path: root/drivers/rtc
2013-04-01Consolidate bool typeYork Sun
'bool' is defined in random places. This patch consolidates them into a single header file include/linux/types.h, using stdbool.h introduced in C99. All other #define, typedef and enum are removed. They are all consistent with true = 1, false = 0. Replace FALSE, False with false. Replace TRUE, True with true. Skip *.py, *.php, lib/* files. Signed-off-by: York Sun <yorksun@freescale.com>
2013-03-11ppc: Remove PCIPPC2 and PCIPPC6 boardsStefan Roese
These boards seem to be unmaintained for quite some time. So lets remove support for them completely. This also cleans up some common drivers/files. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Guillaume Alexandre <guillaume.alexandre@gespac.ch> Acked-by: Wolfgang Denk <wd@denx.de>
2012-11-14pmic: Extend PMIC framework to support multiple instances of PMIC devicesŁukasz Majewski
The PMIC framework has been extended to support multiple instances of the variety of devices responsible for power management. This change allows supporting of e.g. fuel gauge, charger, MUIC (Micro USB Interface Circuit). Power related includes have been moved to ./include/power directory. This is a first of a series of patches - in the future "pmic" will be replaced with "power". Two important issues: 1. The PMIC needs to be initialized just after malloc is configured 2. It uses list to hold information about available PMIC devices Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Stefano Babic <sbabic@denx.de>
2012-09-02rtc: pcf8563: Make century compatible with LinuxBenoît Thébaudeau
This driver uses the century bit of this RTC in the opposite way Linux does. From Linux's rtc-pcf8563.c: /* * The meaning of MO_C bit varies by the chip type. * From PCF8563 datasheet: this bit is toggled when the years * register overflows from 99 to 00 * 0 indicates the century is 20xx * 1 indicates the century is 19xx * From RTC8564 datasheet: this bit indicates change of * century. When the year digit data overflows from 99 to 00, * this bit is set. By presetting it to 0 while still in the * 20th century, it will be set in year 2000, ... * There seems no reliable way to know how the system use this * bit. So let's do it heuristically, assuming we are live in * 1970...2069. */ As U-Boot's PCF8563 driver does not say it is supposed to support the RTC8564, make this driver compatible with Linux's by giving the opposite meaning to the century bit. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Wolfgang Denk <wd@denx.de>
2012-09-01rtc: add support of mx27 rtctrem
This driver has been tested on board armadeus apf27. Signed-off-by: Philippe Reynes <tremyfr@yahoo.fr> Acked-by: Stefano Babic <sbabic@denx.de>
2012-09-01mxs: Convert sys_proto.h prefixes to 'mxs'Otavio Salvador
The sys_proto.h functions (except the boot modes) are compatible with i.MX233 and i.MX28 so we use 'mxs' prefix for its methods. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2012-09-01rtc: imxdi: Initial supportBenoît Thébaudeau
Add support for Freescale's i.MX DryIce RTC, present on i.MX25. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2012-09-01mxs: prefix register structs with 'mxs' prefixOtavio Salvador
2012-08-10Add support for DS1388.Kenth Eriksson
Support for DS1388 is added by extending the DS1337 driver. DS1388 is similar to DS1337. The time registers are offset by 1 (due to support for hundreds of seconds), and there is no century bit. The configuration and trickle charge registers are also different. Tested on hardware with Freescale P2010 and DS1388. Signed-off-by: Kenth Eriksson <kenth.eriksson@transmode.com>
2012-07-07rtc/m41t62: Add support for M41T82 with HT (Halt Update)Stefan Roese
Add support for the M41T82 RTC to the m41t62 driver. The only difference that needs to be handled by this driver, is to clear the HT (Halt Update) bit upon reset. This bit is not used on the M41T62, so its save to clear this bit always. The M41T82 support will be used by the X600 (SPEAr600) board support. Signed-off-by: Stefan Roese <sr@denx.de>
2011-12-06arm, davinci: move davinci_rtc struct to hardware.hHeiko Schocher
move struct davinci_rtc to arch/arm/include/asm/arch-davinci/hardware.h and add RTC_KICK0R_WE, RTC_KICK1R_WE defines, so they are global useable. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-16drivers/rtc/s3c24x0_rtc.c: fix GCC 4.6 warningsAnatolij Gustschin
Fix: s3c24x0_rtc.c: In function 'rtc_get': s3c24x0_rtc.c:67:53: warning: variable 'a_armed' set but not used s3c24x0_rtc.c:67:45: warning: variable 'a_year' set but not used s3c24x0_rtc.c:67:38: warning: variable 'a_mon' set but not used s3c24x0_rtc.c:67:30: warning: variable 'a_date' set but not used s3c24x0_rtc.c:67:22: warning: variable 'a_hour' set but not used s3c24x0_rtc.c:67:15: warning: variable 'a_min' set but not used s3c24x0_rtc.c:67:8: warning: variable 'a_sec' set but not used [-Wunused-but-set-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-11-11iMX28: Add driver for internal RTCMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2011-11-08Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: Arm: re-introduce the MACH_TYPE_XXXXXX for EB_CPUX9K2 board arm: jadecpu: Readd MACH_TYPE_JADECPU at91: defined mach-types for otc570 board in board config file at91: defined mach-types for meesc board in board config file mx31pdk: Enable D and I caches ehci-mxc: remove incorrect comment README: Fix supported i.MX SoC list for CONFIG_MXC_SPI mx53: Turn off child clocks before reconfigure perclk_root qong: enable support for compressed images imx: imx31_phycore.h: fix checkpatch warnings vision2: Remove unused get_board_rev function mx53smd: Remove unused get_board_rev function mx53ard: Remove unused get_board_rev function mx53evk: Remove unused get_board_rev function mx53evk: Add RTC support mx53loco: Remove unused get_board_rev function mx53evk: Remove unneeded '1' from mx53evk.h OMAP3: mvblx: Initial support for mvBlueLYNX-X ARM: dig297: Define MACH_TYPE_OMAP3_CPS and CONFIG_MACH_TYPE omap3: mem: Move comments next to definitions omap3: mem: Clean-up whitespaces omap3: mem: Define and use common macros Davinci: ea20: added PREBOOT to configuration Davinci: ea20: added I2C support Davinci: ea20: added video support VIDEO: davinci: add framebuffer to da8xx ARM: Davinci: added missing registers to hardware.h Davinci: ea20: add gpios for LCD backlight control Davinci: ea20: add gpio for keeping power on in board_late_init Davinci: ea20: Add default U-Boot environment Davinci: ea20: Add early init to get early output from console Davinci: ea20: Add NAND support Davinci: ea20: set GPIOs to hold MII-Phy in reset and set UART0-Switch for console Davinci: ea20: set console on UART0 arm, davinci: add cam_enc_4xx support arm926ejs, davinci: add missing spi defines for dm365 arm926ejs, davinci: add cpuinfo for dm365 arm, davinci: add lowlevel function for dm365 soc arm, davinci: add header files for dm365 spl, nand: add 4bit HW ecc oob first nand_read_page function arm, davinci: add support for new spl framework spl: add option for adding post memory test to the SPL framework net, davinci_emac: make clock divider in MDIO control register configurable arm, usb, davinci: make USBPHY_CTL register configurable usb, davinci: add enable_vbus() weak function omap3evm: fix errors caused by multiple definitions omap3evm: Add (quick) configuration for NAND only omap3evm: Add (quick) configuration for MMC/SD only omap3evm: move common config options to new file omap3evm: Prepare to split configuration omap3evm: Reorder related config options omap/spl: actually enable the console davinci_emac: compilation fix, phy is array now omap3evm: Set environment variable 'ethaddr' arm, arm926: fix missing symbols in NAND_SPL mode arm, davinci: Add function lpsc_syncreset() arm, davinci: replace CONFIG_PRELOADER with CONFIG_SPL_BUILD arm/km: portl2 environment address update to P1B arm/km: adapt bootcounter evaluation arm/km: enable jffs2 cmds arm/km: trigger reconfiguration for the Xilinx FPGA arm/km: add boardid and hwkey to kernel command line ARM: Reintroduce MACH_TYPE_KM_KIRKWOOD for keymile ARM boards netspace_v2: enable I2C EEPROM support netspace_v2: fix SDRAM configuration armada100: define CONFIG_SYS_CACHELINE_SIZE pantheon: define CONFIG_SYS_CACHELINE_SIZE kirkwood: define CONFIG_SYS_CACHELINE_SIZE kirkwood: drop empty asm-offsets.s file arm/km/mgcoge3un: enhance "waitforne" feature arm/km: add variable waitforne to mgcoge3un gplugD: Fix for error:MACH_TYPE_SHEEVAD undeclared ARM: dreamplug: fix compilation ARM: DockStar: fix compilation ARM: netspace_v2: fix warnings am335x: Drop board_sysinfo struct am335x: Temporarily add MACH_TYPE define misc:pmic:samsung Enable PMIC driver at C210 Universal target dcache:s5p CONFIG_SYS_CACHELINE_SIZE added for s5p UNIVERSAL C210 target dcache:s5p CONFIG_SYS_CACHELINE_SIZE added for s5p GONI target smdkv310: use macro for mmc data read function address smdkv310: use spl framework for mmc spl SMDKV310: use get_ram_size() to validate dram size SMDKV310: Initialize board id using CONFIG_MACH_TYPE ORIGEN : use absolute paths and fix tool naming ORIGEN : enable device tree support MX25: tx25: Fix building due to missing MACH_TYPE mx31: Add board support for HALE TT-01 mx31: add ESD control registers mx31: define pins and init for UART2 and CSPI3 MX35: add support for flea3 board MX51: vision2: add MACH_TYPE in config file vision2: Remove unused header file mx51evk: Remove unused get_board_rev function mx51evk: Remove unneeded '1' from mx51evk.h I2C: Fix mxc_i2c.c problem on imx31_phycore mx35pdk: Add RTC support mx51evk: Use GPIO API for configuring the IOMUX mx51evk: Add RTC support rtc: Make mc13783-rtc driver generic qong: remove unneeded IOMUX settings qong: Use mx31_set_gpr to setup USBH2 pins mx31: Introduce mx31_set_gpr function mx31pdk: Add MC13783 PMIC support qong: remove unneeded "1" from qong.h misc: pmic: fix regression in pmic_fsl.c (SPI) mx5 configs: CONFIG_PRIME should really be CONFIG_ETHPRIME MX35: Drop unnecessary prototypes from imx-regs.h I2C: added I2C-2 and I2C-3 to MX35 MX35: factorize common assembly code MX35: add reset cause as provided by other i.MX MX35: add pins definition for UART3 MX35: added ESDC structure to imx-regs
2011-11-07drivers/rtc/rv3029.c: fix GCC 4.6 build warningsWolfgang Denk
Fix: rv3029.c: In function 'rtc_set': rv3029.c:98:6: warning: variable 'ret' set but not used [-Wunused-but-set-variable] rv3029.c: In function 'set_eere_bit': rv3029.c:131:6: warning: variable 'ret' set but not used [-Wunused-but-set-variable] rv3029.c: In function 'wait_eebusy': rv3029.c:149:9: warning: variable 'ret' set but not used [-Wunused-but-set-variable] rv3029.c: In function 'rtc_reset': rv3029.c:165:6: warning: variable 'ret' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-11-07drivers/rtc/ds3231.c: fix GCC 4.6 build warningsWolfgang Denk
Fix: ds3231.c: In function 'rtc_get': ds3231.c:90:52: warning: variable 'control' set but not used [-Wunused-but-set-variable] Fix is done by switching to standard debug() instead of custom macro. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-11-03ARM: dreamplug: fix compilationAnatolij Gustschin
Fix build issues: mvrtc.c: In function 'rtc_get': mvrtc.c:45: warning: implicit declaration of function 'readl' mvrtc.c: In function 'rtc_set': mvrtc.c:100: warning: implicit declaration of function 'writel' dreamplug.c: In function 'board_early_init_f': dreamplug.c:43: warning: implicit declaration of function 'kw_config_gpio' dreamplug.c: In function 'board_init': dreamplug.c:108: warning: implicit declaration of function 'kw_sdram_bar' drivers/rtc/librtc.o: In function `rtc_set': /home/ag/u-boot/u-boot-move-new-host/u-boot-video/drivers/rtc/mvrtc.c:92: undefined reference to `writel' /home/ag/u-boot/u-boot-move-new-host/u-boot-video/drivers/rtc/mvrtc.c:103: undefined reference to `writel' drivers/rtc/librtc.o: In function `rtc_reset': /home/ag/u-boot/u-boot-move-new-host/u-boot-video/drivers/rtc/mvrtc.c:117: undefined reference to `readl' /home/ag/u-boot/u-boot-move-new-host/u-boot-video/drivers/rtc/mvrtc.c:120: undefined reference to `readl' drivers/rtc/librtc.o: In function `rtc_get': /home/ag/u-boot/u-boot-move-new-host/u-boot-video/drivers/rtc/mvrtc.c:45: undefined reference to `readl' /home/ag/u-boot/u-boot-move-new-host/u-boot-video/drivers/rtc/mvrtc.c:48: undefined reference to `readl' ... Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Jason Cooper <u-boot@lakedaemon.net> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2011-11-03rtc: Make mc13783-rtc driver genericFabio Estevam
Rename mc13783-rtc so that it can be used for both MC13783 and MC13892 PMICs. efikamx board, for example, does use a MC13892 PMIC, but the RTC selection is currently made as: #define CONFIG_RTC_MC13783 ,which is not very obvious. Let the MC13783 and MC13892 RTC be selected by: #define CONFIG_RTC_MC13XXX Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2011-11-03drivers/rtc/ds1337.c: fix GCC 4.6 build warningsWolfgang Denk
Fix: ds1337.c: In function 'rtc_get': ds1337.c:88:52: warning: variable 'control' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-10-27RTC: Switch mc13783 to generic pmic codeStefano Babic
2011-09-30rtc, davinci: add support for davinci internal RTCHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Paulraj Sandeep <s-paulraj@ti.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-08-04Convert ISO-8859 files to UTF-8Albert ARIBAUD
There was a mix of UTF-8 and ISO-8859 files in the U-Boot source tree, which could cause issues with the patchwork review system. This commit converts all ISO-8859 files to UTF-8. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-08-04drivers/rtc: add Marvell Integrated RTCJason Cooper
This driver can be used for kirkwood SoCs by enabling CONFIG_RTC_MV. Tested on Global Scale Technologies Dreamplug. Signed-off-by: Jason Cooper <u-boot@lakedaemon.net>
2011-07-28cleanup: Fix typos and misspellings in various files.Mike Williams
Recieve/Receive recieve/receive Interupt/Interrupt interupt/interrupt Addres/Address addres/address Signed-off-by: Mike Williams <mike@mikebwilliams.com>
2011-05-18AT91: change includes from asm/arch/io.h to asm/io.hReinhard Meyer
and remove the now unused asm/arch-at91/io.h Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-05-18AT91: fix related at91 driver filesReinhard Meyer
2011-04-26rtc, rv3029: add trickle charger support.Heiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2011-02-12eNET: Add RTC support to eNETGraeme Russ
The SC520 has an inbuilt MC146818 - Enable it for the eNET board
2011-01-18rtc: add support for Micro Crystal RV-3029-C2 RTCHeiko Schocher
2010-12-17RTC driver for PT7C4338 chip.Priyanka Jain
PT7C4338 chip is being manufactured by Pericom Technology Inc. It is a serial real-time clock which provides: 1)Low-power clock/calendar. 2)Programmable square-wave output. It has 56 bytes of nonvolatile RAM. Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Acked-by: Timur Tabi <timur@freescale.com>
2010-10-29Merge branch 'master' of git://git.denx.de/u-boot-samsungWolfgang Denk
2010-10-28Add generic support for samsung s3c2440C Nauman
This patch adds generic support for the Samsung s3c2440 processor. Global s3c24x0 changes to struct members converting from upper case to lower case. Signed-off-by: Craig Nauman <cnauman@diagraph.com> Cc: kevin.morfitt@fearnside-systems.co.uk Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2010-10-20ftrtc010.c : enhance code according to original datasheetMacpaul Lin
Add missing codes according to original datasheet. This patch also makes ftrtc010 could be adapted to PCLK and EXT_CLK. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2010-09-03AT91: add RTT and GPBR based RTCReinhard Meyer
2010-06-23Remove AmigaOneG3SE boardWolfgang Denk
The AmigaOneG3SE board has been orphaned or a very long time, and broken for more than 12 releases resp. more than 3 years. As nobody seems to be interested any more in this stuff we may as well ged rid of it, especially as it clutters many areas of the code so it is a continuous pain for all kinds of ongoing work. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-05-05MX: RTC13783 uses general function to access PMICStefano Babic
The RTC is part of the Freescale's PMIC controller. Use general function to access to PMIC internal registers. Signed-off-by: Stefano Babic <sbabic@denx.de> Tested-by: Magnus Lilja <lilja.magnus@gmail.com>
2009-12-05Merge branch 'master' into nextWolfgang Denk
Conflicts: board/esd/plu405/plu405.c drivers/rtc/ftrtc010.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-12-02RTC: Fix return code in MC13783 RTC driver.Magnus Lilja
Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
2009-12-02m41t11: Remove unused functionsPeter Tyser
2009-11-27arm: A320: driver for FTRTC010 real time clockPo-Yu Chuang
This patch adds an FTRTC010 driver for Faraday A320 evaluation board. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2009-11-27Add a unified s3c24x0 header filekevin.morfitt@fearnside-systems.co.uk
This patch adds a unified s3c24x0 cpu header file that selects the header file for the specific s3c24x0 cpu from the SOC and CPU configs defined in board config file. This removes the current chain of s3c24-type #ifdef's from the s3c24x0 code. Signed-off-by: Kevin Morfitt <kevin.morfitt@fearnside-systems.co.uk> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-11-27Move s3c24x0 header files to asm-arm/arch-s3c24x0/kevin.morfitt@fearnside-systems.co.uk
This patch moves the s3c24x0 header files from include/ to include/asm-arm/arch-s3c24x0/. checkpatch.pl showed 2 errors and 3 warnings. The 2 errors were both due to a non-UTF8 character in David M?ller's name: ERROR: Invalid UTF-8, patch and commit message should be encoded in UTF-8 #489: FILE: include/asm-arm/arch-s3c24x0/s3c2410.h:3: + * David M?ller ELSOFT AG Switzerland. d.mueller@elsoft.ch As David's name correctly contains a non-UTF8 character I haven't fixed these errors. The 3 warnings were all because of the use of 'volatile' in s3c24x0.h: WARNING: Use of volatile is usually wrong: see Documentation/volatile-considered-harmful.txt #673: FILE: include/asm-arm/arch-s3c24x0/s3c24x0.h:35: +typedef volatile u8 S3C24X0_REG8; +typedef volatile u16 S3C24X0_REG16; +typedef volatile u32 S3C24X0_REG32; I'll fix these errors in another patch. Tested by running MAKEALL for ARM8 targets and ensuring there were no new errors or warnings. Signed-off-by: Kevin Morfitt <kevin.morfitt@fearnside-systems.co.uk> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-11-27Fix for Void function returning value in sbc35-a9g20Sandeep Paulraj
Void function was returning 0 in the m41t94 rtc driver. This makes it similar to m41t62 rtc driver. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-11-22Add driver for FTRTC010 real time clockPo-Yu Chuang
Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-10-13Clean-up of s3c24x0 drivers excluding nand driverkevin.morfitt@fearnside-systems.co.uk
This patch re-formats the arm920t s3c24x0 driver files, excluding the nand driver, in preparation for changes to add support for the Embest SBC2440-II Board. The changes are as follows: - re-indent the code using Lindent - make sure register layouts are defined using a C struct - replace the upper-case typedef'ed C struct names with lower case non-typedef'ed ones - make sure registers are accessed using the proper accessor functions - run checkpatch.pl and fix any error reports It assumes the following patch has been applied first: - [U-Boot][PATCH-ARM] CONFIG_SYS_HZ fix for ARM902T S3C24X0 Boards, 05/09/2009 - patches 1/4 and 2/4 of this series Tested on an Embest SBC2440-II Board with local u-boot patches as I don't have any s3c2400 or s3c2410 boards but need this patch applying before I can submit patches for the SBC2440-II Board. Also, temporarily modified sbc2410x, smdk2400, smdk2410 and trab configs to use the mtd nand driver (which isn't used by any board at the moment), ran MAKEALL for all ARM9 targets and no new warnings or errors were found. Signed-off-by: Kevin Morfitt <kevin.morfitt@fearnside-systems.co.uk> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-09-24rtc/ds1337.c: Allow to set TCR registerWerner Pfister
This is needed to correctly start the charging of an attached capacitor or battery. Signed-off-by: Werner Pfister <werner.pfister@intercontrol.de> Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-08-25Add driver for the ST M41T94 SPI RTCAlbin Tonnerre
This RTC is used in some Calao boards. The driver code is taken from the linux rtc-m41t94 driver Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com>
2009-08-25Switch from per-driver to common definition of bin2bcd and bcd2binAlbin Tonnerre
Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Acked-by: Stefan Roese <sr@denx.de>
2009-08-25Replace BCD2BIN and BIN2BCD macros with inline functionsAlbin Tonnerre
In the process, also remove backward-compatiblity macros BIN_TO_BCD and BCD_TO_BIN and update the sole board using them to use the new bin2bcd and bcd2bin instead Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
