path: root/drivers/rtc
2014-12-08Replace <compiler.h> with <linux/compiler.h>Masahiro Yamada
Including <linux/compiler.h> is enough for general use. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-25rtc: mc146818: Set up RTC at start of daySimon Glass
Provide a function to set up the RTC ready for use. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2014-10-23arm: marvell: Move arch/kirkwood.h to arch/soc.hStefan Roese
This move makes is possible to use this header not only from kirkwood platforms but from all Marvell mvebu platforms. Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Luka Perkov <luka@openwrt.org> Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
2014-09-24kconfig: add blank Kconfig filesMasahiro Yamada
This would be useful to start moving various config options. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-08-14RTC: add support for DS1339 (using DS1307 driver)Markus Niebel
Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
2014-02-19kbuild: use Linux Kernel build scriptsMasahiro Yamada
Now we are ready to switch over to real Kbuild. This commit disables temporary scripts: scripts/{Makefile.build.tmp, Makefile.host.tmp} and enables real Kbuild scripts: scripts/{Makefile.build,Makefile.host,Makefile.lib}. This switch is triggered by the line in scripts/Kbuild.include -build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj +build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj We need to adjust some build scripts for U-Boot. But smaller amount of modification is preferable. Additionally, we need to fix compiler flags which are locally added or removed. In Kbuild, it is not allowed to change CFLAGS locally. Instead, ccflags-y, asflags-y, cppflags-y, CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o are prepared for that purpose. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2013-11-11Merge branch 'master' of git://git.denx.de/u-boot-mipsTom Rini
2013-11-09Merge branch 'iu-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile board/compulab/cm_t35/Makefile board/corscience/tricorder/Makefile board/ppcag/bg0900/Makefile drivers/bootcount/Makefile include/configs/omap4_common.h include/configs/pdnb3.h Makefile conflicts are due to additions/removals of object files on the ARM branch vs KBuild introduction on the main branch. Resolution consists in adjusting the list of object files in the main branch version. This also applies to two files which are not listed as conflicting but had to be modified: board/compulab/common/Makefile board/udoo/Makefile include/configs/omap4_common.h conflicts are due to the OMAP4 conversion to ti_armv7_common.h on the ARM side, and CONFIG_SYS_HZ removal on the main side. Resolution is to convert as this icludes removal of CONFIG_SYS_HZ. include/configs/pdnb3.h is due to a removal on ARM side. Trivial resolution is to remove the file. Note: 'git show' will also list two files just because they are new: include/configs/am335x_igep0033.h include/configs/omap3_igep00x0.h
2013-11-09malta: enable RTC supportPaul Burton
This is actually required in order for a Linux kernel to boot successfully on a physical Malta board. Without enabling the RTC, a Malta Linux kernel will get stuck in its estimate_frequencies function on boot. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-01am33xx, davinci: Create and use <asm/davinci_rtc.h>Tom Rini
Create a common header file for the RTC IP block that is shared between davinci and am33xx. Signed-off-by: Tom Rini <trini@ti.com>
2013-11-01drivers/rtc/davinci.c: Reference DAVINCI_RTC_BASE more directlyTom Rini
We shouldn't rely on a define to hide this cast for us. Signed-off-by: Tom Rini <trini@ti.com>
2013-10-31drivers: convert makefiles to Kbuild styleMasahiro Yamada
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2013-09-19drivers: s3c44b0_rtc: delete an unused driverMasahiro Yamada
Since commit 5dc5f36 removed B2 board support, there are no boards enabling s3c44b0_rtc. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Andrea Scian <andrea.scian@dave-tech.it>
2013-04-01Consolidate bool typeYork Sun
'bool' is defined in random places. This patch consolidates them into a single header file include/linux/types.h, using stdbool.h introduced in C99. All other #define, typedef and enum are removed. They are all consistent with true = 1, false = 0. Replace FALSE, False with false. Replace TRUE, True with true. Skip *.py, *.php, lib/* files. Signed-off-by: York Sun <yorksun@freescale.com>
2013-03-11ppc: Remove PCIPPC2 and PCIPPC6 boardsStefan Roese
These boards seem to be unmaintained for quite some time. So lets remove support for them completely. This also cleans up some common drivers/files. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Guillaume Alexandre <guillaume.alexandre@gespac.ch> Acked-by: Wolfgang Denk <wd@denx.de>
2012-11-14pmic: Extend PMIC framework to support multiple instances of PMIC devicesŁukasz Majewski
The PMIC framework has been extended to support multiple instances of the variety of devices responsible for power management. This change allows supporting of e.g. fuel gauge, charger, MUIC (Micro USB Interface Circuit). Power related includes have been moved to ./include/power directory. This is a first of a series of patches - in the future "pmic" will be replaced with "power". Two important issues: 1. The PMIC needs to be initialized just after malloc is configured 2. It uses list to hold information about available PMIC devices Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Stefano Babic <sbabic@denx.de>
2012-09-02rtc: pcf8563: Make century compatible with LinuxBenoît Thébaudeau
This driver uses the century bit of this RTC in the opposite way Linux does. From Linux's rtc-pcf8563.c: /* * The meaning of MO_C bit varies by the chip type. * From PCF8563 datasheet: this bit is toggled when the years * register overflows from 99 to 00 * 0 indicates the century is 20xx * 1 indicates the century is 19xx * From RTC8564 datasheet: this bit indicates change of * century. When the year digit data overflows from 99 to 00, * this bit is set. By presetting it to 0 while still in the * 20th century, it will be set in year 2000, ... * There seems no reliable way to know how the system use this * bit. So let's do it heuristically, assuming we are live in * 1970...2069. */ As U-Boot's PCF8563 driver does not say it is supposed to support the RTC8564, make this driver compatible with Linux's by giving the opposite meaning to the century bit. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Wolfgang Denk <wd@denx.de>
2012-09-01rtc: add support of mx27 rtctrem
This driver has been tested on board armadeus apf27. Signed-off-by: Philippe Reynes <tremyfr@yahoo.fr> Acked-by: Stefano Babic <sbabic@denx.de>
2012-09-01mxs: Convert sys_proto.h prefixes to 'mxs'Otavio Salvador
The sys_proto.h functions (except the boot modes) are compatible with i.MX233 and i.MX28 so we use 'mxs' prefix for its methods. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2012-09-01rtc: imxdi: Initial supportBenoît Thébaudeau
Add support for Freescale's i.MX DryIce RTC, present on i.MX25. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2012-09-01mxs: prefix register structs with 'mxs' prefixOtavio Salvador
2012-08-10Add support for DS1388.Kenth Eriksson
Support for DS1388 is added by extending the DS1337 driver. DS1388 is similar to DS1337. The time registers are offset by 1 (due to support for hundreds of seconds), and there is no century bit. The configuration and trickle charge registers are also different. Tested on hardware with Freescale P2010 and DS1388. Signed-off-by: Kenth Eriksson <kenth.eriksson@transmode.com>
2012-07-07rtc/m41t62: Add support for M41T82 with HT (Halt Update)Stefan Roese
Add support for the M41T82 RTC to the m41t62 driver. The only difference that needs to be handled by this driver, is to clear the HT (Halt Update) bit upon reset. This bit is not used on the M41T62, so its save to clear this bit always. The M41T82 support will be used by the X600 (SPEAr600) board support. Signed-off-by: Stefan Roese <sr@denx.de>
2011-12-06arm, davinci: move davinci_rtc struct to hardware.hHeiko Schocher
move struct davinci_rtc to arch/arm/include/asm/arch-davinci/hardware.h and add RTC_KICK0R_WE, RTC_KICK1R_WE defines, so they are global useable. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-16drivers/rtc/s3c24x0_rtc.c: fix GCC 4.6 warningsAnatolij Gustschin
Fix: s3c24x0_rtc.c: In function 'rtc_get': s3c24x0_rtc.c:67:53: warning: variable 'a_armed' set but not used s3c24x0_rtc.c:67:45: warning: variable 'a_year' set but not used s3c24x0_rtc.c:67:38: warning: variable 'a_mon' set but not used s3c24x0_rtc.c:67:30: warning: variable 'a_date' set but not used s3c24x0_rtc.c:67:22: warning: variable 'a_hour' set but not used s3c24x0_rtc.c:67:15: warning: variable 'a_min' set but not used s3c24x0_rtc.c:67:8: warning: variable 'a_sec' set but not used [-Wunused-but-set-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-11-11iMX28: Add driver for internal RTCMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2011-11-08Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: Arm: re-introduce the MACH_TYPE_XXXXXX for EB_CPUX9K2 board arm: jadecpu: Readd MACH_TYPE_JADECPU at91: defined mach-types for otc570 board in board config file at91: defined mach-types for meesc board in board config file mx31pdk: Enable D and I caches ehci-mxc: remove incorrect comment README: Fix supported i.MX SoC list for CONFIG_MXC_SPI mx53: Turn off child clocks before reconfigure perclk_root qong: enable support for compressed images imx: imx31_phycore.h: fix checkpatch warnings vision2: Remove unused get_board_rev function mx53smd: Remove unused get_board_rev function mx53ard: Remove unused get_board_rev function mx53evk: Remove unused get_board_rev function mx53evk: Add RTC support mx53loco: Remove unused get_board_rev function mx53evk: Remove unneeded '1' from mx53evk.h OMAP3: mvblx: Initial support for mvBlueLYNX-X ARM: dig297: Define MACH_TYPE_OMAP3_CPS and CONFIG_MACH_TYPE omap3: mem: Move comments next to definitions omap3: mem: Clean-up whitespaces omap3: mem: Define and use common macros Davinci: ea20: added PREBOOT to configuration Davinci: ea20: added I2C support Davinci: ea20: added video support VIDEO: davinci: add framebuffer to da8xx ARM: Davinci: added missing registers to hardware.h Davinci: ea20: add gpios for LCD backlight control Davinci: ea20: add gpio for keeping power on in board_late_init Davinci: ea20: Add default U-Boot environment Davinci: ea20: Add early init to get early output from console Davinci: ea20: Add NAND support Davinci: ea20: set GPIOs to hold MII-Phy in reset and set UART0-Switch for console Davinci: ea20: set console on UART0 arm, davinci: add cam_enc_4xx support arm926ejs, davinci: add missing spi defines for dm365 arm926ejs, davinci: add cpuinfo for dm365 arm, davinci: add lowlevel function for dm365 soc arm, davinci: add header files for dm365 spl, nand: add 4bit HW ecc oob first nand_read_page function arm, davinci: add support for new spl framework spl: add option for adding post memory test to the SPL framework net, davinci_emac: make clock divider in MDIO control register configurable arm, usb, davinci: make USBPHY_CTL register configurable usb, davinci: add enable_vbus() weak function omap3evm: fix errors caused by multiple definitions omap3evm: Add (quick) configuration for NAND only omap3evm: Add (quick) configuration for MMC/SD only omap3evm: move common config options to new file omap3evm: Prepare to split configuration omap3evm: Reorder related config options omap/spl: actually enable the console davinci_emac: compilation fix, phy is array now omap3evm: Set environment variable 'ethaddr' arm, arm926: fix missing symbols in NAND_SPL mode arm, davinci: Add function lpsc_syncreset() arm, davinci: replace CONFIG_PRELOADER with CONFIG_SPL_BUILD arm/km: portl2 environment address update to P1B arm/km: adapt bootcounter evaluation arm/km: enable jffs2 cmds arm/km: trigger reconfiguration for the Xilinx FPGA arm/km: add boardid and hwkey to kernel command line ARM: Reintroduce MACH_TYPE_KM_KIRKWOOD for keymile ARM boards netspace_v2: enable I2C EEPROM support netspace_v2: fix SDRAM configuration armada100: define CONFIG_SYS_CACHELINE_SIZE pantheon: define CONFIG_SYS_CACHELINE_SIZE kirkwood: define CONFIG_SYS_CACHELINE_SIZE kirkwood: drop empty asm-offsets.s file arm/km/mgcoge3un: enhance "waitforne" feature arm/km: add variable waitforne to mgcoge3un gplugD: Fix for error:MACH_TYPE_SHEEVAD undeclared ARM: dreamplug: fix compilation ARM: DockStar: fix compilation ARM: netspace_v2: fix warnings am335x: Drop board_sysinfo struct am335x: Temporarily add MACH_TYPE define misc:pmic:samsung Enable PMIC driver at C210 Universal target dcache:s5p CONFIG_SYS_CACHELINE_SIZE added for s5p UNIVERSAL C210 target dcache:s5p CONFIG_SYS_CACHELINE_SIZE added for s5p GONI target smdkv310: use macro for mmc data read function address smdkv310: use spl framework for mmc spl SMDKV310: use get_ram_size() to validate dram size SMDKV310: Initialize board id using CONFIG_MACH_TYPE ORIGEN : use absolute paths and fix tool naming ORIGEN : enable device tree support MX25: tx25: Fix building due to missing MACH_TYPE mx31: Add board support for HALE TT-01 mx31: add ESD control registers mx31: define pins and init for UART2 and CSPI3 MX35: add support for flea3 board MX51: vision2: add MACH_TYPE in config file vision2: Remove unused header file mx51evk: Remove unused get_board_rev function mx51evk: Remove unneeded '1' from mx51evk.h I2C: Fix mxc_i2c.c problem on imx31_phycore mx35pdk: Add RTC support mx51evk: Use GPIO API for configuring the IOMUX mx51evk: Add RTC support rtc: Make mc13783-rtc driver generic qong: remove unneeded IOMUX settings qong: Use mx31_set_gpr to setup USBH2 pins mx31: Introduce mx31_set_gpr function mx31pdk: Add MC13783 PMIC support qong: remove unneeded "1" from qong.h misc: pmic: fix regression in pmic_fsl.c (SPI) mx5 configs: CONFIG_PRIME should really be CONFIG_ETHPRIME MX35: Drop unnecessary prototypes from imx-regs.h I2C: added I2C-2 and I2C-3 to MX35 MX35: factorize common assembly code MX35: add reset cause as provided by other i.MX MX35: add pins definition for UART3 MX35: added ESDC structure to imx-regs
2011-11-07drivers/rtc/rv3029.c: fix GCC 4.6 build warningsWolfgang Denk
Fix: rv3029.c: In function 'rtc_set': rv3029.c:98:6: warning: variable 'ret' set but not used [-Wunused-but-set-variable] rv3029.c: In function 'set_eere_bit': rv3029.c:131:6: warning: variable 'ret' set but not used [-Wunused-but-set-variable] rv3029.c: In function 'wait_eebusy': rv3029.c:149:9: warning: variable 'ret' set but not used [-Wunused-but-set-variable] rv3029.c: In function 'rtc_reset': rv3029.c:165:6: warning: variable 'ret' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-11-07drivers/rtc/ds3231.c: fix GCC 4.6 build warningsWolfgang Denk
Fix: ds3231.c: In function 'rtc_get': ds3231.c:90:52: warning: variable 'control' set but not used [-Wunused-but-set-variable] Fix is done by switching to standard debug() instead of custom macro. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-11-03ARM: dreamplug: fix compilationAnatolij Gustschin
Fix build issues: mvrtc.c: In function 'rtc_get': mvrtc.c:45: warning: implicit declaration of function 'readl' mvrtc.c: In function 'rtc_set': mvrtc.c:100: warning: implicit declaration of function 'writel' dreamplug.c: In function 'board_early_init_f': dreamplug.c:43: warning: implicit declaration of function 'kw_config_gpio' dreamplug.c: In function 'board_init': dreamplug.c:108: warning: implicit declaration of function 'kw_sdram_bar' drivers/rtc/librtc.o: In function `rtc_set': /home/ag/u-boot/u-boot-move-new-host/u-boot-video/drivers/rtc/mvrtc.c:92: undefined reference to `writel' /home/ag/u-boot/u-boot-move-new-host/u-boot-video/drivers/rtc/mvrtc.c:103: undefined reference to `writel' drivers/rtc/librtc.o: In function `rtc_reset': /home/ag/u-boot/u-boot-move-new-host/u-boot-video/drivers/rtc/mvrtc.c:117: undefined reference to `readl' /home/ag/u-boot/u-boot-move-new-host/u-boot-video/drivers/rtc/mvrtc.c:120: undefined reference to `readl' drivers/rtc/librtc.o: In function `rtc_get': /home/ag/u-boot/u-boot-move-new-host/u-boot-video/drivers/rtc/mvrtc.c:45: undefined reference to `readl' /home/ag/u-boot/u-boot-move-new-host/u-boot-video/drivers/rtc/mvrtc.c:48: undefined reference to `readl' ... Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Jason Cooper <u-boot@lakedaemon.net> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2011-11-03rtc: Make mc13783-rtc driver genericFabio Estevam
Rename mc13783-rtc so that it can be used for both MC13783 and MC13892 PMICs. efikamx board, for example, does use a MC13892 PMIC, but the RTC selection is currently made as: #define CONFIG_RTC_MC13783 ,which is not very obvious. Let the MC13783 and MC13892 RTC be selected by: #define CONFIG_RTC_MC13XXX Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2011-11-03drivers/rtc/ds1337.c: fix GCC 4.6 build warningsWolfgang Denk
Fix: ds1337.c: In function 'rtc_get': ds1337.c:88:52: warning: variable 'control' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-10-27RTC: Switch mc13783 to generic pmic codeStefano Babic
2011-09-30rtc, davinci: add support for davinci internal RTCHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Paulraj Sandeep <s-paulraj@ti.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-08-04Convert ISO-8859 files to UTF-8Albert ARIBAUD
There was a mix of UTF-8 and ISO-8859 files in the U-Boot source tree, which could cause issues with the patchwork review system. This commit converts all ISO-8859 files to UTF-8. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-08-04drivers/rtc: add Marvell Integrated RTCJason Cooper
This driver can be used for kirkwood SoCs by enabling CONFIG_RTC_MV. Tested on Global Scale Technologies Dreamplug. Signed-off-by: Jason Cooper <u-boot@lakedaemon.net>
2011-07-28cleanup: Fix typos and misspellings in various files.Mike Williams
Recieve/Receive recieve/receive Interupt/Interrupt interupt/interrupt Addres/Address addres/address Signed-off-by: Mike Williams <mike@mikebwilliams.com>
2011-05-18AT91: change includes from asm/arch/io.h to asm/io.hReinhard Meyer
and remove the now unused asm/arch-at91/io.h Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-05-18AT91: fix related at91 driver filesReinhard Meyer
2011-04-26rtc, rv3029: add trickle charger support.Heiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2011-02-12eNET: Add RTC support to eNETGraeme Russ
The SC520 has an inbuilt MC146818 - Enable it for the eNET board
2011-01-18rtc: add support for Micro Crystal RV-3029-C2 RTCHeiko Schocher
2010-12-17RTC driver for PT7C4338 chip.Priyanka Jain
PT7C4338 chip is being manufactured by Pericom Technology Inc. It is a serial real-time clock which provides: 1)Low-power clock/calendar. 2)Programmable square-wave output. It has 56 bytes of nonvolatile RAM. Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Acked-by: Timur Tabi <timur@freescale.com>
2010-10-29Merge branch 'master' of git://git.denx.de/u-boot-samsungWolfgang Denk
2010-10-28Add generic support for samsung s3c2440C Nauman
This patch adds generic support for the Samsung s3c2440 processor. Global s3c24x0 changes to struct members converting from upper case to lower case. Signed-off-by: Craig Nauman <cnauman@diagraph.com> Cc: kevin.morfitt@fearnside-systems.co.uk Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2010-10-20ftrtc010.c : enhance code according to original datasheetMacpaul Lin
Add missing codes according to original datasheet. This patch also makes ftrtc010 could be adapted to PCLK and EXT_CLK. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
