path: root/drivers/rtc/mk48t59.c
2018-07-25rtc: remove CONFIG_CMD_DATE dependencyHeinrich Schuchardt
The EFI subsystem accesses the real time clock and is enabled by default. So we should drop any CONFIG_CMD_DATE dependency from the real time clock drivers. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-03-11ppc: Remove PCIPPC2 and PCIPPC6 boardsStefan Roese
These boards seem to be unmaintained for quite some time. So lets remove support for them completely. This also cleans up some common drivers/files. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Guillaume Alexandre <guillaume.alexandre@gespac.ch> Acked-by: Wolfgang Denk <wd@denx.de>
2010-06-23Remove AmigaOneG3SE boardWolfgang Denk
The AmigaOneG3SE board has been orphaned or a very long time, and broken for more than 12 releases resp. more than 3 years. As nobody seems to be interested any more in this stuff we may as well ged rid of it, especially as it clutters many areas of the code so it is a continuous pain for all kinds of ongoing work. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-08-25Switch from per-driver to common definition of bin2bcd and bcd2binAlbin Tonnerre
Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Acked-by: Stefan Roese <sr@denx.de>
2008-09-08mk48t59: fix compile problem introduced by commit d1e23194Wolfgang Denk
2008-09-07rtc: allow rtc_set to return an error and use it in cmd_dateJean-Christophe PLAGNIOL-VILLARD
2008-08-18rtc: Clean drivers/rtc/MakefileMichal Simek
2008-03-20LWMON5: POST RTC fixYuri Tikhonov
Modify the RTC API to provide one a status for the time reported by the rtc_get() function: 0 - a reliable time is guaranteed, < 0 - a reliable time isn't guaranteed (power fault, clock issues, and so on). The RTC chip drivers are responsible for providing this info if the corresponding chip supports such functionality. If not - always report that the time is reliable. The POST RTC test was modified to detect the RTC faults utilizing this new rtc_get() feature. Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2007-11-25drivers/rtc : move rtc drivers to drivers/rtcJean-Christophe PLAGNIOL-VILLARD
