path: root/drivers/rtc/i2c_rtc_emul.c
2018-07-19drivers: rtc: resolve year 2038 problem in rtc_to_tmHeinrich Schuchardt
Our implementation of rtc_to_tm() cannot handle dates of more than 0x7fffffff seconds after 1970-01-01. Adopt the Linux kernel implementation. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-01dm: sandbox: i2c_rtc: Drop fdtdec.h headerSimon Glass
This is not needed in this driver. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-05-05dm: rtc: sandbox: Add an emulated I2C RTC deviceSimon Glass
Add a sandbox I2C emulation device which emulates a real-time clock. The clock works off an offset from the current system time, and supports setting and getting the clock, as well as access to byte-width regisers in the RTC. It does not support changing the system time. This device can be used for testing the 'date' command on sandbox, as well as the RTC uclass. Signed-off-by: Simon Glass <sjg@chromium.org>
