path: root/drivers/qe
2008-03-07net: uec_phy: actually increment the timeout counterKim Phillips
allow u-boot to recover (and, e.g., switch to another interface) in the case where a PHY does not report autonegotiation is complete within its two second timeout value. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-03-03fix QE firmware uploading limitTimur Tabi
Fix a typo in qe_upload_firmware() that prevented uploading firmware on systems with more than one RISC core. Signed-off-by: Timur Tabi <timur@freescale.com>
2008-03-02net: uec_phy: handle 88e1111 rev.B2 erratum 5.6Kim Phillips
erratum 5.6 states the autoneg completion bit is functional only if the autoneg bit is asserted. This fixes any secondarily-issued networking commands on non-gigabit links on the mpc8360 mds board. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-02-12QE: Move FDT support into a common fileKumar Gala
Move the flat device tree setup for QE related devices into a common file shared between 83xx & 85xx platforms that have QE's. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-16Remove annoying debug printout for PHY less boards.Joakim Tjernlund
PHY less board prints out lots of "read wrong ...": read wrong value : mii_id 3,mii_reg 2, base e0102320 read wrong value : mii_id 3,mii_reg 3, base e0102320 UEC: PHY is Generic MII (ffffffff) read wrong value : mii_id 3,mii_reg 4, base e0102320 read wrong value : mii_id 3,mii_reg 0, base e0102320 read wrong value : mii_id 3,mii_reg 1, base e0102320 read wrong value : mii_id 3,mii_reg 1, base e0102320 read wrong value : mii_id 3,mii_reg 5, base e0102320 read wrong value : mii_id 3,mii_reg 1, base e0102320 read wrong value : mii_id 3,mii_reg 1, base e0102320 read wrong value : mii_id 3,mii_reg 5, base e0102320 FSL UEC0: Full Duplex FSL UEC0: Speed 100BT FSL UEC0: Link is up Using FSL UEC0 device Make this printout depend on UEC_VERBOSE_DEBUG and remove its definition in uec_phy.c Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-01-16net: reduce boot latency on QE UEC based boardsKim Phillips
actually polling for PHY autonegotiation to finish enables us to remove the 5 second boot prompt latency present on QE based boards. call to qe_set_mii_clk_src in init_phy, and mv call to init_phy from uec_initialize to uec_init by Joakim Tjernlund; autonegotiation wait code shamelessly stolen from tsec driver. also rm unused CONFIG_RMII_MODE code. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-01-15QE UEC: Extend number of supported UECs to 4David Saada
This patch extends the number of supported UECs to 4. Note that the problem of QE thread resources exhaustion is resolved by setting the correct number of QE threads according to Ethernet type (GBE or FE). Signed-off-by: David Saada <david.saada@ecitele.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-01-14QE: fix compile warningDave Liu
qe.c: In function 'qe_upload_firmware': qe.c:390: warning: pointer targets in passing argument 2 uec.c: In function 'uec_initialize': uec.c:1236: warning: 'uec_info' may be used uninitialized Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-01-10Fix Ethernet init() return codesBen Warren
Change return values of init() functions in all Ethernet drivers to conform to the following: >=0: Success <0: Failure All drivers going forward should return 0 on success. Current drivers that return 1 on success were left as-is to minimize changes. Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-By: Timur Tabi <timur@freescale.com>
2008-01-10Coding Style cleanup; update CHANGELOGWolfgang Denk
2008-01-0985xx: add ability to upload QE firmwareTimur Tabi
Define the layout of a binary blob that contains a QE firmware and instructions on how to upload it. Add function qe_upload_firmware() to parse the blob and perform the actual upload. Add command-line command "qe fw" to take a firmware blob in memory and upload it. Update ft_cpu_setup() on 85xx to create the 'firmware' device tree node if U-Boot has uploaded a firmware. Fully define 'struct rsp' in immap_qe.h to include the actual RISC Special Registers. Signed-off-by: Timur Tabi <timur@freescale.com>
2008-01-08Add support CONFIG_UEC_ETH3 in MPC83xxJoakim Tjernlund
2007-09-15Fix cases where DECLARE_GLOBAL_DATA_PTR was not declared as globalWolfgang Denk
2007-08-16Fix numerous bugs in the 8568 UEC supportAndy Fleming
Actually, fixed a large bug in the UEC for *all* platforms. How did this ever work? uec_init() did not follow the spec for eth_init(), and returned 0 on success. Switch it to return the link like tsec_init() (and 0 on error) The immap for the 8568 was defined based on MPC8568, rather than CONFIG_MPC8568 CONFIG_QE was off CONFIG_ETHPRIME was set to "Freescale GETH". Now is "FSL UEC0" Fixed a comment about the ranges for CONFIG_ETHPRIME if TSEC_ENET is enabled Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-14Add support for UEC to 8568Andy Fleming
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-10mpc83xx: Fix the align bug of SDMA bufferDave Liu
According to the latest user manual, the SDMA temporary buffer base address must be 4KB aligned. Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-03-02mpc83xx: Fix alternating tx error / tx buffer not ready bug in QE UECEmilian Medve
The problem is not gcc4 but the code itself. The BD_STATUS() macro can't be used for busy-waiting since it strips the 'volatile' property from the bd variable. gcc3 was working by pure luck. This is a follow on patch to "Fix the UEC driver bug of QE"
2007-03-02mpc83xx: Add support for the MPC832XEMDS boardDave Liu
This patch supports DUART, ETH3/4 and PCI etc. Signed-off-by: Dave Liu <daveliu@freescale.com>
2007-03-02mpc83xx: Fix the UEC driver bug of QEDave Liu
The patch prevents the GCC tool chain from striping useful code for optimization. It will make UEC ethernet driver workable, Otherwise the UEC will fail in tx when you are using gcc4.x. but the driver can work when using gcc3.4.3. CHANGELOG *Prevent the GCC from striping code for optimization, Otherwise the UEC will tx failed when you are using gcc4.x. Signed-off-by: Dave Liu <daveliu@freescale.com>
2006-11-30Code cleanup.Wolfgang Denk
2006-11-28Eliminate gcc 4 'used uninitialized' warnings in drivers/qe/uccf.cKim Phillips
give initial values for reg_num, shift, p_cmxucr in ucc_set_clk_src since they are passed by reference to ucc_get_cmxucr_reg and assigned.
2006-11-03mpc83xx: add QE ethernet supportDave Liu
this patch adds support for the QUICC Engine based UCC gigabit ethernet device.
