ALDO2 is used to power LPDDR2 SDRAM on both the reference design and the
Hummingbird A31, when this type of RAM is present.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Acked-by: Hans de Goede <hdegoede@redhat.com>
Explicitly turn off unused voltages, rather then leaving them as is. Likewise
explictly enabled the dcdc convertors, rather then assuming they are already
enabled at boot.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
The dcdc1 voltage is typically used as generic 3.3V IO voltage for things like
GPIO-s, sdcard interfaces, etc. On most boards this is undervolted to 3.0V to
safe battery, but not on all, make it configurable so that we can use the
same settings as the original firmware on all boards.
Some of the ldo-s of the axp221 are used in the same way on most boards, add
comments to the Kconfig help text to reflect this, and give them defaults
matching their typical usage.
The axp223 appears to be the same as the axp221, except that it uses the
rsb to communicate rather then the p2wi. At least all the registers we use
are 100% the same.
The A31 uses the AXP221 pmic for various voltages.
Signed-off-by: Oliver Schinagl <oliver@schinagl.nl>
Changes in v2:
-Rebase
Changes in v3:
-Add support for all dldo and aldo-s
-Add Kconfig option to select building AXP221 and to select voltage of
dldo and aldo-s
Changes in v4:
-Add axp221_setbits helper function
-Use symbolic names for enabled bits in CTRL1 - CTRL3 registers
This would be useful to start moving various config options.
