path: root/drivers/rtc/pcf8563.c
2012-09-02rtc: pcf8563: Make century compatible with LinuxBenoît Thébaudeau
This driver uses the century bit of this RTC in the opposite way Linux does. From Linux's rtc-pcf8563.c: /* * The meaning of MO_C bit varies by the chip type. * From PCF8563 datasheet: this bit is toggled when the years * register overflows from 99 to 00 * 0 indicates the century is 20xx * 1 indicates the century is 19xx * From RTC8564 datasheet: this bit indicates change of * century. When the year digit data overflows from 99 to 00, * this bit is set. By presetting it to 0 while still in the * 20th century, it will be set in year 2000, ... * There seems no reliable way to know how the system use this * bit. So let's do it heuristically, assuming we are live in * 1970...2069. */ As U-Boot's PCF8563 driver does not say it is supposed to support the RTC8564, make this driver compatible with Linux's by giving the opposite meaning to the century bit. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Wolfgang Denk <wd@denx.de>
2009-08-25Switch from per-driver to common definition of bin2bcd and bcd2binAlbin Tonnerre
Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Acked-by: Stefan Roese <sr@denx.de>
2008-09-07rtc: allow rtc_set to return an error and use it in cmd_dateJean-Christophe PLAGNIOL-VILLARD
2008-08-18rtc: Clean drivers/rtc/MakefileMichal Simek
2008-03-20LWMON5: POST RTC fixYuri Tikhonov
Modify the RTC API to provide one a status for the time reported by the rtc_get() function: 0 - a reliable time is guaranteed, < 0 - a reliable time isn't guaranteed (power fault, clock issues, and so on). The RTC chip drivers are responsible for providing this info if the corresponding chip supports such functionality. If not - always report that the time is reliable. The POST RTC test was modified to detect the RTC faults utilizing this new rtc_get() feature. Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2007-11-25drivers/rtc : move rtc drivers to drivers/rtcJean-Christophe PLAGNIOL-VILLARD
