This commit does the same thing as Linux commit 33def8498fdd.
Use a more generic form for __section that requires quotes to avoid
complications with clang and gcc differences.
Remove the quote operator # from compiler_attributes.h __section macro.
Convert all unquoted __section(foo) uses to quoted __section("foo").
Also convert __attribute__((section("foo"))) uses to __section("foo")
even if the __attribute__ has multiple list entry forms.
Signed-off-by: Marek Behún <marek.behun@nic.cz>
Use CONFIG_IS_ENABLED() macro, which provides more convenient
way to check $(SPL)DM_I2C/$(SPL)DM_I2C_GPIO configs
for both SPL and U-Boot proper.
CONFIG_IS_ENABLED(DM_I2C) expands to:
- 1 if CONFIG_SPL_BUILD is undefined and CONFIG_DM_I2C is set to 'y',
- 1 if CONFIG_SPL_BUILD is defined and CONFIG_SPL_DM_I2C is set to 'y',
- 0 otherwise.
All occurences were replaced automatically using these bash cmds:
$ find . -type f -exec sed -i
's/ifndef CONFIG_DM_I2C/if !CONFIG_IS_ENABLED(DM_I2C)/g' {} +
's/ifdef CONFIG_DM_I2C/if CONFIG_IS_ENABLED(DM_I2C)/g' {} +
's/defined(CONFIG_DM_I2C)/CONFIG_IS_ENABLED(DM_I2C)/g' {} +
's/ifndef CONFIG_DM_I2C_GPIO/if !CONFIG_IS_ENABLED(DM_I2C_GPIO)/g' {} +
's/ifdef CONFIG_DM_I2C_GPIO/if CONFIG_IS_ENABLED(DM_I2C_GPIO)/g' {} +
's/defined(CONFIG_DM_I2C_GPIO)/CONFIG_IS_ENABLED(DM_I2C_GPIO)/g' {} +
Signed-off-by: Igor Opaniuk <igor.opaniuk@foundries.io>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
Those driver are not DM drivers per se (not using the PMIC/regulator
framework) and are using the legacy I2C API. Make them compatible with
the DM_I2C API.
This impacts the following drivers:
- palmas (used by am57xx/dra7xx evms)
- tps65218 (used by am43xx evms)
- tps65217 and tps65910 (used by am335x evms and am335x boneblack vboot)
- twl4030 (used by omap3_logicpd)
- tps65217 (used by brppt1)
- twl6030
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Some boards like am437x-gp-evm require dcdc3 also to be configured
as it feeds on to ddr. Hence add the capability as well.
Signed-off-by: Keerthy <j-keerthy@ti.com>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
Currently while setting the vsel value for dcdc1 and dcdc2
the driver is wrongly masking the entire 8 bits in the process
clearing PFM (bit7) field as well. Hence describe an appropriate
mask for vsel field and modify only those bits in the vsel
mask.
Source: http://www.ti.com/lit/ds/symlink/tps65218.pdf
Fixes: 86db550b38 ("power: Add support for the TPS65218 PMIC")
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Now, arch/${ARCH}/include/asm/errno.h and include/linux/errno.h have
the same content. (both just wrap <asm-generic/errno.h>)
Replace all include directives for <asm/errno.h> with <linux/errno.h>.
[trini: Fixup include/clk.]
Add the following functions:
tps65218_reg_read() for accessing redisters
tps65218_toggle_fseal() for toggling the fseal bit
tps65218_lock_fsea() for locking the fseal bit to 1
Add the following defines:
All status register bits
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
Add in an init function for the drivers/power framework so we can dump
and read the registers via i2c.
Cc: Łukasz Majewski <l.majewski@samsung.com>
Add a driver for the TPS65218 PMIC which is used by TI AM43xx SoCs and
may be used by TI AM335x SoCs.
