path: root/drivers/remoteproc
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop net.h from common headerSimon Glass
Move this header out of the common header. Network support is used in quite a few places but it still does not warrant blanket inclusion. Note that this net.h header itself has quite a lot in it. It could be split into the driver-mode support, functions, structures, checksumming, etc. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-03-16remoteproc: k3-r5: Fix rproc init failure on Split-mode _only_ devicesSuman Anna
The R5F subsystem/cluster on K3 SoCs can support both LockStep and Split-modes (superset) or just Split-mode depending on an eFUSE capability register. The LockStep configuration bit is Read-only though on Split-mode _only_ devices and as such the System Firmware does not allow the LockStep mode bit to be configured on such devices. The current logic in k3_r5f_rproc_configure() fails on Split-mode devices because of this unconditional programming of the LockStep mode bit, and results in the probe failure shown during the "rproc init" step at U-Boot prompt. Fix this by limiting the LockStep mode bit clear configuration only on devices supporting both LockStep/Split-modes. Fixes: 4c850356a83f ("remoteproc: Introduce K3 remoteproc driver for R5F subsystem") Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Andreas Dannenberg <dannenberg@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2020-03-16remoteproc: k3-r5: Fix rproc init failure for Main R5FSS0Suman Anna
The Main R5FSS0 cluster is also enabled to probe the R5F remoteproc driver within R5 SPL for booting the Core0 very early. This results in a ti_sci_power_domain_on failure during the probe from the A72 U-Boot when "rproc init" is executed at U-Boot prompt, and doesn't enumerate all the rproc devices. Fix this by suppressing the power_domain_on altogether using the flag DM_FLAG_DEFAULT_PD_CTRL_OFF added in commit af94ad418dc7 ("dm: core: Allow for not controlling the power-domain by DM framework"). Fixes: fac6aa817a09 ("configs: j721e_evm_r5: Enable R5F remoteproc support") Signed-off-by: Suman Anna <s-anna@ti.com>
2020-03-16remoteproc: k3-dsp: Add support for L2RAM loading on C66x DSPsSuman Anna
The resets for the DSP processors on K3 SoCs are managed through the Power and Sleep Controller (PSC) module. Each DSP typically has two resets - a global module reset for powering on the device, and a local reset that affects only the CPU while allowing access to the other sub-modules within the DSP processor sub-systems. The C66x DSPs have two levels of internal RAMs that can be used to boot from, and the firmware loading into these RAMs require the local reset to be asserted with the device powered on/enabled using the module reset. Enhance the K3 DSP remoteproc driver to add support for loading into the internal RAMs. The local reset is deasserted on SoC power-on-reset, so logic has to be added in probe in remoteproc mode to balance the remoteproc state-machine. Note that the local resets are a no-op on C71x cores, and the hardware does not supporting loading into its internal RAMs. Signed-off-by: Suman Anna <s-anna@ti.com>
2020-03-16remoteproc: k3-dsp: Add a sanity check for DSP boot address alignmentSuman Anna
The DSP remote processors on K3 SoCs require a boot register to be programmed with a boot address, and these boot addresses need to be aligned on certain address boundaries. The current code does not have any error checks, and relies on the System Firmware to perform the checking. Add logic to perform this sanity check within the remoteproc driver itself to detect these anomalies specifically, and print a meaningful trace. This avoids the cumbersome debug of root-causing such failures from the corresponding TI-SCI failure. The C66x and C71x DSP cores have different alignment needs and are as follows: C66x DSP = 1 KB (0x400) C71x DSP = 2 MB (0x200000) Signed-off-by: Suman Anna <s-anna@ti.com>
2020-03-16remoteproc: k3-dsp: Fix unbalanced state machine in k3_dsp_startSuman Anna
The global module reset is deasserted through the ti_sci_power_domain_on() call in k3_dsp_start(), but is not asserted back if the local module reset fails. Fix this. While at this, remove the stale comment about assigned-clock-rates that seems to have been copied from the K3 ARM64 Remoteproc driver. Fixes: ab827b385718 ("remoteproc: Introduce K3 C66 and C71 remoteproc driver") Signed-off-by: Suman Anna <s-anna@ti.com>
2020-02-05dm: core: Create a new header file for 'compat' featuresSimon Glass
At present dm/device.h includes the linux-compatible features. This requires including linux/compat.h which in turn includes a lot of headers. One of these is malloc.h which we thus end up including in every file in U-Boot. Apart from the inefficiency of this, it is problematic for sandbox which needs to use the system malloc() in some files. Move the compatibility features into a separate header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-02-05dm: core: Require users of devres to include the headerSimon Glass
At present devres.h is included in all files that include dm.h but few make use of it. Also this pulls in linux/compat which adds several more headers. Drop the automatic inclusion and require files to include devres themselves. This provides a good indication of which files use devres. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Anatolij Gustschin <agust@denx.de>
2020-01-24remoteproc: elf_loader: fix program header parsingFabien Dessenne
Fix an issue where some sections are never loaded : if p_type is different from PT_LOAD the phdr pointer must be incremented. Signed-off-by: Fabien Dessenne <fabien.dessenne@st.com> Acked-by: Suman Anna <s-anna@ti.com>
2020-01-07remoteproc: stm32: load resource table from firmwareFabien Dessenne
Load the optional resource table from the firmware, and write its address in the dedicated backup register. Signed-off-by: Fabien Dessenne <fabien.dessenne@st.com> Acked-by: Patrick Delaunay <patrick.delaunay@st.com>
2020-01-07remoteproc: stm32: track the coprocessor state in a backup registerFabien Dessenne
Update the dedicated backup register to track the coprocessor state and rely on that register to compute the .is_running() value (which expects a return value of 0 -not 1- if the processor is running). Signed-off-by: Fabien Dessenne <fabien.dessenne@st.com> Acked-by: Patrick Delaunay <patrick.delaunay@st.com>
2020-01-07remoteproc: elf_loader: Add elf resource table load supportFabien Dessenne
Add rproc_elf_load_rsc_table(), which searches for a resource table in an elf64/elf32 image, and if found, copies it to device memory. Add also the elf32 and elf64 variants of this API. Add a test for this. Signed-off-by: Fabien Dessenne <fabien.dessenne@st.com> Acked-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2019-12-02common: Move ARM cache operations out of common.hSimon Glass
These functions are CPU-related and do not use driver model. Move them to cpu_func.h Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-10-15remoteproc: k3_arm64: Enable DM_FLAG_DEFAULT_PD_CTRL_OFFLokesh Vutla
Enable DM_FLAG_DEFAULT_PD_CTRL_OFF for arm64 remote core so that pd can be enabled after loading the image. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-10-11remoteproc: Introduce K3 C66 and C71 remoteproc driverLokesh Vutla
Certain SoCs with K3 architecture have integrated a C66 Corepac DSP subsystem and an advanced C71 DSPs. Introduce a remoteproc driver that that does take care of loading an elf to any of the specified DSPs and start it. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Suman Anna <s-anna@ti.com>
2019-10-11remoteproc: Introduce K3 remoteproc driver for R5F subsystemLokesh Vutla
SoCs with K3 architecture have an integrated Arm Cortex-R5F subsystem that is comprised of dual-core Arm Cortex-R5F processor cores. This R5 subsytem can be configured at boot time to be either run in a LockStep mode or in an Asymmetric Multi Processing (AMP) fashion in Split-mode. This subsystem has each Tightly-Coupled Memory (TCM) internal memories for each core split between two banks - TCMA and TCMB. Add a remoteproc driver to support this subsystem to be able to load and boot the R5 cores primarily in LockStep mode or split mode. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Suman Anna <s-anna@ti.com>
2019-10-11remoteproc: tisci_proc: Add helper api for controlling core power domainLokesh Vutla
Power domain for the remote cores needs to be handled in a right sequence as mandated by the spec. Introduce tisci helper apis that can control power-domains of remote cores. TISCI clients can use this api and control the remote cores power domain instead of hooking it to power-domain layer. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2019-10-11remoteproc: elf_loader: Introduce rproc_elf_get_boot_addr() apiLokesh Vutla
Introduce rproc_elf_get_boot_addr() that returns the entry point of the elf file. This api auto detects the 64/32 bit elf file and returns the boot addr accordingly. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2019-10-11remoteproc: elf_loader: Introduce a common elf loader and checker functionsLokesh Vutla
Introduce a common remoteproc elf loader and checker functions that automatically detects the 64 bit elf file or 32 bit elf file and loads/checks the sections accordingly. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Fabien Dessenne <fabien.dessenne@st.com>
2019-10-11remoteproc: elf-loader: Add 64 bit elf loading supportLokesh Vutla
The current rproc-elf-loader supports loading of only 32 bit elf files. Introduce support for loading of 64 bit elf files in rproc-elf-loader. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Fabien Dessenne <fabien.dessenne@st.com>
2019-10-11remoteproc: elf_loader: Always check the validity of the image before loadingLokesh Vutla
rproc_elf32_load_image() rely on user to send a valid address for elf loading. Instead do a sanity check on the address passed by user. This will help all rproc elf users to not call sanity_check explicitly before calling elf_loading. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Fabien Dessenne <fabien.dessenne@st.com>
2019-10-11remoteproc: ops: Add elf section size as input parameter to device_to_virt apiLokesh Vutla
Introduce a new parameter "size" that accepts size of the region to remoteproc ops callback device_to_virt(). This can enforce more checks on the region that device_to_virt() is dealing with. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Tested-by: Fabien Dessenne <fabien.dessenne@st.com> Reviewed-by: Fabien Dessenne <fabien.dessenne@st.com>
2019-08-27stm32mp1: Add remoteproc support for m4 coprocessorPatrick Delaunay
Alignment with kernel patch proposal for binding: [PATCH v4 0/8] stm32 m4 remoteproc on STM32MP157c https://lkml.org/lkml/2019/5/14/159 Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-07-26remoteproc: k3_rproc: Rename to ti_k3_arm64_rprocLokesh Vutla
k3_rproc driver is specifically meant for controlling an arm64 core using TISCI protocol. So rename the driver, Kconfig symbol, compatible and functions accordingly. While at it drop this remoteproc selection for a53 defconfig. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2019-07-26remoteproc: k3_rproc: Update the driver to use ti_sci_proc helpersLokesh Vutla
Update the k3_rproc driver to use the generic ti_sci_proc helper apis which simplifies the driver a bit. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2019-07-26remoteproc: tisci: add TI-SCI processor control helper functionsLokesh Vutla
Texas Instruments' K3 generation SoCs has specific modules/register spaces used for configuring the various aspects of a remote processor. These include power, reset, boot vector and other configuration features specific to each compute processor present on the SoC. These registers are managed by the System Controller such as DMSC on K3 AM65x SoCs. The Texas Instrument's System Control Interface (TI-SCI) Message Protocol is used to communicate to the System Controller from various compute processors to invoke specific services provided by the firmware running on the System Controller. Add a common processor control interface header file that can be used by multiple remoteproc drivers. The helper functions within this header file abstract the various TI SCI protocol ops for the remoteproc drivers, and allow them to request the System Controller to be able to program and manage various remote processors on the SoC. The common macros required by the R5 remoteproc driver were also added. The remoteproc drivers are expected to manage the life-cycle of their ti_sci_proc_dev local structures. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Suman Anna <s-anna@ti.com>
2019-07-22remoteproc: Introduce STM32 Cortex-M4 remoteproc driverFabien Dessenne
This patch introduces support of Cortex-M4 remote processor for STM32 MCU and MPU families. Signed-off-by: Loic Pallardy <loic.pallardy@st.com> Signed-off-by: Fabien Dessenne <fabien.dessenne@st.com>
2019-07-22remoteproc: add elf file load supportFabien Dessenne
The current implementation supports only binary file load. Add helpers to support ELF32 format (sanity check, and load). Note that since an ELF32 image is built for the remote processor, the load function uses the device_to_virt ops to translate the addresses. Implement a basic translation for sandbox_testproc. Add related tests. Test result: => ut dm remoteproc_elf Test: dm_test_remoteproc_elf: remoteproc.c Test: dm_test_remoteproc_elf: remoteproc.c (flat tree) Failures: 0 Signed-off-by: Loic Pallardy <loic.pallardy@st.com> Signed-off-by: Fabien Dessenne <fabien.dessenne@st.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2019-05-09remoteproc: k3_system_controller: Increase rx timeoutLokesh Vutla
There is one case where 400ms is not sufficient for loading the system firmware: - System firmware is not signed with rsa degenerate key. - ROM loading the sysfw directly from SPI flash which is in memory mapped mode. The above scenario is definitely not desired in production use cases as it effects boot time. But still keeping this support as this is a valid boot scenario. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-09-11spl: Allow remoteproc drivers to be used within SPLLokesh Vutla
Add an option for building remoteproc drivers within SPL. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-09-11remoteproc: Introduce K3 remoteproc driverLokesh Vutla
Add support for K3 based remoteproc driver that communicates with TISCI to start start a remote processor. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-09-11remoteproc: Introduce K3 system controllerLokesh Vutla
K3 specific SoCs have a dedicated microcontroller for doing resource management. Any HLOS/firmware on compute clusters should load a firmware to this microcontroller before accessing any resource. Adding support for loading this firmware. After the K3 system controller got loaded with firmware and started up it sends out a boot notification message through the secure proxy facility using the TI SCI protocol. Intercept and receive this message through the rproc start operation which will need to get invoked explicitly after the firmware got loaded. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Andreas Dannenberg <dannenberg@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-09-11remoteproc: Allow for individual remoteproc initializationLokesh Vutla
Existing rproc_init() api tries to initialize all available remoteproc devices. This will fail when there is dependency among available remoteprocs. So introduce a separate api that allows to initialize remoteprocs individually based on id. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-02-08dm: core: Replace of_offset with accessorSimon Glass
At present devices use a simple integer offset to record the device tree node associated with the device. In preparation for supporting a live device tree, which uses a node pointer instead, refactor existing code to access this field through an inline function. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-14remoteproc: Add support for TI power processorNishanth Menon
Many TI System on Chip (SoC) solutions do have a dedicated microcontroller for doing power management functionality. These include the AM335x, AM437x, Keystone K2G SoCs. The functionality provided by these microcontrollers and the communication mechanisms vary very widely. However, we are able to consolidate some basic functionality to be generic enough starting with K2G SoC family. Introduce a basic remote proc driver to support these microcontrollers. In fact, on SoCs starting with K2G, basic power management functions are primarily accessible for the High Level Operating Systems(HLOS) via these microcontroller solutions. Hence, having these started at a bootloader level is pretty much mandatory. Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-12-05drivers: remoteproc: rproc-uclass: Fix check for NULL pointersNishanth Menon
Neither uc_pdata->name nor check_name are supposed to be NULL in _rproc_name_is_unique(). if uc_pdata->name is NULL, we are not intialized yet, however if check_data is NULL, we do not have proper data. Further, if either were NULL, strlen will crap out while attempting to derefence NULL. Instead, just check if either of these are NULL and bail out. This should also fix the following coverity scan warnings: *** CID 132281: Null pointer dereferences (FORWARD_NULL) /drivers/remoteproc/rproc-uclass.c: 73 in _rproc_name_is_unique() Reported-by: Tom Rini <trini@konsulko.com> Signed-off-by: Nishanth Menon <nm@ti.com>
2015-10-22remoteproc: Introduce a sandbox dummy driverNishanth Menon
Introduce a dummy driver for sandbox that allows us to verify basic functionality. This is not meant to do anything functional - but is more or less meant as a framework plumbing debug helper. The sandbox remoteproc driver maintains absolutey no states and is a simple driver which just is filled with empty hooks. Idea being to give an approximate idea to implement own remoteproc driver using this as a template. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Nishanth Menon <nm@ti.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-22drivers: Introduce a simplified remoteproc frameworkNishanth Menon
Many System on Chip(SoC) solutions are complex with multiple processors on the same die dedicated to either general purpose of specialized functions. Many examples do exist in today's SoCs from various vendors. Typical examples are micro controllers such as an ARM M3/M0 doing a offload of specific function such as event integration or power management or controlling camera etc. Traditionally, the responsibility of loading up such a processor with a firmware and communication has been with a High Level Operating System(HLOS) such as Linux. However, there exists classes of products where Linux would need to expect services from such a processor or the delay of Linux and operating system being able to load up such a firmware is unacceptable. To address these needs, we need some minimal capability to load such a system and ensure it is started prior to an Operating System(Linux or any other) is started up. NOTE: This is NOT meant to be a solve-all solution, instead, it tries to address certain class of SoCs and products that need such a solution. A very simple model is introduced here as part of the initial support that supports microcontrollers with internal memory (no MMU, no execution from external memory, or specific image format needs). This basic framework can then (hopefully) be extensible to other complex SoC processor support as need be. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Nishanth Menon <nm@ti.com> Acked-by: Simon Glass <sjg@chromium.org>
