path: root/drivers/power/power_spi.c
2017-01-11power: change from meaningless value to error numberJaehoon Chung
'-1' is absolutely meaningless value. This patch changed from meaningless value to error number. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-11-07power_spi.c: Rewrite pmic_reg functionTom Rini
The pmic_spi_free function isn't ever used, and as the frameworks stand today, cannot be, so remove it. Integrate the probe function into pmic_reg as it's not really a "probe" today. Finally, add an err label for the common failure cases. Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Stefano Babic <sbabic@denx.de> Signed-off-by: Tom Rini <trini@ti.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-11-14power:pmic: Rename ./drivers/power/pmic_* to ./drivers/power/power_* filesƁukasz Majewski
Rename pmic/power related files at ./drivers/power directory Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Stefano Babic <sbabic@denx.de>
