path: root/drivers/rtc
2011-01-18rtc: add support for Micro Crystal RV-3029-C2 RTCHeiko Schocher
2010-12-17RTC driver for PT7C4338 chip.Priyanka Jain
PT7C4338 chip is being manufactured by Pericom Technology Inc. It is a serial real-time clock which provides: 1)Low-power clock/calendar. 2)Programmable square-wave output. It has 56 bytes of nonvolatile RAM. Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Acked-by: Timur Tabi <timur@freescale.com>
2010-10-29Merge branch 'master' of git://git.denx.de/u-boot-samsungWolfgang Denk
2010-10-28Add generic support for samsung s3c2440C Nauman
This patch adds generic support for the Samsung s3c2440 processor. Global s3c24x0 changes to struct members converting from upper case to lower case. Signed-off-by: Craig Nauman <cnauman@diagraph.com> Cc: kevin.morfitt@fearnside-systems.co.uk Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2010-10-20ftrtc010.c : enhance code according to original datasheetMacpaul Lin
Add missing codes according to original datasheet. This patch also makes ftrtc010 could be adapted to PCLK and EXT_CLK. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2010-09-03AT91: add RTT and GPBR based RTCReinhard Meyer
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-06-23Remove AmigaOneG3SE boardWolfgang Denk
The AmigaOneG3SE board has been orphaned or a very long time, and broken for more than 12 releases resp. more than 3 years. As nobody seems to be interested any more in this stuff we may as well ged rid of it, especially as it clutters many areas of the code so it is a continuous pain for all kinds of ongoing work. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-05-05MX: RTC13783 uses general function to access PMICStefano Babic
The RTC is part of the Freescale's PMIC controller. Use general function to access to PMIC internal registers. Signed-off-by: Stefano Babic <sbabic@denx.de> Tested-by: Magnus Lilja <lilja.magnus@gmail.com>
2009-12-05Merge branch 'master' into nextWolfgang Denk
Conflicts: board/esd/plu405/plu405.c drivers/rtc/ftrtc010.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-12-02RTC: Fix return code in MC13783 RTC driver.Magnus Lilja
Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
2009-12-02m41t11: Remove unused functionsPeter Tyser
2009-11-27arm: A320: driver for FTRTC010 real time clockPo-Yu Chuang
This patch adds an FTRTC010 driver for Faraday A320 evaluation board. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2009-11-27Add a unified s3c24x0 header filekevin.morfitt@fearnside-systems.co.uk
This patch adds a unified s3c24x0 cpu header file that selects the header file for the specific s3c24x0 cpu from the SOC and CPU configs defined in board config file. This removes the current chain of s3c24-type #ifdef's from the s3c24x0 code. Signed-off-by: Kevin Morfitt <kevin.morfitt@fearnside-systems.co.uk> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-11-27Move s3c24x0 header files to asm-arm/arch-s3c24x0/kevin.morfitt@fearnside-systems.co.uk
This patch moves the s3c24x0 header files from include/ to include/asm-arm/arch-s3c24x0/. checkpatch.pl showed 2 errors and 3 warnings. The 2 errors were both due to a non-UTF8 character in David M?ller's name: ERROR: Invalid UTF-8, patch and commit message should be encoded in UTF-8 #489: FILE: include/asm-arm/arch-s3c24x0/s3c2410.h:3: + * David M?ller ELSOFT AG Switzerland. d.mueller@elsoft.ch As David's name correctly contains a non-UTF8 character I haven't fixed these errors. The 3 warnings were all because of the use of 'volatile' in s3c24x0.h: WARNING: Use of volatile is usually wrong: see Documentation/volatile-considered-harmful.txt #673: FILE: include/asm-arm/arch-s3c24x0/s3c24x0.h:35: +typedef volatile u8 S3C24X0_REG8; +typedef volatile u16 S3C24X0_REG16; +typedef volatile u32 S3C24X0_REG32; I'll fix these errors in another patch. Tested by running MAKEALL for ARM8 targets and ensuring there were no new errors or warnings. Signed-off-by: Kevin Morfitt <kevin.morfitt@fearnside-systems.co.uk> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-11-27Fix for Void function returning value in sbc35-a9g20Sandeep Paulraj
Void function was returning 0 in the m41t94 rtc driver. This makes it similar to m41t62 rtc driver. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-11-22Add driver for FTRTC010 real time clockPo-Yu Chuang
Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-10-13Clean-up of s3c24x0 drivers excluding nand driverkevin.morfitt@fearnside-systems.co.uk
This patch re-formats the arm920t s3c24x0 driver files, excluding the nand driver, in preparation for changes to add support for the Embest SBC2440-II Board. The changes are as follows: - re-indent the code using Lindent - make sure register layouts are defined using a C struct - replace the upper-case typedef'ed C struct names with lower case non-typedef'ed ones - make sure registers are accessed using the proper accessor functions - run checkpatch.pl and fix any error reports It assumes the following patch has been applied first: - [U-Boot][PATCH-ARM] CONFIG_SYS_HZ fix for ARM902T S3C24X0 Boards, 05/09/2009 - patches 1/4 and 2/4 of this series Tested on an Embest SBC2440-II Board with local u-boot patches as I don't have any s3c2400 or s3c2410 boards but need this patch applying before I can submit patches for the SBC2440-II Board. Also, temporarily modified sbc2410x, smdk2400, smdk2410 and trab configs to use the mtd nand driver (which isn't used by any board at the moment), ran MAKEALL for all ARM9 targets and no new warnings or errors were found. Signed-off-by: Kevin Morfitt <kevin.morfitt@fearnside-systems.co.uk> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-09-24rtc/ds1337.c: Allow to set TCR registerWerner Pfister
This is needed to correctly start the charging of an attached capacitor or battery. Signed-off-by: Werner Pfister <werner.pfister@intercontrol.de> Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-08-25Add driver for the ST M41T94 SPI RTCAlbin Tonnerre
This RTC is used in some Calao boards. The driver code is taken from the linux rtc-m41t94 driver Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com>
2009-08-25Switch from per-driver to common definition of bin2bcd and bcd2binAlbin Tonnerre
Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Acked-by: Stefan Roese <sr@denx.de>
2009-08-25Replace BCD2BIN and BIN2BCD macros with inline functionsAlbin Tonnerre
In the process, also remove backward-compatiblity macros BIN_TO_BCD and BCD_TO_BIN and update the sole board using them to use the new bin2bcd and bcd2bin instead Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2009-04-05Update CHANGELOG, coding style cleanup.Wolfgang Denk
2009-04-02Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2009-03-30rtc: add support for 4543 RTC (manufactured by e.g. EPSON)Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de> Signed-off-by: Andreas Pfefferle <ap@denx.de>
2009-03-29s3c44b0: move rtc driver to drivers/rtcJean-Christophe PLAGNIOL-VILLARD
2008-10-23Blackfin: only initialize the RTC when actually usedMike Frysinger
2008-09-12i.MX31: Make the SPI bus and chip select configurable for MC13783Magnus Lilja
The i.MX31 has three SPI buses and each bus has several chip selects and the MC13783 chip can be connected to any of these. The current RTC driver for MC13783 is hardcoded for CSPI2/SS2. This patch makes make MC13783 SPI bus and chip select configurable via CONFIG_MC13783_SPI_BUS and CONFIG_MC13783_SPI_CS. Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
2008-09-09Makefile: fix bug introduced by commit 47ffd6c2Wolfgang Denk
2008-09-09Makefile: compile and link each module just onceWolfgang Denk
Several source files need to be compiled and linked when one or more config options are selected. To allow for easy selection in the Makefiles yet to avoild multiple compilation (which costs build time) and especially multiple linking (which causes errors), we use "COBJS = $(sort COBJS-y)" which eliminates duplicates. By courtesy of Detlev Zundel who suggested this approach. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-09-09rs5c372: fix rtc_set prototypeJean-Christophe PLAGNIOL-VILLARD
2008-09-08mk48t59: fix compile problem introduced by commit d1e23194Wolfgang Denk
2008-09-07rtc: allow rtc_set to return an error and use it in cmd_dateJean-Christophe PLAGNIOL-VILLARD
2008-09-06RX 8025 RTC: analyze 12/24-hour mode flag in rtc_get().Yuri Tikhonov
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-08-25Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2008-08-25RTC: Fix Makefile problem with COBJS-$(CONFIG_RTC_DS1307 || CONFIG_RTC_DS1338)Stefan Roese
This "||" doesn't seem to work. Now using the idea suggest by Scott Wood to combine both config options into one line. This even allows defining both options and not generating the target object twice. Signed-off-by: Stefan Roese <sr@denx.de>
2008-08-25Add ARM AMBA PL031 RTC SupportGururaja Hebbar K R
Signed-off-by: Gururaja Hebbar K R <gururajakr@sanyo.co.in>
2008-08-18rtc: Clean drivers/rtc/MakefileMichal Simek
2008-07-10silence misc printf formatting compiler warningsKim Phillips
2008-07-10rtc: Fix printf format warning in m41t60.cStefan Roese
2008-06-03SPI API improvementsHaavard Skinnemoen
This patch gets rid of the spi_chipsel table and adds a handful of new functions that makes the SPI layer cleaner and more flexible. Instead of the spi_chipsel table, each board that wants to use SPI gets to implement three hooks: * spi_cs_activate(): Activates the chipselect for a given slave * spi_cs_deactivate(): Deactivates the chipselect for a given slave * spi_cs_is_valid(): Determines if the given bus/chipselect combination can be activated. Not all drivers may need those extra functions however. If that's the case, the board code may just leave them out (assuming they know what the driver needs) or rely on the linker to strip them out (assuming --gc-sections is being used.) To set up communication parameters for a given slave, the driver needs to call spi_setup_slave(). This returns a pointer to an opaque spi_slave struct which must be passed as a parameter to subsequent SPI calls. This struct can be freed by calling spi_free_slave(), but most driver probably don't want to do this. Before starting one or more SPI transfers, the driver must call spi_claim_bus() to gain exclusive access to the SPI bus and initialize the hardware. When all transfers are done, the driver must call spi_release_bus() to make the bus available to others, and possibly shut down the SPI controller hardware. spi_xfer() behaves mostly the same as before, but it now takes a spi_slave parameter instead of a spi_chipsel function pointer. It also got a new parameter, flags, which is used to specify chip select behaviour. This may be extended with other flags in the future. This patch has been build-tested on all powerpc and arm boards involved. I have not tested NIOS since I don't have a toolchain for it installed, so I expect some breakage there even though I've tried fixing up everything I could find by visual inspection. I have run-time tested this on AVR32 ATNGW100 using the atmel_spi and DataFlash drivers posted as a follow-up. I'd like some help testing other boards that use the existing SPI API. But most of all, I'd like some comments on the new API. Is this stuff usable for everyone? If not, why? Changed in v4: - Build fixes for various boards, drivers and commands - Provide common struct spi_slave definition that can be extended by drivers - Pass a struct spi_slave * to spi_cs_activate and spi_cs_deactivate - Make default bus and mode build-time configurable - Override default SPI bus ID and mode on mx32ads and imx31_litekit. Changed in v3: - Add opaque struct spi_slave for controller-specific data associated with a slave. - Add spi_claim_bus() and spi_release_bus() - Add spi_free_slave() - spi_setup() is now called spi_setup_slave() and returns a struct spi_slave - soft_spi now supports four SPI modes (CPOL|CPHA) - Add bus parameter to spi_setup_slave() - Convert the new i.MX32 SPI driver - Convert the new MC13783 RTC driver Changed in v2: - Convert the mpc8xxx_spi driver and the mpc8349emds board to the new API. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Tested-by: Guennadi Liakhovetski <lg@denx.de>
2008-05-03RTC: Fix month offset by one problem in M41T62 RTC driverStefan Roese
This patch fixes a problem with the month being read and written incorrectly (offset by one). This only gets visible by also using the Linux driver (rtc-m41t80). Tested on AMCC Canyonlands. Signed-off-by: Stefan Roese <sr@denx.de>
2008-04-18RTC driver for MC13783Guennadi Liakhovetski
MC13783 is a multifunction IS with an SPI interface to the host. This driver handles the RTC controller in this chip. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-04-17ds174x: Fix warning on return in rtc_get and rtc_set functionsJean-Christophe PLAGNIOL-VILLARD
2008-03-26Coding style cleanup.Wolfgang Denk
2008-03-26Add CFG_RTC_DS1337_NOOSC to turn off OSC outputJoakim Tjernlund
The default settings for RTC DS1337 keeps the OSC output, 32,768 Hz, on. This add CFG_RTC_DS1337_NOOSC to turn it off. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2008-03-26rtc: Remove 2nd reference to max6900.o in drivers/rtc/MakefileStefan Roese
2008-03-20LWMON5: POST RTC fixYuri Tikhonov
Modify the RTC API to provide one a status for the time reported by the rtc_get() function: 0 - a reliable time is guaranteed, < 0 - a reliable time isn't guaranteed (power fault, clock issues, and so on). The RTC chip drivers are responsible for providing this info if the corresponding chip supports such functionality. If not - always report that the time is reliable. The POST RTC test was modified to detect the RTC faults utilizing this new rtc_get() feature. Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
