path: root/drivers/power/pmic
2019-06-11regulator: bd71837: copy the bd71837 pmic driver from NXP imx u-bootMatti Vaittinen
https://source.codeaurora.org/external/imx/uboot-imx cherry picked, styled and merged commits: - MLK-18387 pmic: Add pmic driver for BD71837: e9a3bec2e95a - MLK-18590 pmic: bd71837: Change to use new fdt API: acdc5c297a96 Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Matti Vaittinen <matti.vaittinen@fi.rohmeurope.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-04-12stpmic1: add NVM update support in fuse commandPatrick Delaunay
Add functions to read/update the non volatile memory of STPMIC1 (8 bytes-register at 0xF8 address) and allow access with fuse command (bank=1, word > 0xF8). For example: STM32MP> fuse read 1 0xf8 8 Reading bank 1: Word 0x000000f8: 000000ee 00000092 000000c0 00000002 Word 0x000000fc: 000000f2 00000080 00000002 00000033 Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-04-12pmic: stpmu1: add power switch off supportPatrick Delaunay
Add sysreset support, and support power switch off request, needed by poweroff command. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-04-12power: rename stpmu1 to official name stpmic1Patrick Delaunay
Alignment with kernel driver name & binding introduced by https://patchwork.kernel.org/cover/10761943/ to use the final marketing name = STPMIC1. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2019-04-12power: stpmu1: rename files to stpmic1Patrick Delaunay
Prepare file modification for kernel alignment and rename driver to stpmic1. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2018-12-10Merge tag 'for-master-20181210' of git://git.denx.de/u-boot-rockchipTom Rini
Improvements: - init DRAM for RK322x in SPL - add FAN53555 PMIC/regulator driver - update MicroCrystal RV3029 driver to Kconfig and sync from Linux - add bootcount uclass and first DM-driver for bootcount
2018-12-10power: add FAN53555 family supportPhilipp Tomsich
This adds a driver for the FAN53555 family of regulators and wraps it in a PMIC implementation. While these devices support a 'normal' and 'suspend' mode (controlled via an external pin) to switch between two programmable voltages, this incarnation of the driver assumes that the device is always operating in 'normal' mode. Only setting/reading the programmed voltage is supported at this time and the following device functionality remains unsupported: - switching the selected voltage (via a GPIO) - disabling the voltage output via software-control This matches the functionality of the Linux driver. Tested on a RK3399-Q7 (with 'option 5' devices): setting voltages from the U-Boot shell and verifying output voltages on the board. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Tested-by: Klaus Goger <klaus.goger@theobroma-systems.com>
2018-12-10power: make most tps drivers and the twl4030 driver compatible with DM_I2CJean-Jacques Hiblot
Those driver are not DM drivers per se (not using the PMIC/regulator framework) and are using the legacy I2C API. Make them compatible with the DM_I2C API. This impacts the following drivers: - palmas (used by am57xx/dra7xx evms) - tps65218 (used by am43xx evms) - tps65217 and tps65910 (used by am335x evms and am335x boneblack vboot) - twl4030 (used by omap3_logicpd) - tps65217 (used by brppt1) - twl6030 Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2018-11-29dm: sandbox: i2c: Use new emulator parent uclassSimon Glass
Update the device tree, sandbox i2c driver and tests to use the new emulation parent to hold emulators. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-29power: pmic: Correct debug/error outputSimon Glass
There is a newline missing from quite a few printf() strings in these pmic files. Fix them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2018-07-30Kconfig: Remove trailing whitespaces in promptMichal Simek
Remove additional trailing whitespaces in prompt reported by kconfiglib: warning: DM_PMIC_SANDBOX (defined at drivers/power/pmic/Kconfig:133) has leading or trailing whitespace in its prompt warning: <choice> (defined at dts/Kconfig:204) has leading or trailing whitespace in its prompt Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Felix Brack <fb@ltec.ch>
2018-06-27power: pmic: Let PFUZE3000 see all 256 registersTrent Piepho
The PFUZE3000 uses registers addresses up to 0xff. The DM pfuze100 driver supports both pfuze100 and pfuze3000. Allow it to use the device type to return the correct number of registers. Also rename the too generic PMIC_NUM_OF_REGS enumeration value for pfuze3000 to match the other "PFUZE3000_" prefixed enumerations and the pfuze100 enumeration value PFUZE100_NUM_OF_REGS. Cc: Peng Fan <Peng.Fan@freescale.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Trent Piepho <tpiepho@impinj.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2018-05-18sandbox: Rewrite i2c_pmic_emul.c to support PMIC with 3 bytes transmissionLukasz Majewski
This change enables support for MC34708 PMIC in sandbox. Now we can emulate the I2C transfers larger than 1 byte. Notable changes for this driver: - From now on the register number is not equal to index in the buffer, which emulates the PMIC registers - The PMIC register's pool is now dynamically allocated up till 64 regs * 3 bytes each = 192 B Signed-off-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-18pmic: dm: Add support for MC34708 for PMIC DMLukasz Majewski
This patch adds support for MC34708 PMIC, to be used with driver model (DM). Signed-off-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-18pmic: dm: Rewrite pmic_reg_{read|write|clrsetbits} to support 3 bytes ↵Lukasz Majewski
transmissions This commit provides support for transmissions larger than 1 byte for PMIC devices used with DM (e.g. MC34708 from NXP). Signed-off-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-18pmic: Add support for setting transmission length in uclass private dataLukasz Majewski
The struct uc_pmic_priv's trans_len field stores the number of types to be transmitted per PMIC transfer. Signed-off-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-08Merge git://git.denx.de/u-boot-mmcTom Rini
2018-05-08power: pmic: stpmu1: Add regulator bindingsPatrice Chotard
Add regulator bindings to get access to regulator managed by drivers/power/regulator/stpmu1.c regulator driver. Signed-off-by: Christophe Kerello <christophe.kerello@st.com> Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-05-08power: pmic_max77686: remove the old pmic_max77686 fileJaehoon Chung
max77686 pmic is supporting with max77686.c under pmic/ and regulator/ direnctroy. Remove pmic_max77686.c what didn't use anywhere. Instead, enable CONFIG_DM_REGULATOR_MAX77686 and CONFIG_DM_PMIC_MAX77686. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
2018-05-07SPDX: Convert all of our multiple license tags to Linux Kernel styleTom Rini
When U-Boot started using SPDX tags we were among the early adopters and there weren't a lot of other examples to borrow from. So we picked the area of the file that usually had a full license text and replaced it with an appropriate SPDX-License-Identifier: entry. Since then, the Linux Kernel has adopted SPDX tags and they place it as the very first line in a file (except where shebangs are used, then it's second line) and with slightly different comment styles than us. In part due to community overlap, in part due to better tag visibility and in part for other minor reasons, switch over to that style. This commit changes all instances where we have multiple licenses (in these cases, dual license) declared in the SPDX-License-Identifier tag. In this case we change from listing "LICENSE-A LICENSE-B" or "LICENSE-A or LICENSE-B" or "(LICENSE-A OR LICENSE-B)" to "LICENSE-A OR LICENSE-B" as per the Linux Kernel style document. Note that parenthesis are allowed so when they were used before we continue to use them. Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-03-19pmic: add stpmu1 supportPatrick Delaunay
This driver implements register read/write operations for STPMU1. The STPMU1 PMIC provides 4 BUCKs, 6 LDOs, 1 VREF and 2 power switches. It is accessed via an I2C interface. This device is used with STM32MP1 SoCs. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-02-04power: pmic/regulator allow dm be omitted by SPLPeng Fan
Allow the dm driver be omitted by SPL. Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Stefano Babic <sbabic@denx.de> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2018-01-24power: pmic: s2mps11: probe the regulator driverJaehoon Chung
Add the probe function to support the s2mps11 regulator driver. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Anand Moon <linux.amoon@gmail.com>
2018-01-01power: tps65910: replace error() by pr_err()Felix Brack
The patch replaces the former error() by the new pr_err(). This makes the TPS65910 driver conform to Masahiro's patch 'treewide:replace with error() with pr_err()' introduced October 2017. Signed-off-by: Felix Brack <fb@ltec.ch> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-12-12power: pmic/regulator: Add basic support for TPS65910Felix Brack
Texas Instrument's TPS65910 PMIC contains 3 buck DC-DC converts, one boost DC-DC converter and 8 LDOs. This patch implements driver model support for the TPS65910 PMIC and its regulators making the get/set API for regulator value/enable available. This patch depends on the patch "am33xx: Add a function to query MPU voltage in uV" to build correctly. For boards relying on the DT include file tps65910.dtsi the v3 patch "power: extend prefix match to regulator-name property" and an appropriate regulator naming is also required. Signed-off-by: Felix Brack <fb@ltec.ch> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-12-12power: extend prefix match to regulator-name propertyFelix Brack
This patch extends pmic_bind_children prefix matching. In addition to the node name the property regulator-name is used while trying to match prefixes. This allows assigning different drivers to regulator nodes named regulator@1 and regulator@10 for example. I have discarded the idea of using other properties then regulator-name as I do not see any benefit in using property compatible or even regulator-compatible. Of course I am open to change this if there are good reasons to do so. Signed-off-by: Felix Brack <fb@ltec.ch> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-04treewide: replace with error() with pr_err()Masahiro Yamada
U-Boot widely uses error() as a bit noisier variant of printf(). This macro causes name conflict with the following line in include/linux/compiler-gcc.h: # define __compiletime_error(message) __attribute__((error(message))) This prevents us from using __compiletime_error(), and makes it difficult to fully sync BUILD_BUG macros with Linux. (Notice Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().) Let's convert error() into now treewide-available pr_err(). Done with the help of Coccinelle, excluing tools/ directory. The semantic patch I used is as follows: // <smpl> @@@@ -error +pr_err (...) // </smpl> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Re-run Coccinelle] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-18rockchip: rk8xx: remove unused header includesPhilipp Tomsich
Remove header file includes that have been left over after the conversion to livetree-support. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-09-11dm: core: Add ofnode_for_each_subnode()Simon Glass
Add a convenience macro to iterate over subnodes of a node. Make use of this where appropriate in the code. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-28dm: power: Convert as3722 to driver modelSimon Glass
Convert this PMIC driver to driver model and fix up other users. The regulator and GPIO functions are now handled by separate drivers. Update nyan-big to work correct. Three boards will need to be updated by the maintainers: apalis-tk1, cei-tk1-som. Also the TODO in the code re as3722_sd_set_voltage() needs to be completed. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Tested-on: Jetson-TK1 Tested-by: Stephen Warren <swarren@nvidia.com>
2017-07-28power: Add a GPIO driver for the as3722 PMICSimon Glass
This pmic includes GPIOs which should have their own driver. Add a driver to support these. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Tested-on: Beaver, Jetson-TK1 Tested-by: Stephen Warren <swarren@nvidia.com>
2017-06-09power: pmic: lp87565: Add the basic pmic supportKeerthy
Add support to bind the regulators/child nodes with the pmic. Signed-off-by: Keerthy <j-keerthy@ti.com> Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
2017-06-09power: pmic: tps65218: Add DCDC3 configurationKeerthy
Some boards like am437x-gp-evm require dcdc3 also to be configured as it feeds on to ddr. Hence add the capability as well. Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-06-07rockchip: rk8xx: allocate priv structure for driverKever Yang
The rk8xx_priv structure need to allocate for driver, or else it will cause data abort when CPU access it. This is a bug fix for below patch set: https://www.mail-archive.com/u-boot@lists.denx.de/msg247345.html Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: gpio: power: Convert pm8916 drivers to livetreeSimon Glass
This PMIC driver (power and GPIO) is used by the sandbox SPMI tests. Update the drivers to support a live device tree so that the tests pass. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01sandbox: pmic: Convert pmic emulator to support livetreeSimon Glass
Update this driver to support a live device tree. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: pmic: Convert uclass to livetreeSimon Glass
Update the pmic uclass and all pmics to support a live device tree. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: Rename dev_addr..() functionsSimon Glass
These support the flat device tree. We want to use the dev_read_..() prefix for functions that support both flat tree and live tree. So rename the existing functions to avoid confusion. In the end we will have: 1. dev_read_addr...() - works on devices, supports flat/live tree 2. devfdt_get_addr...() - current functions, flat tree only 3. of_get_address() etc. - new functions, live tree only All drivers will be written to use 1. That function will in turn call either 2 or 3 depending on whether the flat or live tree is in use. Note this involves changing some dead code - the imx_lpi2c.c file. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-29power: pmic: tps65218: Fix tps65218_voltage_update functionKeerthy
Currently while setting the vsel value for dcdc1 and dcdc2 the driver is wrongly masking the entire 8 bits in the process clearing PFM (bit7) field as well. Hence describe an appropriate mask for vsel field and modify only those bits in the vsel mask. Source: http://www.ti.com/lit/ds/symlink/tps65218.pdf Signed-off-by: Keerthy <j-keerthy@ti.com> Fixes: 86db550b38 ("power: Add support for the TPS65218 PMIC") Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2017-05-10power: rk808: rename to rk8xxJacob Chen
Since this driver can be used for rk8xx series pmic, let's rename rk808 to rk8xx, to make it clear. Configs parts are done by sed -i "s/RK808/RK8XX/g" `grep RK808 -lr ./` Signed-off-by: Jacob Chen <jacob-chen@iotwrt.com>
2017-05-10power: pmic: rk808: add RK818 supportJacob Chen
The RK818 chip is a Power Management IC (PMIC) for multimedia and handheld devices. For boards use rk818, the input current should be set in the early stage, before ddr initialization. Signed-off-by: Jacob Chen <jacob-chen@iotwrt.com>
2017-04-30power: Convert CONFIG_PMIC_AS3722 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_PMIC_AS3722 Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-30power: Move as3722 pmic to pmic/ directorySimon Glass
Most of the PMICs are in the drivers/power/pmic/ directory. Move this one there. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-02-09power: pmic: add the max8997 controller for DMJaehoon Chung
Add the max8997 controller for Driver model. Exynos4210 is using max8997 pmic controller. (pmic_max8997.c should be deprecated.) Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-02-08dm: core: Replace of_offset with accessorSimon Glass
At present devices use a simple integer offset to record the device tree node associated with the device. In preparation for supporting a live device tree, which uses a node pointer instead, refactor existing code to access this field through an inline function. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-19Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2017-01-18pmic: pmic_mc34vr500: Add a driver for the mc34vr500 pmicHou Zhiqiang
This patch adds a simple pmic driver for the mc34vr500 pmic which is used in conjunction with the fsl T1 and LS1 series SoC. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: York Sun <york.sun@nxp.com>
