path: root/drivers/qe
2008-01-14QE: fix compile warningDave Liu
qe.c: In function 'qe_upload_firmware': qe.c:390: warning: pointer targets in passing argument 2 uec.c: In function 'uec_initialize': uec.c:1236: warning: 'uec_info' may be used uninitialized Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-01-10Fix Ethernet init() return codesBen Warren
Change return values of init() functions in all Ethernet drivers to conform to the following: >=0: Success <0: Failure All drivers going forward should return 0 on success. Current drivers that return 1 on success were left as-is to minimize changes. Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-By: Timur Tabi <timur@freescale.com>
2008-01-10Coding Style cleanup; update CHANGELOGWolfgang Denk
2008-01-0985xx: add ability to upload QE firmwareTimur Tabi
Define the layout of a binary blob that contains a QE firmware and instructions on how to upload it. Add function qe_upload_firmware() to parse the blob and perform the actual upload. Add command-line command "qe fw" to take a firmware blob in memory and upload it. Update ft_cpu_setup() on 85xx to create the 'firmware' device tree node if U-Boot has uploaded a firmware. Fully define 'struct rsp' in immap_qe.h to include the actual RISC Special Registers. Signed-off-by: Timur Tabi <timur@freescale.com>
2008-01-08Add support CONFIG_UEC_ETH3 in MPC83xxJoakim Tjernlund
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2007-09-15Fix cases where DECLARE_GLOBAL_DATA_PTR was not declared as globalWolfgang Denk
2007-08-16Fix numerous bugs in the 8568 UEC supportAndy Fleming
Actually, fixed a large bug in the UEC for *all* platforms. How did this ever work? uec_init() did not follow the spec for eth_init(), and returned 0 on success. Switch it to return the link like tsec_init() (and 0 on error) The immap for the 8568 was defined based on MPC8568, rather than CONFIG_MPC8568 CONFIG_QE was off CONFIG_ETHPRIME was set to "Freescale GETH". Now is "FSL UEC0" Fixed a comment about the ranges for CONFIG_ETHPRIME if TSEC_ENET is enabled Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-14Add support for UEC to 8568Andy Fleming
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-10mpc83xx: Fix the align bug of SDMA bufferDave Liu
According to the latest user manual, the SDMA temporary buffer base address must be 4KB aligned. Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-03-02mpc83xx: Fix alternating tx error / tx buffer not ready bug in QE UECEmilian Medve
The problem is not gcc4 but the code itself. The BD_STATUS() macro can't be used for busy-waiting since it strips the 'volatile' property from the bd variable. gcc3 was working by pure luck. This is a follow on patch to "Fix the UEC driver bug of QE"
2007-03-02mpc83xx: Add support for the MPC832XEMDS boardDave Liu
This patch supports DUART, ETH3/4 and PCI etc. Signed-off-by: Dave Liu <daveliu@freescale.com>
2007-03-02mpc83xx: Fix the UEC driver bug of QEDave Liu
The patch prevents the GCC tool chain from striping useful code for optimization. It will make UEC ethernet driver workable, Otherwise the UEC will fail in tx when you are using gcc4.x. but the driver can work when using gcc3.4.3. CHANGELOG *Prevent the GCC from striping code for optimization, Otherwise the UEC will tx failed when you are using gcc4.x. Signed-off-by: Dave Liu <daveliu@freescale.com>
2006-11-30Code cleanup.Wolfgang Denk
2006-11-28Eliminate gcc 4 'used uninitialized' warnings in drivers/qe/uccf.cKim Phillips
give initial values for reg_num, shift, p_cmxucr in ucc_set_clk_src since they are passed by reference to ucc_get_cmxucr_reg and assigned.
2006-11-03mpc83xx: add QE ethernet supportDave Liu
this patch adds support for the QUICC Engine based UCC gigabit ethernet device.
