The SDRAM_IDX in DDRSS_V2A_CTL_REG describes the number of address
bits minus 16 that are used to determine the mask used to detect
memory rollover and prevent aliasing and false coherency issues.
Set SDRAM_IDX using the device private data, ddr_ram_size for AM64x,
AM62x and AM62x SIP.
Signed-off-by: Santhosh Kumar K <s-k6@ti.com>
Acked-by: Bryan Brattlof <bb@ti.com>
I do not think the R5 SPL will initialize non static variables (I didn't
find and evidence of it) so we want to ensure this is a constant.
Signed-off-by: Bryan Brattlof <bb@ti.com>
The AM64x and some of the AM62xx family of devices use the same 16b
controller though only the AM64x is limited to 2GB addressable.
Annoyingly the address alias detection machinery defaults to the full
8GB for the AM64x. Reset this value to 2GB only if we're initializin DDR
on an am64x device
Add CONFIG_K3_INLINE_ECC so that ECC functions can be compiled into R5 SPL
only when the config has been enabled.
Signed-off-by: Neha Malcom Francis <n-francis@ti.com>
Enable ECC 1-bit error, 2-bit error, multiple 1-bit error interrupts
by setting the respective bits in the DDRSS_V2A_INT_SET_REG register.
Setup the ECC region's start and range using the device private data,
ddrss->ddr_bank_base[0] and ddrss->ddr_ram_size. Also, move start and
range of ECC regions from 32 bits to 64 bits to accommodate for
DDR greater than or equal to 4GB.
Reviewed-by: Neha Malcom Francis <n-francis@ti.com>
restricted to 32 bits' issue
As R5 is a 32 bit processor, the RAM banks' base and size calculation
is restricted to 32 bits, which results in wrong values if bank's base
is greater than 32 bits or bank's size is greater than or equal to 4GB.
So, add k3_ddrss_ddr_bank_base_size_calc() to get the base address and
size of RAM's banks from the device tree memory node, and store in a
64 bit device private data which can be used for ECC reserved memory
calculation, Setting ECC range and Fixing up bank size in device tree
when ECC is enabled.
The 1-bit inline ECC support in TI's DDRSS bridge requires
the configured memory regions to be preloaded with a pattern
before use. This is done by the k3-ddrss driver from the
R5 SPL in a 'for' loop. It takes around 10 seconds to fill
2GB of memory, for example. Memset can cut the time in half
and using DMA currently yields a similar result.
The BIST engine of DDR controller provides support for
initializing any memory region with a pattern. This
bypasses the DDRSS bridge, so the required inline ECC
data is not computed and populated in the memory. For
some values like zero, the computed ECC syndrome is also
zero and we can use these values to preload the memory
from the DDR controller, without the assistance of the
bridge.
The registers involved in the process are described in the
'DDR controller registers' topic in [1] AM62 and [2] J721E
reference manuals.
The patch replaces the 'for' loop memory fill function with
the BIST memory initialization procedure. This cuts the time
to preload the 2GB memory from 10 seconds down to 1 second.
The bist preload function uses the lpddr4 APIs in the k3-ddrss,
so this is compatible with devices with both 16-bit LPDDR4 and
32-bit LPDDR4 interfaces (e.g J721E).
[1] AM62x: https://www.ti.com/lit/pdf/spruiv7
[2] DRA829/TDA4VM: https://www.ti.com/lit/zip/spruil1
Signed-off-by: Georgi Vlaev <g-vlaev@ti.com>
The J722S family of SoCs uses the same DDR controller as found on the
AM62A family. Enable this option when building for the J722S family.
Signed-off-by: Vaishnav Achath <vaishnav.a@ti.com>
Signed-off-by: Jayesh Choudhary <j-choudhary@ti.com>
commit af7c33c103450e06aecf8adba8cbc8c522295be1 upstream.
During LPDDR initialization we will loop through a series of frequency
changes in order to train at the various operating frequencies. During
this training, accessing the DRAM_CLASS bitfield could happen during a
frequency change and cause the read to hang.
Store the DRAM type into the main structure to avoid multiple readings
while the independent phy is training.
[praneeth@ti.com: cherrypick from v2023.10]
Signed-off-by: Praneeth Bajjuri <praneeth@ti.com>
The am62px family of SoCs uses the same DDR controller as found on the
am62ax family. Enable this option when building for the am62px family
When DDR ECC is off (ecc_reserved_space = 0) k3_ddrss_ddr_fdt_fixup()
doesn't update the DDR size in the memory node of DT. Fix this by
dropping check for ecc_reserved_space to be non zero.
This allows R5 SPL to fixup A53 SPL DT with right DDR size as discovered
during DDR init or based on R5 SPL DT input.
Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
Signed-off-by: Nitin Yadav <n-yadav@ti.com>
Add support for DDR subsystem in J784S4 SoC.
Signed-off-by: Apurva Nandan <a-nandan@ti.com>
Signed-off-by: Hari Nagalla <hnagalla@ti.com>
A condition in the rk3399 RAM initialization code used the old
CONFIG_RAM_RK3399_LPDDR4 constant name. This commit changes the
condition to use the correct CONFIG_RAM_ROCKCHIP_LPDDR4 constant.
Add ddr driver for rk3588 to get the ram capacity.
Co-developed-by: Jonas Karlman <jonas@kwiboo.se>
Signed-off-by: Jonas Karlman <jonas@kwiboo.se>
Signed-off-by: Jagan Teki <jagan@edgeble.ai>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
At this point, the remaining places where we have a symbol that is
defined as CONFIG_... are in fairly odd locations. While as much dead
code has been removed as possible, some of these locations are simply
less obvious at first. In other cases, this code is used, but was
defined in such a way as to have been missed by earlier checks. Perform
a rename of all such remaining symbols to be CFG_... rather than
CONFIG_...
Add LPDDR4 detection timings and support for RV1126.
Control the ddr init print messages via RAM_ROCKCHIP_DEBUG
instead of printing by default.
This gives an option to configs to enable these prints or
not.
Add DDR driver for Rockchip RV1126 SoC.
Signed-off-by: YouMin Chen <cym@rock-chips.com>
Add DDR loader parameters for Rockchip RV1126 SoC.
Add DDR3 detection timings for Rockchip RV1126 SoC.
Add full ddr pctl registers and bit masks for px30.
DDR chip capacity is computed based on GRF split in some
Rockchip SoC's like PX30 and RV1126.
Add split argument in ddr print info so-that the respective
ddr driver will pass the grf split.
We have common ddr types in rockchip or in general. So use
the common ddr type names instead of per Rockchip SoC to
avoid confusion.
The respective ddr type names will use on the associated
ddr SoC driver as these drivers are built per SoC at a time.
ram-uclass is building irrespective of whether TPL_DM
or SPL_DM is enabled. So control the ram uclass build
based on TPL/SPL_DM.
This removes the following unreferenced CONFIG symbols:
CONFIG_FDTADDR
CONFIG_FDTFILE
CONFIG_FLASH_SECTOR_SIZE
CONFIG_FSL_CPLD
CONFIG_HDMI_ENCODER_I2C_ADDR
CONFIG_I2C_MVTWSI
CONFIG_I2C_RTC_ADDR
CONFIG_IRAM_END
CONFIG_IRAM_SIZE
CONFIG_KSNET_MDIO_PHY_CONFIG_ENABLE
CONFIG_L1_INIT_RAM
CONFIG_MACB_SEARCH_PHY
CONFIG_MIU_2BIT_21_7_INTERLEAVED
CONFIG_MTD_NAND_VERIFY_WRITE
CONFIG_MVGBE_PORTS
CONFIG_NETDEV
CONFIG_NUM_DSP_CPUS
CONFIG_PHY_BASE_ADR
CONFIG_PHY_INTERFACE_MODE
CONFIG_PSRAM_SCFG
CONFIG_RAMBOOT_SPIFLASH
CONFIG_RAMBOOT_TEXT_BASE
CONFIG_RD_LVL
CONFIG_ROCKCHIP_SDHCI_MAX_FREQ
CONFIG_SETUP_INITRD_TAG
CONFIG_SH_QSPI_BASE
CONFIG_SMDK5420
CONFIG_SOCRATES
CONFIG_SPI_ADDR
CONFIG_SPI_FLASH_QUAD
CONFIG_SPI_FLASH_SIZE
CONFIG_SPI_HALF_DUPLEX
CONFIG_SPI_N25Q256A_RESET
CONFIG_TEGRA_SLINK_CTRLS
CONFIG_TPM_TIS_BASE_ADDRESS
CONFIG_UBOOT_SECTOR_COUNT
CONFIG_UBOOT_SECTOR_START
CONFIG_VAR_SIZE_SPL
CONFIG_VERY_BIG_RAM
And also:
BL1_SIZE
PHY_NO
RESERVE_BLOCK_SIZE
TI's am62a family of SoCs uses a new 32bit DDR controller that shares
much of the same functionality with the existing am64 and j721e
controllers.
Select this controller by default when u-boot is build for the am62a
The new 32bit DDR controller for TI's am62a family of SoCs shares much
of the same functionality with the existing 16bit (am64) and 32bit
(j721e) controllers, so this patch reorganizes the existing
auto-generated macros for the 16bit and 32bit controllers to make room
for the macros for the am62a's controller
This patch consists mostly of header/macro renames and additions with a
new Kconfig option (K3_AM62A_DDRSS) allowing us to select these new
macros during compilation.
The rest of the unmigrated CONFIG symbols in the CONFIG_SYS_SDRAM
namespace do not easily transition to Kconfig. In many cases they likely
should come from the device tree instead. Move these out of CONFIG
namespace and in to CFG namespace.
Use macro to represent the RL and WL setting to ensure the PHY and
controller setting are aligned.
Review-by: Ryan Chen <ryan_chen@aspeedtech.com>
Signed-off-by: Dylan Hung <dylan_hung@aspeedtech.com>
Adjust the following settings to get better timing and signal quality.
1. write DQS/DQ delay
- 1e6e2304[0]
- 1e6e2304[15:8]
2. read DQS/DQ delay
- 0x1e6e0298[0]
- 0x1e6e0298[15:8]
3. CLK/CA timing
- 0x1e6e01a8[31]
4. Read and write termination
- change RTT_ROM from 40 ohm to 48 ohm (MR1[10:8])
- change RTT_PARK from disable to 48 ohm (MR5[8:6])
- change RTT_WR from 120 ohm to disable (MR2[11:9])
- change PHY ODT from 40 ohm to 80 ohm (0x1e6e0130[10:8])
Note1: Both DDR-PHY and DDR controller have their own registers for DDR4
Mode Registers (MR0~MR6). This patch introduces macros to synchronize
the MR value on both sides.
Note2: the waveform meansurement can be found in item #21 of Aspeed
AST26x0 Application note (AP note).
The condition "~data" in the if-statement is a typo. The original
intention is to poll if SDRAM_PHYCTRL0_INIT bit equals to 0. So use
"data == 0" for instead.
Besides, the bit[1] of "phy_status" register is hardwired to
SDRAM_PHYCTRL0_INIT (with inverse logic). Since SDRAM_PHYCTRL0_INIT has
already done, remove the unnecessary checking of phy_status[1].
Fixes: fde93143469f ("ram: aspeed: Add AST2600 DRAM control support")
RAM_PX30_DDR4 is for DDR4 support and not DDR3 so let's fix the typo.
Fixes: 2db36c64bd5a ("ram: rockchip: px30: add a config-based ddr selection")
Cc: Quentin Schulz <foss+uboot@0leil.net>
Signed-off-by: Quentin Schulz <quentin.schulz@theobroma-systems.com>
The i.MXRT11 series has different offsets for IOCR_MUX, it also can
address 64MiB of SDRAM so add a macro for that.
Signed-off-by: Jesse Taube <Mr.Bossman075@gmail.com>
Globally replace all occurances of WATCHDOG_RESET() with schedule(),
which handles the HW_WATCHDOG functionality and the cyclic
infrastructure.
Tested-by: Tom Rini <trini@konsulko.com> [am335x_evm, mx6cuboxi, rpi_3,dra7xx_evm, pine64_plus, am65x_evm, j721e_evm]
Currently the default initialisation frequency is 50MHz. Although
this does appear to be suitable for some LPDDR4 RAM chips, training at
this low frequency has been seen to cause Column errors, leading to
Capacity check errors on others.
Here we force RAM initialisation to happen at 400MHz before ramping up
to the final value running value of 800MHz after everything has been
successfully configured.
Link: https://lore.kernel.org/u-boot/Yo4v3jUeHXTovjOH@google.com/
Suggested-by: YouMin Chen <cym@rock-chips.com>
Signed-off-by: Lee Jones <lee@kernel.org>
Tested-by: Xavier Drudis Ferran <xdrudis@tinet.cat>
Tested-by: Michal Suchánek <msuchanek@suse.de>
Frequency changes to 400MHz are presently reported as:
lpddr4_set_rate_0: change freq to 400000000 mhz 0, 1
This is obviously wrong by 6 orders of magnitude.
Ensure frequency changes are reported accurately.
Functions pointed to by this op pointer can return non-zero values
indicating an error. Ensure any error value is propagated back up the
call-chain.
Only add the dram channel when we finally setup it successfully at the
last step.
Signed-off-by: Han Pengfei <pengphei@foxmail.com>
The first AM6x device was the AM654x, but being the first we named it
just AM6, since more devices have come out with this same prefix we
should switch it to the normal convention of using the full name of the
first compatibility device the series. This makes what device we are
talking about more clear and matches all the K3 devices added since.
Signed-off-by: Andrew Davis <afd@ti.com>
Tighten up symbol dependencies in a number of places. Ensure that a TPL
specific option has at least a direct dependency on TPL. In places
where it's clear that we depend on something more specific, use that
dependency instead.
Reported-by: Pali Rohár <pali@kernel.org>
Add support for new compatible "st,stm32mp13-ddr" to manage the
DDR sub system (Controller and PHY) in STM32MP13x SOC:
- only one AXI port
- support of 16 port output (MEMC_DRAM_DATA_WIDTH = 2)
The STM32MP15x SOC have 2 AXI ports and 32 bits support.
Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
Reviewed-by: Patrice Chotard <patrice.chotard@foss.st.com>
The AM62 SoC family is the follow on AM335x built on K3 Multicore SoC
architecture platform, providing ultra-low-power modes, dual display,
multi-sensor edge compute, security and other BOM-saving integration.
The AM62 SoC targets broad market to enable applications such as
Industrial HMI, PLC/CNC/Robot control, Medical Equipment, Building
Automation, Appliances and more.
Some highlights of this SoC are:
* Quad-Cortex-A53s (running up to 1.4GHz) in a single cluster.
Pin-to-pin compatible options for single and quad core are available.
* Cortex-M4F for general-purpose or safety usage.
* Dual display support, providing 24-bit RBG parallel interface and
OLDI/LVDS-4 Lane x2, up to 200MHz pixel clock support for 2K display
resolution.
* Selectable GPUsupport, up to 8GFLOPS, providing better user experience
in 3D graphic display case and Android.
* PRU(Programmable Realtime Unit) support for customized programmable
interfaces/IOs.
* Integrated Giga-bit Ethernet switch supporting up to a total of two
external ports (TSN capable).
* 9xUARTs, 5xSPI, 6xI2C, 2xUSB2, 3xCAN-FD, 3x eMMC and SD, GPMC for
NAND/FPGA connection, OSPI memory controller, 3xMcASP for audio,
1x CSI-RX-4L for Camera, eCAP/eQEP, ePWM, among other peripherals.
* Dedicated Centralized System Controller for Security, Power, and
Resource Management.
* Multiple low power modes support, ex: Deep sleep,Standby, MCU-only,
enabling battery powered system design.
AM625 is the first device of the family. Add DT bindings for the same.
More details can be found in the Technical Reference Manual:
Signed-off-by: Suman Anna <s-anna@ti.com>
Signed-off-by: Gowtham Tammana <g-tammana@ti.com>
Signed-off-by: Aswath Govindraju <a-govindraju@ti.com>
Signed-off-by: Nishanth Menon <nm@ti.com>
Enable DRAM ASR, auto self-refresh, conditionally, based on DT PWRCTL
register bits. While ASR does save considerable amount of power at
runtime automatically, it also causes LTDC underruns on large panels.
Let user select whether or not ASR is required or not, generally ASR
should be enabled on portable and battery operated devices.
Cc: Patrick Delaunay <patrick.delaunay@foss.st.com>
Cc: Patrice Chotard <patrice.chotard@foss.st.com>
Reviewed-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
Signed-off-by: Patrice Chotard <patrice.chotard@foss.st.com>
Allow device tree to provide ti,ddr-freq0 to be used as the initial DDR
frequency that is set for lpddr4 before initialization of the
controller. Make this optional and continue to use PLL bypass frequency
as is done currently if ti,ddr-freq0 is not provided.
Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
The k3-ddrss driver wants to configure the DDRSS_V2A_CTL_REG to reflect
the maximum possible SDRAM of 2 GB for AM64x (instead of the register's
default that says 8 GB, which the AM64x DDR controller wouldn't support).
The offset 0x20 was correct, but the register name DDRSS_V2A_R1_MAT_REG
was that of the next register at offset 0x24.
Signed-off-by: Dominic Rath <rath@ibv-augsburg.net>
Add rockchip rk3066 sdram driver
Signed-off-by: Paweł Jarosz <paweljarosz3691@gmail.com>
Signed-off-by: Johan Jonker <jbx6244@gmail.com>
Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Makes it possible to use 16-bit DDR memory.
