path: root/drivers/sed13806.c
2007-11-25drivers/video : move video drivers to drivers/videoJean-Christophe PLAGNIOL-VILLARD
2004-08-04* Patch by Martin Krause, 03 Aug 2004:wdenk
change timing for SM501 graphics controller on TQM5200 module * Patch by Mark Jonas, 13 July 2004: - Total5200 LCD now run in little endian mode. Endianess conversion is done in hardware. - Removed last reference to "console" environment variable.
2002-12-03* Fix startup problems with VFD display on TRABLABEL_2002_12_03_2230wdenk
* Patch by Pierre Aubert, 20 Nov 2002 Add driver for Epson SED13806 graphic controller. Add support for BMP logos in cfb_console driver.
