path: root/drivers/qe
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-09-15blk: Remove various places that do flush cache after readBin Meng
All these places seem to inherit the codes from the MMC driver where a FIXME was put in the comment. However the correct operation after read should be cache invalidate, not flush. The underlying drivers should be responsible for the cache operation. Remove these codes completely. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: York Sun <york.sun@nxp.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: York Sun <york.sun@nxp.com>
2017-09-11QE: Set QE_IRAM_READY after uploading firmwareZhao Qiang
QE_IRAM_READY should be set only after successfully uploading the firmware. Signed-off-by: Zhao Qiang <qiang.zhao@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-06-01QE: add QE support on SD bootZhao Qiang
modify u_qe_init to upload QE firmware from SD card when it is SD boot Signed-off-by: Zhao Qiang <qiang.zhao@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-04-17armv7: ls1021a: Drop macro CONFIG_LS102XAYork Sun
Use CONFIG_ARCH_LS1021A instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1025: Remove macro CONFIG_P1025York Sun
Replace CONFIG_P1025 with ARCH_P1025 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1021: Remove macro CONFIG_P1021York Sun
Replace CONFIG_P1021 with ARCH_P1021 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1012: Drop configuration for P1012York Sun
P1012 is a single-core version of P1021. There is no P1012 target configured. Drop related macros. P1012 SoC is still supported. Signed-off-by: York Sun <york.sun@nxp.com>
2016-09-23treewide: use #include <...> to include public headersMasahiro Yamada
We are supposed to use #include <...> to include headers in the public include paths. We should use #include "..." only for headers in local directories. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-15net: mii: Fix changes made by spatchJoe Hershberger
Some of the changes were a bit too complex. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-08-15net: mii: Use spatch to update miiphy_registerJoe Hershberger
Run scripts/coccinelle/net/mdio_register.cocci on the U-Boot code base. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-02-24board: ls1043ardb: Add micro QE support for ls1043ardbZhao Qiang
2016-02-24driver: qe: Mask the codes not used for micro QEZhao Qiang
there are some code in qe.c not used for micro QE, use "#ifdef CONFIG_QE" to mask them. Signed-off-by: Zhao Qiang <qiang.zhao@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-02-24qe: move drivers/qe/qe.h to include/fsl_qe.hQianyu Gong
As the QE firmware struct is shared with Fman, move the header file out of drivers/qe/. Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2015-08-03driver/qe: use strncpy instead of strcpyZhao Qiang
strncpy is safer than strcpy, use it to instead of strcpy. Signed-off-by: Zhao Qiang <B45475@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-08-03drivers/qe: transform parameter to compatible typeZhao Qiang
when using printf, the parameter type need to be compatible type, so transform them to compatible type Signed-off-by: Zhao Qiang <B45475@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-04-21QE/DeepSleep: add QE deepsleep support for mpc85xxZhao Qiang
Muram will power off during deepsleep, and the microcode of qe in muram will be lost, it should be reload when resume. Signed-off-by: Zhao Qiang <B45475@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-04-18net: cosmetic: Fix var naming net <-> eth driversJoe Hershberger
Update the naming convention used in the network stack functions and variables that Ethernet drivers use to interact with it. This cleans up the temporary hacks that were added to this interface along with the DM support. This patch has a few remaining checkpatch.pl failures that would be out of the scope of this patch to fix (drivers that are in gross violation of checkpatch.pl). Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-15qe/deep-sleep: modify qe deep-sleep for generic boardZhao Qiang
Deep sleep for generic board is supported now, modify qe deep-sleep code to adapt it. Signed-off-by: Zhao Qiang <B45475@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-19u_qe: add u_qe_upload_firmware for u_qeZhao Qiang
2014-11-19qe: add u-qe support to arm boardZhao Qiang
ls1021 is arm-core and support qe which is u-qe. add u-qe init for arm board. Signed-off-by: Zhao Qiang <B45475@freescale.com> [York Sun: Fix compiling error caused by u_qe_init()] Reviewed-by: York Sun <yorksun@freescale.com>
2014-09-08net: Merge asm/fsl_enet.h into fsl_mdio.hClaudiu Manoil
fsl_enet.h defines the mapping of the usual MII management registers, which are included in the MDIO register block common to Freescale ethernet controllers. So it shouldn't depend on the CPU architecture but it should be actually part of the arch independent fsl_mdio.h. To remove the arch dependency, merge the content of asm/fsl_enet.h into fsl_mdio.h. Some files (like fm_eth.h) were simply including fsl_enet.h only for phy.h. These were updated to include phy.h instead. Signed-off-by: Claudiu Manoil <claudiu.manoil@freescale.com>
2014-08-20driver/qe: update status of QE microcodeVijay Rai
This Patch updates error print for QE which should be easily understood Signed-off-by: Vijay Rai <vijay.rai@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-07-22qe: move immap_qe.h from arch directory into common directoryZhao Qiang
ls1021 is arm-core and supports qe too. Move immap_qe.h into common directory for both arm and powerpc. Signed-off-by: Zhao Qiang <B45475@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-05-13qe: disable qe when qe-ucode fails to be uploaded for "deep sleep"Zhao Qiang
when qe-ucode fails to be uploaded, "deep sleep" will hang. if there is no qe-ucode, disable qe module for platforms which support "deep sleep" Signed-off-by: Zhao Qiang <B45475@freescale.com>
2014-04-22QE/U-QE: Add U-QE supportZhao Qiang
Modify code to adapt to both u-qe and qe. U_QE is a kind of cutted QE. the differences between U_QE and QE 1. UCC: U_QE supports 2 UCCs while QE supports up to 8 UCCs. 2. IMMR: have different immr base addr. 3. iopin: U_QE doesn't need to config iopin. Signed-off-by: Zhao Qiang <B45475@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22QE/FMAN: modify CONFIG_SYS_QE_FMAN_FW_ADDR to CONFIG_SYS_FMAN_FW_ADDR and ↵Zhao Qiang
CONFIG_SYS_QE_FW_ADDR CONFIG_SYS_QE_FMAN_FW_ADDR is used to both Fman and QE for microcode address. Now using CONFIG_SYS_FMAN_FW_ADDR for Fman microcode address, and CONFIG_SYS_QE_FW_ADDR for QE microcode address. Signed-off-by: Zhao Qiang <B45475@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2013-11-17drivers/qe: move the entry to drivers/MakefileMasahiro Yamada
2013-10-31drivers: convert makefiles to Kbuild styleMasahiro Yamada
2013-02-04ppc: Move CONFIG_QE to arch_global_dataSimon Glass
Move the quantative easing fields into arch_global_data and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-01ppc: Move brg_clk to arch_global_dataSimon Glass
Move this field into arch_global_data and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-23mpc83xx: add support for mpc8309Gerlando Falauto
This processor, though very similar to other members of the PowerQUICC II Pro family (namely 8308, 8360 and 832x), provides yet another feature set than any supported sibling. Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-08-23powerpc/mpc8xxx: Remove P1015 and P1016 from CPU listYork Sun
P1015 is the same as P1011 and P1016 is the same as P1012 from software point of view. They have different packages but share SVRs. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-05-22drivers/qe/uec.c: Fix compile warningJoe Hershberger
Fix this: uec.c: In function 'uec_initialize': uec.c:1404:12: warning: assignment from incompatible pointer type Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-03-18net/miiphy/serial: drop duplicate "NAMESIZE" defineMike Frysinger
A few subsystems are using the same define "NAMESIZE". This has been working so far because they define it to the same number. However, I want to change the size of eth_device's NAMESIZE, so rather than tweak the define names, simply drop references to it. Almost no one does, and the handful that do can easily be changed to a sizeof(). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-11-29powerpc/85xx: clean up and document the QE/FMAN microcode macrosTimur Tabi
Several macros are used to identify and locate the microcode binary image that U-boot needs to upload to the QE or Fman. Both the QE and the Fman use the QE Firmware binary format to package their respective microcode data, which is why the same macros are used for both. A given SOC will only have a QE or an Fman, so this is safe. Unfortunately, the current macro definition and usage has inconsistencies. For example, CONFIG_SYS_FMAN_FW_ADDR was used to define the address of Fman firmware in NOR flash, but CONFIG_SYS_QE_FW_IN_NAND contains the address of NAND. There's no way to know by looking at a variable how it's supposed to be used. In the future, the code which uploads QE firmware and Fman firmware will be merged. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-11-11drivers/qe/uec.c: Fix GCC 4.6 build warningKumar Gala
uec.c: In function 'uec_stop': uec.c:267:22: warning: variable 'uccf' set but not used [-Wunused-but-set-variable] uec.c: In function 'uec_set_mac_if_mode': uec.c:328:15: warning: variable 'uec_info' set but not used [-Wunused-but-set-variable] uec.c: In function 'adjust_link': uec.c:519:11: warning: variable 'uec_regs' set but not used [-Wunused-but-set-variable] Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-20fsl: Change fsl_phy_enet_if to phy_interface_tAndy Fleming
The fsl_phy_enet_if enum was, essentially, the phy_interface_t enum. This meant that drivers which used fsl_phy_enet_if to deal with PHY interfaces would have to convert between the two (or we would have to have them mirror each other, and deal with the ensuing maintenance headache). Instead, we switch all clients of fsl_phy_enet_if over to phy_interface_t, which should become the standard, anyway. Signed-off-by: Andy Fleming <afleming@freescale.com> Acked-by: Detlev Zundel <dzu@denx.de>
2011-04-20Remove instances of phy_read/writeAndy Fleming
There were a few files which were already using phy_read and phy_write for their PHY function names. It's only a few places, and the name seems most appropriate for the high-level abstraction, so let's rename the other versions to something more specific. Also, uec_phy.c had a marvell_init function which I renamed to not conflict with the one in marvell.c Lastly, uec_phy.c was putting a space between the phy writing function names, and the open paren, so I fixed that Signed-off-by: Andy Fleming <afleming@freescale.com> Acked-by: Detlev Zundel <dzu@denx.de>
2011-04-05powerpc/85xx: Add P1021 specific QE and UEC supportHaiying Wang
P1021 has some QE pins which need to be set in pmuxcr register before using QE functions. In this patch, pin QE0 and QE3 are set for UCC1 and UCC5 in Eth mode. QE9 and QE12 are set for MII management. QE12 needs to be released after MII access because QE12 pin is muxed with LBCTL signal. Also added relevant QE support defines unique to P1021. The P1021 QE is shared on P1012, P1016, and P1025. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-25UEC: Fix compiler warnings introduced by linux/mii.h changeKumar Gala
Patch 8ef583a0 [miiphy: convert to linux/mii.h] introduced the following compiler warnings in the uec ethernet driver: In file included from /local/home/galak/git/u-boot-85xx/include/miiphy.h:37:0, from uec.c:32: /local/home/galak/git/u-boot-85xx/include/linux/mii.h:133:0: warning: "LPA_1000FULL" redefined uec_phy.h:34:0: note: this is the location of the previous definition /local/home/galak/git/u-boot-85xx/include/linux/mii.h:134:0: warning: "LPA_1000HALF" redefined uec_phy.h:35:0: note: this is the location of the previous definition In file included from /local/home/galak/git/u-boot-85xx/include/miiphy.h:37:0, from uec_phy.c:27: /local/home/galak/git/u-boot-85xx/include/linux/mii.h:133:0: warning: "LPA_1000FULL" redefined uec_phy.h:34:0: note: this is the location of the previous definition /local/home/galak/git/u-boot-85xx/include/linux/mii.h:134:0: warning: "LPA_1000HALF" redefined uec_phy.h:35:0: note: this is the location of the previous definition Fix them be removing the duplication in the uec code and utlizing the linux/mii.h version instead. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-09miiphy: convert to linux/mii.hMike Frysinger
The include/miiphy.h header duplicates a lot of things from linux/mii.h. So punt all the things that overlap to keep the API simple and to make merging between U-Boot and Linux simpler. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-18Exclude drivers/qe/fdt.c without CONFIG_QESebastien Carlier
Previously with archive libraries fdt.o was compiled and included in qe.a and then discarded by the linker. With partial linking this results in unresolved symbols, which this commit fixes. This commit also cleans up a now-useless conditional in fdt.c. Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com> Tested-by: Wolfgang Denk <wd@denx.de>
2010-10-20powerpc/fsl: Introduce common enum for PHY typesKumar Gala
Have a common enum for phy types that we use in the UCC driver. We will also use this enum for dealing with phy connection fixup in the device tree. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-11UEC PHY: Speed up initial PHY neg.Joakim Tjernlund
Instead of always performing an autoneg, check if the PHY already has a link and if it matches one of the requested modes. Initially only 100MbFD is optimized this way. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-10-11UEC PHY: Remove strange 0.5 sec delayJoakim Tjernlund
This udelay looks bogus and doesn't help my board. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se> Acked-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-10-11UEC: Don't udelay needlesslyJoakim Tjernlund
uec_init() adds an udelay(100000) even though the PHY status read went well, don't do that. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se> Acked-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
