path: root/drivers/rtc/rtc-uclass.c
2015-10-21dm: rtc: Correct rtc_read32() return valueSimon Glass
The current check is incorrect and will fail when any non-zero byte is read. Fix it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-05-05dm: rtc: Add a uclass for real-time clocksSimon Glass
Add a uclass for real-time clocks which support getting the current time, setting it and resetting the chip to a known-working state. Some RTCs have additional registers which can be used to store settings, so also provide an interface to these. Signed-off-by: Simon Glass <sjg@chromium.org>
