We use 'priv' for private data but often use 'platdata' for platform data.
We can't really use 'pdata' since that is ambiguous (it could mean private
or platform data).
Rename some of the latter variables to end with 'plat' for consistency.
Move this header out of the common header.
The RK809 is a Power Management IC (PMIC) for multimedia
and handheld devices. They contains the following components:
- Regulators(5*BUCKs, 9*LDOs, 2*SWITCHes)
- RTC
- Clocking
Signed-off-by: Joseph Chen <chenjh@rock-chips.com>
Signed-off-by: Elaine Zhang <zhangqing@rock-chips.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
The RK817 is a Power Management IC (PMIC) for multimedia
- Regulators(4*BUCKs, 1* BOOST, 9*LDOs, 1*SWITCH)
- RTC
- Clocking
The RK805 are a Power Management IC (PMIC) for multimedia
- Regulators(4*BUCKs, 3*LDOs)
- RTC
- Clocking
The RK816 is a Power Management IC (PMIC) for multimedia
- Regulators(4*BUCKs, 1*BOOST, 6*LDOs, 1*SWITCH)
- RTC
- Clocking
In order to adapt the following pmics, make the interface more compatible.
Support buck and ldo suspend voltage setting and getting.
Supprot buck and ldo suspend enable/disable setting and getting.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
get_enable should be able to return error values. Hence change
the return type to integer.
Signed-off-by: Keerthy <j-keerthy@ti.com>
The RK818 PMIC contains a charger. Add very basic charger functionality
to be able to regulate the USB input current and charger shutdown limits.
Signed-off-by: Wadim Egorov <w.egorov@phytec.de>
Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Enabling CONFIG_SPL_POWER_SUPPORT will cause a compiler warning:
‘get_ldo_reg’ defined but not used [-Wunused-function]
Let's wrap get_ldo_reg(), rk808_ldo and rk818_ldo with ENABLE_DRIVER
which is only set for non SPL builds.
Till now get_ldo_reg did a return &rk808_ldo[num - 1]; to return
the ldo register offset but didn't take into account that its
calling functions already created the ldo as ldo = dev->driver_data - 1.
This resulted in the setting for ldo8 writing to the register of ldo7
and so on. So fix this and get the correct ldo register data.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Since this driver can be used for rk8xx series pmic,
let's rename rk808 to rk8xx, to make it clear.
Configs parts are done by sed -i "s/RK808/RK8XX/g" `grep RK808 -lr ./`
Signed-off-by: Jacob Chen <jacob-chen@iotwrt.com>
