path: root/drivers/pinctrl
2015-09-25pinctrl: uniphier: add UniPhier PH1-LD6b pinctrl driverMasahiro Yamada
Add pin configuration and pinmux support for UniPhier PH1-LD6b SoC. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-09-25pinctrl: uniphier: add UniPhier ProXstream2 pinctrl driverMasahiro Yamada
Add pin configuration and pinmux support for UniPhier ProXstream2 SoC. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-09-25pinctrl: uniphier: add UniPhier PH1-Pro5 pinctrl driverMasahiro Yamada
Add pin configuration and pinmux support for UniPhier PH1-Pro5 SoC. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-09-25pinctrl: uniphier: add UniPhier PH1-sLD8 pinctrl driverMasahiro Yamada
Add pin configuration and pinmux support for UniPhier PH1-sLD8 SoC. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-09-25pinctrl: uniphier: add UniPhier PH1-Pro4 pinctrl driverMasahiro Yamada
Add pin configuration and pinmux support for UniPhier PH1-Pro4 SoC. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-09-25pinctrl: uniphier: add UniPhier PH1-LD4 pinctrl driverMasahiro Yamada
Add pin configuration and pinmux support for UniPhier PH1-LD4 SoC. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-09-23pinctrl: uniphier: add UniPhier pinctrl core supportMasahiro Yamada
The core support for the pinctrl drivers for all the UniPhier SoCs. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-09-19pinctrl: move dm_scan_fdt_node() out of pinctrl uclassMasahiro Yamada
Commit c5acf4a2b3c6 ("pinctrl: Add the concept of peripheral IDs") added some additional change that was not mentioned in the git-log. That commit added dm_scan_fdt_node() in the pinctrl uclass binding. It should be handled by the simple-bus driver or the low-level driver, not by the pinctrl framework. I guess Simon's motivation was to bind GPIO banks located under the Rockchip pinctrl device. It is true some chips have sub-devices under their pinctrl devices, but it is basically SoC-specific matter. This commit partly reverts commit c5acf4a2b3c6 to keep the only pinctrl-generic features in the uclass. The dm_scan_fdt_node() should be called from the rk3288_pinctrl driver. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2015-09-02rockchip: rk3288: Add pinctrl driverSimon Glass
Add a driver which supports pin multiplexing setup for the most commonly used peripherals. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02pinctrl: Add the concept of peripheral IDsSimon Glass
My original pinctrl patch operating using a peripheral ID enum. This was shared between pinmux and clock and provides an easy way to specify a device that needs to be controlled, even it is does not (yet) have a driver within driver model. Masahiro's new simple pinctrl gets around this by providing a set_state_simple() pinctrl method. By passing a device to that call the peripheral ID becomes unnecessary. If the driver needs it, it can calculate it itself and use it internally. However this does not solve the problem for peripheral clocks. The 'pure' solution would be to pass a driver to the clock uclass also. But this requires that all devices should have a driver, and a struct udevide. Also a key optimisation of the clock uclass is allowing a peripheral clock to be set even when there is no device for that clock. There may be a better way to achive the same goal, but for now it seems expedient to add in peripheral ID to the pinctrl uclass. Two methods are added - one to get the peripheral ID and one to select it. The existing set_state_simple() is effectively the union of these. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02pinctrl: Add help text to KconfigSimon Glass
The pinctrl Kconfig options should have help messages. Add this to a few options. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-31pinctrl: sandbox: add sandbox pinctrl driverMasahiro Yamada
This driver actually does nothing but test pinctrl uclass, and demonstrate how things work. To try this driver, uncomment /* #define DEBUG */ in the drivers/pinctrl/pinctrl-sandbox.c, and debug messages will be displayed. DRAM: 128 MiB sandbox pinmux: group = 1 (serial_a), function = 1 (serial) Using default environment In: cros-ec-keyb Out: lcd Err: lcd Net: Net Initialization Skipped eth0: eth@10002000, eth1: eth@80000000, eth5: eth@90000000 => i2c dev 0 Setting bus to 0 sandbox pinmux: group = 0 (i2c), function = 0 (i2c) sandbox pinconf: group = 0 (i2c), param = 3, arg = 1 Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-31pinctrl: add pin control uclass supportMasahiro Yamada
This creates a new framework for handling of pin control devices, i.e. devices that control different aspects of package pins. This uclass handles pinmuxing and pin configuration; pinmuxing controls switching among silicon blocks that share certain physical pins, pin configuration handles electronic properties such as pin- biasing, load capacitance etc. This framework can support the same device tree bindings, but if you do not need full interface support, you can disable some features to reduce memory foot print. Typically around 1.5KB is necessary to include full-featured uclass support on ARM board (CONFIG_PINCTRL + CONFIG_PINCTRL_FULL + CONFIG_PINCTRL_GENERIC + CONFIG_PINCTRL_PINMUX), for example. We are often limited on code size for SPL. Besides, we still have many boards that do not support device tree configuration. The full pinctrl, which requires OF_CONTROL, does not make sense for those boards. So, this framework also has a Do-It-Yourself (let's say simple pinctrl) interface. With CONFIG_PINCTRL_FULL disabled, the uclass itself provides no systematic mechanism for identifying the peripheral device, applying pinctrl settings, etc. They must be done in each low-level driver. In return, you can save much memory footprint and it might be useful especially for SPL. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
