path: root/drivers/scsi/scsi.c
2019-10-23scsi: Add dma direction member to command structureFaiz Abbas
Some SCSI devices like UFS use DMA for executing scsi commands and hence need to know the direction of transfer of the dma. Add a dma_dir element to the command structure to facilitate this. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
2019-10-23scsi: Retry inquiry 3 times to overcome Unit Attention conditionFaiz Abbas
The UFS SCSI device LUNs are observed to return failure the first time a unit ready inquiry is sent and pass on the second try. Send this inquiry 3 times to make sure device is ready. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
2019-10-23scsi: Add max_bytes_per_req to scsi_platdataFaiz Abbas
Add max_bytes_per_req to scsi_platdata to enable the host driver to limit the number of bytes that can be read/written per request. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
2019-10-23scsi: Simplify scsi_read()/_write()Faiz Abbas
With no non-DM driver using scsi_read()/_write() APIs, remove the legacy implementations. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com> [trini: Reorder slightly and mark scsi_read/write behind BLK test to avoid warnings] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-08-11env: Move env_set_ulong() to env.hSimon Glass
Move env_set_ulong() over to the new header file. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-02-19dm: scsi: report correct device numberHeinrich Schuchardt
Before the patch scsi would report the same device number for all SCSI devices, e.g. Device 0: (1:0) Vendor: ATA Prod.: Crucial_CT128M55 Rev: MU01 Type: Hard Disk Capacity: 122104.3 MB = 119.2 GB (250069680 x 512) Device 0: (1:0) Vendor: ATA Prod.: Rev: Type: Hard Disk Capacity: not available With the patch the same device number is reported as is used in scsi_read(): Device 0: (1:0) Vendor: ATA Prod.: Crucial_CT128M55 Rev: MU01 Type: Hard Disk Capacity: 122104.3 MB = 119.2 GB (250069680 x 512) Device 1: (1:0) Vendor: ATA Prod.: Rev: Type: Hard Disk Capacity: not available Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-11-14blk: Call part_init() in the post_probe() methodBin Meng
part_init() is currently called in every DM BLK driver, either in its bind() or probe() method. However we can use the BLK uclass driver's post_probe() method to do it automatically. Update all DM BLK drivers to adopt this change. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-09-10Remove <inttypes.h> includes and PRI* usages in printf() entirelyMasahiro Yamada
In int-ll64.h, we always use the following typedefs: typedef unsigned int u32; typedef unsigned long uintptr_t; typedef unsigned long long u64; This does not need to match to the compiler's <inttypes.h>. Do not include it. The use of PRI* makes the code super-ugly. You can simply use "l" for printing uintptr_t, "ll" for u64, and no modifier for u32. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-09-11blk: dm: make blk_create_device() take a number of block instead of a sizeJean-Jacques Hiblot
There is an overflow problem when taking the size instead of the number of blocks in blk_create_device(). This results in a wrong device size: the device apparent size is its real size modulo 4GB. Using the number of blocks instead of the device size fixes the problem and is more coherent with the internals of the block layer. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename common functions related to setenv()Simon Glass
We are now using an env_ prefix for environment functions. Rename these commonly used functions, for consistency. Also add function comments in common.h. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-01dm: mmc: Allow disabling driver model in SPLSimon Glass
At present if U-Boot proper uses driver model for MMC, then SPL has to also. While this is desirable, it places a significant barrier to moving to driver model in some cases. For example, with a space-constrained SPL it may be necessary to enable CONFIG_SPL_OF_PLATDATA which involves adjusting some drivers. Add new SPL versions of the options for DM_MMC, DM_MMC_OPS and BLK. By default these follow their non-SPL versions, but this can be changed by boards which need it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-11dm: scsi: Drop scsi_init() when driver model is usedSimon Glass
This function should not be used with driver model. Update the code to reflect this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11dm: scsi: Split out the bus scanning codeSimon Glass
Split out the code that scans a single SCSI bus into a separate function. This will allow it to be used from driver model. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11dm: scsi: Adjust return value of scsi_exec()Simon Glass
Change this function to return an error number instead of true/false. This allows us to return a proper error number. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11dm: scsi: Document and rename the scsi_scan() parameterSimon Glass
The 'mode' parameter is actually a flag to determine whether to display a list of devices found during the scan. Rename it to reflect this, add a function comment and adjust callers to use a boolean. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11dm: scsi: Add a device pointer to scan_exec(), scsi_bus_reset()Simon Glass
With driver model these functions need a device pointer. Add one even when CONFIG_DM_SCSI is not defined. This avoids having ugly conditional function prototypes, When CONFIG_DM_SCSI is not defined we can just ignore the pointer. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11dm: scsi: Indent the confusing #ifdefsSimon Glass
These are very confusing without some sort of indentation. At some point we will be able to remove them, but for now, indent them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11dm: scsi: Use the uclass platform dataSimon Glass
At present the two driver-model SCSI drivers use device platform data to store information that relates to the uclass. It is better to use uclass platform data in this situation. Update the code to do this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11dm: scsi: Drop the ccb typedefSimon Glass
We should not be using typedefs in U-Boot and 'ccb' is a pretty short name. It is also used with variables. Drop the typedef and use 'struct' instead. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11scsi: Move drivers into new drivers/scsi directorySimon Glass
At present we have the SCSI drivers in the drivers/block and common/ directories. It is better to split them out into their own place. Use drivers/scsi which is what Linux does. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
