path: root/drivers/remoteproc
2019-05-09remoteproc: k3_system_controller: Increase rx timeoutLokesh Vutla
There is one case where 400ms is not sufficient for loading the system firmware: - System firmware is not signed with rsa degenerate key. - ROM loading the sysfw directly from SPI flash which is in memory mapped mode. The above scenario is definitely not desired in production use cases as it effects boot time. But still keeping this support as this is a valid boot scenario. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-09-11spl: Allow remoteproc drivers to be used within SPLLokesh Vutla
Add an option for building remoteproc drivers within SPL. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-09-11remoteproc: Introduce K3 remoteproc driverLokesh Vutla
Add support for K3 based remoteproc driver that communicates with TISCI to start start a remote processor. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-09-11remoteproc: Introduce K3 system controllerLokesh Vutla
K3 specific SoCs have a dedicated microcontroller for doing resource management. Any HLOS/firmware on compute clusters should load a firmware to this microcontroller before accessing any resource. Adding support for loading this firmware. After the K3 system controller got loaded with firmware and started up it sends out a boot notification message through the secure proxy facility using the TI SCI protocol. Intercept and receive this message through the rproc start operation which will need to get invoked explicitly after the firmware got loaded. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Andreas Dannenberg <dannenberg@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-09-11remoteproc: Allow for individual remoteproc initializationLokesh Vutla
Existing rproc_init() api tries to initialize all available remoteproc devices. This will fail when there is dependency among available remoteprocs. So introduce a separate api that allows to initialize remoteprocs individually based on id. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-02-08dm: core: Replace of_offset with accessorSimon Glass
At present devices use a simple integer offset to record the device tree node associated with the device. In preparation for supporting a live device tree, which uses a node pointer instead, refactor existing code to access this field through an inline function. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-14remoteproc: Add support for TI power processorNishanth Menon
Many TI System on Chip (SoC) solutions do have a dedicated microcontroller for doing power management functionality. These include the AM335x, AM437x, Keystone K2G SoCs. The functionality provided by these microcontrollers and the communication mechanisms vary very widely. However, we are able to consolidate some basic functionality to be generic enough starting with K2G SoC family. Introduce a basic remote proc driver to support these microcontrollers. In fact, on SoCs starting with K2G, basic power management functions are primarily accessible for the High Level Operating Systems(HLOS) via these microcontroller solutions. Hence, having these started at a bootloader level is pretty much mandatory. Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-12-05drivers: remoteproc: rproc-uclass: Fix check for NULL pointersNishanth Menon
Neither uc_pdata->name nor check_name are supposed to be NULL in _rproc_name_is_unique(). if uc_pdata->name is NULL, we are not intialized yet, however if check_data is NULL, we do not have proper data. Further, if either were NULL, strlen will crap out while attempting to derefence NULL. Instead, just check if either of these are NULL and bail out. This should also fix the following coverity scan warnings: *** CID 132281: Null pointer dereferences (FORWARD_NULL) /drivers/remoteproc/rproc-uclass.c: 73 in _rproc_name_is_unique() Reported-by: Tom Rini <trini@konsulko.com> Signed-off-by: Nishanth Menon <nm@ti.com>
2015-10-22remoteproc: Introduce a sandbox dummy driverNishanth Menon
Introduce a dummy driver for sandbox that allows us to verify basic functionality. This is not meant to do anything functional - but is more or less meant as a framework plumbing debug helper. The sandbox remoteproc driver maintains absolutey no states and is a simple driver which just is filled with empty hooks. Idea being to give an approximate idea to implement own remoteproc driver using this as a template. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Nishanth Menon <nm@ti.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-22drivers: Introduce a simplified remoteproc frameworkNishanth Menon
Many System on Chip(SoC) solutions are complex with multiple processors on the same die dedicated to either general purpose of specialized functions. Many examples do exist in today's SoCs from various vendors. Typical examples are micro controllers such as an ARM M3/M0 doing a offload of specific function such as event integration or power management or controlling camera etc. Traditionally, the responsibility of loading up such a processor with a firmware and communication has been with a High Level Operating System(HLOS) such as Linux. However, there exists classes of products where Linux would need to expect services from such a processor or the delay of Linux and operating system being able to load up such a firmware is unacceptable. To address these needs, we need some minimal capability to load such a system and ensure it is started prior to an Operating System(Linux or any other) is started up. NOTE: This is NOT meant to be a solve-all solution, instead, it tries to address certain class of SoCs and products that need such a solution. A very simple model is introduced here as part of the initial support that supports microcontrollers with internal memory (no MMU, no execution from external memory, or specific image format needs). This basic framework can then (hopefully) be extensible to other complex SoC processor support as need be. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Nishanth Menon <nm@ti.com> Acked-by: Simon Glass <sjg@chromium.org>
