path: root/drivers/qe/uec_phy.h
2011-01-25UEC: Fix compiler warnings introduced by linux/mii.h changeKumar Gala
Patch 8ef583a0 [miiphy: convert to linux/mii.h] introduced the following compiler warnings in the uec ethernet driver: In file included from /local/home/galak/git/u-boot-85xx/include/miiphy.h:37:0, from uec.c:32: /local/home/galak/git/u-boot-85xx/include/linux/mii.h:133:0: warning: "LPA_1000FULL" redefined uec_phy.h:34:0: note: this is the location of the previous definition /local/home/galak/git/u-boot-85xx/include/linux/mii.h:134:0: warning: "LPA_1000HALF" redefined uec_phy.h:35:0: note: this is the location of the previous definition In file included from /local/home/galak/git/u-boot-85xx/include/miiphy.h:37:0, from uec_phy.c:27: /local/home/galak/git/u-boot-85xx/include/linux/mii.h:133:0: warning: "LPA_1000FULL" redefined uec_phy.h:34:0: note: this is the location of the previous definition /local/home/galak/git/u-boot-85xx/include/linux/mii.h:134:0: warning: "LPA_1000HALF" redefined uec_phy.h:35:0: note: this is the location of the previous definition Fix them be removing the duplication in the uec code and utlizing the linux/mii.h version instead. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-09miiphy: convert to linux/mii.hMike Frysinger
The include/miiphy.h header duplicates a lot of things from linux/mii.h. So punt all the things that overlap to keep the API simple and to make merging between U-Boot and Linux simpler. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-10-18Change UEC PHY interface to RGMII on MPC8568MDSHaiying Wang
Change UEC phy interface from GMII to RGMII on MPC8568MDS board Because on MPC8568MDS, GMII interface is only recommended for 1000Mbps speed, but RGMII interface can work at 10/100/1000Mbps, and RGMII interface works more stable. Now both UEC1 and UEC2 can work properly under u-boot. It is also in consistent with the kernel setting for 8568 UEC phy interface. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-03-25uec: add support for gbit mii status readingsAnton Vorontsov
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
2007-08-14Add support for UEC to 8568Andy Fleming
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2006-11-30Code cleanup.Wolfgang Denk
2006-11-03mpc83xx: add QE ethernet supportDave Liu
this patch adds support for the QUICC Engine based UCC gigabit ethernet device.
