path: root/drivers/power/fuel_gauge/fg_max17042.c
2014-01-14fuelgauge: max17042: fix i2c read issue which causes infinity loop.Przemyslaw Marczak
Issues: - reading i2c data by passing u16 pointer causes errors in read data. - max17042 status register fields have not only Power On Reset meaning so using proper mask is required. Changes: - read i2c data to type u32 instead of u16 - avoids buffer overflow - compare FG status register using mask not just one bit value - add checking return value to functions fg read/write - add model lock and model check count - add debug msg Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com>
2012-11-14pmic:fuel-gauge: Support for MAX17042 fuel-gaugeƁukasz Majewski
Support for MAX17042 fuel-gauge (FG), which is built into the MAX8997 power management device. Special file - fg_battery_cell_params.h with cells characteristics added. The FG device will work with redesigned PMIC framework. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Stefano Babic <sbabic@denx.de>
