplified imx53 base device tree from kernel v4.8-rc8, to reuse serial_mxc with DTE and prepare for device tree migration of other functions and imx53 devices. The CX9020 differs from i.MX53 Quick Start Board by: - use uart2 instead of uart1 - DVI-D connector instead of VGA - no audio - CCAT FPGA connected to emi - enable rtc Signed-off-by: Patrick Bruenn <p.bruenn@beckhoff.com>
2016-11-23serial: pxa: use kconfig for serial configurationMarcel Ziswiler
Migrate the PXA serial driver to be configured via Kconfig. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-10-28Merge branch 'master' of git://git.denx.de/u-boot-atmelTom Rini
2016-10-28serial: atmel_usart: Support enable an early debug UARTWenyou Yang
Add support to enable an early debug UART for debugging. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
2016-10-28serial: Kconfig: Add ATMEL_USART optionWenyou Yang
Add ATMEL_USART option to support to enable the Atmel usart driver from Kconfig. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
2016-10-26serial: Kconfig: Add MXC_UART entryJagan Teki
Added kconfig for MXC_UART driver. Cc: Simon Glass <sjg@chromium.org> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Peng Fan <peng.fan@nxp.com> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-09-27serial: Add serial_mvebu_a3700 for Armada 3700 SoCStefan Roese
The Armada 3700's UART is a simple serial port. It has a 32 bytes Tx FIFO and a 64 bytes Rx FIFO integrated. This patch adds support for this UART including the DEBUG UART functions for very early debug output. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Wilson Ding <dingwei@marvell.com> Cc: Victor Gu <xigu@marvell.com> Cc: Hua Jing <jinghua@marvell.com> Cc: Terry Zhou <bjzhou@marvell.com> Cc: Hanna Hawa <hannah@marvell.com> Cc: Haim Boot <hayim@marvell.com>
2016-08-28ARM: uniphier: change UNIPHIER_SERIAL to default y optionMasahiro Yamada
This is very likely to be necessary for normal use cases. Set its default to 'y' for shorter defconfig files. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-07-14rockchip: serial: Add an of-platdata driver for rockchipSimon Glass
Add a driver that works with of-platdata. It sets up the platform data and calls the standard ns16550 driver. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-27arm: add initial support for Amlogic Meson and ODROID-C2Beniamino Galvani
This adds platform code for the Amlogic Meson GXBaby (S905) SoC and a board definition for ODROID-C2. This initial submission only supports UART and Ethernet (through the existing Designware driver). DTS files are the ones submitted to Linux arm-soc for 4.7 [1]. [1] https://patchwork.ozlabs.org/patch/603583/ Signed-off-by: Beniamino Galvani <b.galvani@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-05-21drivers: serial: add serial driver for ar933x SOCWills Wang
This patch add support for ar933x serial. Signed-off-by: Wills Wang <wills.wang@live.com> Reviewed-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-04-01serial: Add support for Qualcomm serial portMateusz Kulikowski
This driver works in "new" Data Mover UART mode, so will be compatible with modern Qualcomm chips only. Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-03-24ARM: uniphier: support Debug UARTMasahiro Yamada
For ARM32 architecture, CONFIG_DEBUG_LL is available for early low-level debugging (and actually UniPhier 32bit SoCs use it), but ARM64 architecture does not support it. Instead, CONFIG_DEBUG_UART is available as an architecture-independent debug facility. This commit supports it on all the UniPhier SoCs (including the new ARMv8 SoCs), which is very useful for new SoC bringups. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-02-25serial: dcc: Move driver to DMMichal Simek
Enabling this driver requires some DT changes. Adding DCC to root or main bus: dcc: dcc { compatible = "arm,dcc"; u-boot,dm-pre-reloc; }; Extend alias list to link DCC: serial0 = &uart0; serial1 = &uart1; serial2 = &dcc; Change stdout-path to point to dcc port. stdout-path = "serial2:115200n8"; Also add support for debug uart to help with early debug. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-02-01drivers: serial: add driver for Microchip PIC32 UART controller.Paul Thacker
This adds PIC32 UART controller support based on driver model. Signed-off-by: Paul Thacker <paul.thacker@microchip.com> Signed-off-by: Purna Chandra Mandal <purna.mandal@microchip.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-01-27ppc: xilinx-ppc4xx: Port to DM serialRicardo Ribalda Delgado
xilinx_uartlite has been ported to DM, this patch makes the xilinx-ppc405-generic and the xilinx-ppc440-generic boards use the new DM driver. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27serial: uartlite: Add uartlite to KconfigMichal Simek
- Move config option out of board file. - Remove uartlite address from config file Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Thomas Chou <thomas@wytron.com.tw>
2016-01-27serial: uartlite: Add support for debug consoleMichal Simek
Add support for debug console. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Thomas Chou <thomas@wytron.com.tw>
2016-01-20serial: lpuart: Move CONFIG_FSL_LPUART to KconfigBin Meng
LPUART is seen on Freescale VF610 and QorIQ Layerscape devices. Create a Kconfig option and move it to defconfig for all boards that have this serial driver. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-01-19arm: serial: Add Kconfig entries to facilitate usage of the pl01x driver for ↵Sergey Temerkhanov
early debug output This patch adds Kconfig entries to facilitate usage of pl01x as a debug UART. Signed-off-by: Sergey Temerkhanov <s.temerkhanov@gmail.com> Signed-off-by: Radha Mohan Chintakuntla <rchintakuntla@cavium.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-01-12dm: serial: Allow the UART driver to be dropped from the imageSimon Glass
In very very space-constrained devices even the full UART driver is too large. In this case the debug UART can still be used in some cases. Add options to enable the UART driver in SPL and U-Boot proper. Enable both options by default. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Thomas Chou <thomas@wytron.com.tw>
2015-12-07serial: zynq: Fix incorrect reference to s5p driverMichal Simek
Remove this c&p error from s5p driver. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
