path: root/drivers/rtc
2019-05-31rtc: export rtc_month_days()Heinrich Schuchardt
Export function rtc_month_days() for reuse in the UEFI subsystem. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-04-25rtc: m41t62: add compatible for m41t82Simon Goldschmidt
This adds a compatible string for m41t82. This ensures that this driver can be used for m41t82 in DM mode, too (asit was usable for this model in non-DM mode before). In addition, the HT bit has to be reset during probe, since the m41t82 chip sets it when entering battery standby mode. This patch ensures this driver works on socfpga_socrates. Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de>
2018-12-03rtc: m41t62: Convert the RTC driver to support the driver model (DM)Lukasz Majewski
After this change the m41t62.c can be used with RTC subsystem (i.e. date command) which uses device model (DM). Signed-off-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Stefan Roese <sr@denx.de>
2018-12-03rtc: m41t62: Extract common RTC handling code to facilitate DM conversionLukasz Majewski
This change facilitates the conversion of m41t62 RTC driver to device model (DM). Signed-off-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Stefan Roese <sr@denx.de>
2018-12-03rtc: m41t62: Break i2c_write() arguments to fix checkpatch warningLukasz Majewski
No functional change for this commit. Signed-off-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Stefan Roese <sr@denx.de>
2018-12-03Kconfig: Migrate CONFIG_RTC_M41T62 define to KconfigLukasz Majewski
This patch moves the RTC M41T62 config define to Kconfig. Signed-off-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-12-01drivers: rtc: correctly convert seconds to time structureHeinrich Schuchardt
Variable 'days' must be defined as signed int. Otherwise the conversion fails for some dates, e.g. 2004-08-25. Cf function rtc_time64_to_tm() in the Linux kernel source. Fixes: 992c1db45591 "drivers: rtc: resolve year 2038 problem in rtc_to_tm" Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-12-01Merge tag 'for-master-20181130' of git://git.denx.de/u-boot-rockchipTom Rini
Improvements: - RK3188 USB-UART functionality - errors triggering a hard-stop in SPL on the RK3399 are reported - Rockchip RV1108 (SoC) support - MicroCrystal RV3029 (RTC) DM driver Fixes: - RK3188 early UART setup - limit SD-card frequency to 40MHz on the RK3399-Q7 - MIPI fixes - RK3399 CPUB clock initialisation
2018-11-30rtc: rv3029: update to support DM and sync with Linux 4.17Philipp Tomsich
The "Flamingo" carrier-board for the RK3399-Q7 has a RV3029 populated and the application will use the off-module RV3029 RTC including the battery backed SRAM. To support this use case, this commit includes the following changes: * updates the rv3029 driver to use DM * implements the read8/write8 operations This syncs the implementation with the Linux code (based on 4.17), porting the trickle-charger support from there (with improvements to avoid unnecessary EEPROM updates) and adheres to the Linux DTS binding. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Tested-by: Klaus Goger <klaus.goger@theobroma-systems.com>
2018-11-30rtc: rv3029: add to KconfigPhilipp Tomsich
The MicroCrystal RV3029 driver didn't have a Kconfig entry and was not used anywhere. Add it to Kconfig to make it selectable. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Tested-by: Klaus Goger <klaus.goger@theobroma-systems.com>
2018-11-29rtc: Allow child driversSimon Glass
Some RTC chips have child drivers, e.g. to provide access to their non-volatile RAM. Scan for these when binding. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-10Merge tag 'dm-9oct18' of git://git.denx.de/u-boot-dmTom Rini
Test improvements to tidy up output and drop duplicate tests Sandbox SPL/TPL support Various dm-related improvements
2018-10-09rtc: Allow use of RTC in SPL and TPLSimon Glass
Add Kconfig options so that the RTC can be used in SPL and TPL. This is helpful for accessing the contents of CMOS RAM, for example. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-09Kconfig: Convert CONFIG_RTC_MC146818 to KconfigSimon Glass
Move this option to Kconfig and tidy up the two boards which use it. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-08rtc: Add read8 and write8 support to isl1208 driverTrent Piepho
This can be used for device register access from board code. This allows access to capabilities in the RTC chip not abstracted in U-Boot's RTC class. E.g., device NVRAM or a tamper detection circuit. Cc: Klaus Goger <klaus.goger@theobroma-systems.com> Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Trent Piepho <tpiepho@impinj.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-09-23rtc: pl031: convert the driver to driver modelAKASHI Takahiro
With this patch, PL031 driver is converted to driver-model-compliant driver. In addition, CONFIG_SYS_RTC_PL031_BASE is no longer valid. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-30Merge tag 'signed-efi-next' of git://github.com/agraf/u-bootTom Rini
Patch queue for efi - 2018-07-25 Highlights this time: - Many small fixes to improve spec compatibility (found by SCT) - Almost enough to run with sandbox target - GetTime() improvements - Enable EFI_LOADER and HYP entry on ARMv7 with NONSEC=y
2018-07-28drivers: rtc: correctly set week day for mc146818Heinrich Schuchardt
The driver sets the weekday incorrectly when called by the 'date set' command. Sunday is 1, Saturday is 7 unlike in U-Boot (see data sheet https://www.nxp.com/docs/en/data-sheet/MC146818.pdf, table 3). Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-07-25rtc: remove CONFIG_CMD_DATE dependencyHeinrich Schuchardt
The EFI subsystem accesses the real time clock and is enabled by default. So we should drop any CONFIG_CMD_DATE dependency from the real time clock drivers. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-24rtc: compile date.c if DM_RTCAKASHI Takahiro
rtc_to_tm() and rtc_mktime() are required for some RTC drivers, at least PL031. Without this patch, we also need to enable CONFIG_CMD_DATE even if we don't want or need this command. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-07-20drivers: rtc: correct week day for mc146818Heinrich Schuchardt
For qemu-x86 the date command produces wrong days of the week: Date: 2018-07-06 (Saturday) Time: 18:02:03 Date: 2018-07-07 (unknown day) Time: 21:02:06 According to a comment in the Linux driver the mc146818 only updates the day of the week if the register value is non-zero. Sunday is 1, saturday is 7 unlike in U-Boot (see data sheet https://www.nxp.com/docs/en/data-sheet/MC146818.pdf). So let's use our library function to determine the day of the week. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-07-19drivers: rtc: resolve year 2038 problem in rtc_to_tmHeinrich Schuchardt
Our implementation of rtc_to_tm() cannot handle dates of more than 0x7fffffff seconds after 1970-01-01. Adopt the Linux kernel implementation. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-07-19ARM: qemu-arm: enable RTCHeinrich Schuchardt
QEMU provides an emulated ARM AMBA PrimeCell PL031 RTC. The patch sets the base address in the board include file according to the definition in hw/arm/virt.c of the QEMU source. It defines the Kconfig option for the existing driver, and enables the RTC driver in qemu_arm64_defconfig and qemu_arm_defconfig as well as the date command. We need an RTC to provide the GetTime() runtime service in the UEFI subsystem. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Tested-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
2018-06-05drivers/rtc: convert mvrtc to DMChris Packham
Add DM support for the Marvell RTC driver. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de>
2018-06-05drivers/rtc: prepare mvrtc for DM conversionChris Packham
Split the rtc_{get,set,reset} functions so that the bodies can be used in a DM driver. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-06rtc: rx8025: remove redundant code in rtc_resetChris Packham
As of commit 1a1fa2406689 ("rtc: Set valid date after reset") the command "date reset" will set the date/time to 2000-01-01 0:00:00 after calling rtc_reset(). This means that the rx8025 implementation of rtc_reset() does not need to call rtc_set(). Signed-off-by: Chris Packham <judge.packham@gmail.com>
2018-04-06rtc: rs5c372: remove redundant code in rtc_resetChris Packham
As of commit 1a1fa2406689 ("rtc: Set valid date after reset") the command "date reset" will set the date/time to 2000-01-01 0:00:00 after calling rtc_reset(). This means that the rs5c372 implementation of rtc_reset() does not need to call rtc_set(). Signed-off-by: Chris Packham <judge.packham@gmail.com>
2018-04-06rtc: mx27rtc: remove redundant code in rtc_resetChris Packham
As of commit 1a1fa2406689 ("rtc: Set valid date after reset") the command "date reset" will set the date/time to 2000-01-01 0:00:00 after calling rtc_reset(). This means that the mx27rtc implementation of rtc_reset() can be an empty stub function. Signed-off-by: Chris Packham <judge.packham@gmail.com>
2018-04-06rtc: ds1374: remove redundant code in rtc_resetChris Packham
As of commit 1a1fa2406689 ("rtc: Set valid date after reset") the command "date reset" will set the date/time to 2000-01-01 0:00:00 after calling rtc_reset(). This means that the ds1374 implementation of rtc_reset() doesn't need to call rtc_set(). Signed-off-by: Chris Packham <judge.packham@gmail.com>
2018-04-06rtc: ds1307: remove redundant code in rtc_resetChris Packham
As of commit 1a1fa2406689 ("rtc: Set valid date after reset") the command "date reset" will set the date/time to 2000-01-01 0:00:00 after calling rtc_reset(). This means that the ds1307 implementation of rtc_reset() doesn't need to call rtc_set(). Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-04-06rtc: rewrite isl1208 to support DMKlaus Goger
Adds devicemodel support to the ISL1208 driver. This patch drops the non-dm API as no board was using it anyway. Also add it to Kconfig. Signed-off-by: Klaus Goger <klaus.goger@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-02-04rtc: adding RX8010SJ rtc driverNandor Han
Add a new driver for RX8010SJ rtc chip. The driver implements both formats of U-Boot driver model. Signed-off-by: Nandor Han <nandor.han@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2017-11-20rtc: add support for s35392aNandor Han
Add support for S35392A RTC. The driver supports both U-Boot driver models. Signed-off-by: Nandor Han <nandor.han@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Cc: Heiko Schocher <hs@denx.de>
2017-10-23rtc: mc146818: Correct alarm message for day alarmBin Meng
RTC_CONFIG_D register contains the day within the month to generate an alarm, not the month. This corrects the printf to indicate it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-16powerpc, 5xxx, 512x: remove support for mpc5xxx and mpc512xHeiko Schocher
There was for long time no activity in the mpx5xxx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in mpc5xxx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-12powerpc, 8xx: remove support for 8xxHeiko Schocher
There was for long time no activity in the 8xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 8xx, so remove it (with a heavy heart, knowing that I remove here the root of U-Boot). Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-09rtc: ds1337: drop "SYS" from config variablesChris Packham
There is some inconsistency between uses of CONFIG_RTC_DS13xx and CONFIG_SYS_RTC_DS13xx. Address this by dropping the "SYS" from these variables. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: sandbox: i2c_rtc: Drop fdtdec.h headerSimon Glass
This is not needed in this driver. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Drop three-wire serial (TWS) supportSimon Glass
This subsystem has not been converted to driver model, there is only one driver and only one board that uses it. Drop it and its CONFIG option. Also drop the rtc4543 RTC driver since it uses TWS. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-08rtc: Add DM support to ds1307Chris Packham
Add an implementation of the ds1307 driver that uses the driver model i2c APIs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-18drivers: remove Blackfin specific driversMasahiro Yamada
These drivers have no user since commit ea3310e8aafa ("Blackfin: Remove"). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
2017-04-10dm: rtc: Add 16-bit read/write supportBin Meng
At present there are only 8-bit and 32-bit read/write routines in the rtc uclass driver. This adds the 16-bit support. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-14rtc: pcf2127: Update Kconfig and code styleMeng Yi
Unfortunately version 2 of this patch was applied which was missing some changes. Fix this. Signed-off-by: Meng Yi <meng.yi@nxp.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2016-12-02rtc: Add RTC chip pcf2127 supportMeng Yi
This driver compatible with pcf2127 and pcf2129 Signed-off-by: Meng Yi <meng.yi@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-11rtc: Use CONFIG_X86 instead of __I386__Simon Glass
For 64-bit x86, __I386__ should perhaps not be defined. It is not clear from the definition, but let's use CONFIG_X86 to be sure. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-09-23drivers: squash lines for immediate returnMasahiro Yamada
Remove unneeded variables and assignments. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
