path: root/drivers/qe/uccf.c
2016-09-23treewide: use #include <...> to include public headersMasahiro Yamada
We are supposed to use #include <...> to include headers in the public include paths. We should use #include "..." only for headers in local directories. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-02-24qe: move drivers/qe/qe.h to include/fsl_qe.hQianyu Gong
As the QE firmware struct is shared with Fman, move the header file out of drivers/qe/. Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2014-07-22qe: move immap_qe.h from arch directory into common directoryZhao Qiang
ls1021 is arm-core and supports qe too. Move immap_qe.h into common directory for both arm and powerpc. Signed-off-by: Zhao Qiang <B45475@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2008-08-13drivers/qe: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2006-11-30Code cleanup.Wolfgang Denk
2006-11-28Eliminate gcc 4 'used uninitialized' warnings in drivers/qe/uccf.cKim Phillips
give initial values for reg_num, shift, p_cmxucr in ucc_set_clk_src since they are passed by reference to ucc_get_cmxucr_reg and assigned.
2006-11-03mpc83xx: add QE ethernet supportDave Liu
this patch adds support for the QUICC Engine based UCC gigabit ethernet device.
