path: root/drivers/pwm/Makefile
2016-05-25exynos: pwm: Add a driver for the exynos5 PWMSimon Glass
This driver supports the standard PWM API. There are 5 PWMs. Four are used normally and the last is normally used as a timer. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2016-02-16tegra: pwm: Add a driver for the tegra PWMSimon Glass
This PWM supports four channels. The driver always uses the 32KHz clock, and adjusts the duty cycle accordingly. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-01-21pwm: rockchip: Add a PWM driver for Rockchip SoCsSimon Glass
Add a simple driver which implements the standard PWM uclass interface. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21dm: pwm: Add a PWM uclassSimon Glass
Add a uclass that supports Pulse Width Modulation (PWM) devices. It provides methods to enable/disable and configure the device. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-07-23pwm, imx6: add support for pwm modul on imx6Heiko Schocher
add basic support for the pwm modul found on imx6. Pieces of this code are based on linux code from drivers/pwm/pwm-imx.c Commit "cd3de83f1476 Linux 3.16-rc4" Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de>
