Now that we have a 'positive' Kconfig option, use this instead of the
negative one, which is harder to understand.
RTCs are using aliases for sequences. That's why enable
DM_UC_FLAG_SEQ_ALIAS for exact RTC indentification.
The same flag is used by a lot of other uclasses like mmc, pci, serial,
spi, timer, tpm, etc.
Define LOG_CATEGORY for all uclass to allow filtering with
log command.
Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
There is no devicetree with of-platdata. Update a few uclasses to allow
them to be built for sandbox_spl. Also drop the i2c-gpio from SPL to avoid
build errors, since it does not support of-platdata.
Similar to how the dm_rtc_{read,write} functions fall back to using
the {read,write}8 methods, do the opposite in the rtc_{read,write}8
functions.
This way, each driver only needs to provide either ->read8 or ->read
to make both rtc_read8() and dm_rtc_read() work - without this, a
driver that provides ->read() would most likely just duplicate the
logic here for implementing a ->read8() method in term of its ->read()
method. The same remarks of course apply to the write case.
Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk>
Similar to dm_rtc_read(), introduce a helper that allows the caller to
write multiple consecutive 8-bit registers with one call. If the
driver provides the ->write method, use that, otherwise loop using
->write8.
Some users may want to read multiple consecutive 8-bit
registers. Instead of each caller having to implement the loop,
provide a dm_rtc_read() helper. Also, allow a driver to provide a
->read method, which can be more efficient than reading one register
at a time.
Move this header out of the common header.
Some RTC chips have child drivers, e.g. to provide access to their
non-volatile RAM. Scan for these when binding.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
At present there are only 8-bit and 32-bit read/write routines in
the rtc uclass driver. This adds the 16-bit support.
The current check is incorrect and will fail when any non-zero byte is read.
Fix it.
Add a uclass for real-time clocks which support getting the current time,
setting it and resetting the chip to a known-working state. Some RTCs have
additional registers which can be used to store settings, so also provide
an interface to these.
