path: root/drivers/pinctrl/uniphier
2017-08-20ARM: uniphier: remove sLD3 SoC supportMasahiro Yamada
This SoC is too old. It is difficult to maintain any longer. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-07-26ARM: uniphier: remove SPL support for ARMv8 SoCsMasahiro Yamada
It has been a while since ARM Trusted Firmware supported UniPhier SoC family. U-Boot SPL was intended as a temporary loader that runs in secure world. It is a maintenance headache to support two different boot mechanisms. Secure firmware is realm of ARM Trusted Firmware and now U-Boot only serves as a non-secure boot loader for UniPhier ARMv8 SoCs. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-06-01dm: Fix up inclusion of common.hSimon Glass
It is good practice to include common.h as the first header. This ensures that required features like the DECLARE_GLOBAL_DATA_PTR macro, configuration options and common types are available. Fix up some files which currently don't do this. This is necessary because driver model will soon start using global data and configuration in the dm/read.h header file, included via dm.h. The gd->fdt_blob value will be used to access the device tree and CONFIG options will be used to determine whether to support inline functions in the header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: Rename dev_addr..() functionsSimon Glass
These support the flat device tree. We want to use the dev_read_..() prefix for functions that support both flat tree and live tree. So rename the existing functions to avoid confusion. In the end we will have: 1. dev_read_addr...() - works on devices, supports flat/live tree 2. devfdt_get_addr...() - current functions, flat tree only 3. of_get_address() etc. - new functions, live tree only All drivers will be written to use 1. That function will in turn call either 2 or 3 depending on whether the flat or live tree is in use. Note this involves changing some dead code - the imx_lpi2c.c file. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: Use dm.h header when driver mode is usedSimon Glass
This header includes things that are needed to make driver build. Adjust existing users to include that always, even if other dm/ includes are present Signed-off-by: Simon Glass <sjg@chromium.org>
2017-02-23pinctrl: uniphier: support pin configurationMasahiro Yamada
Support the following DT properties: "bias-disable" "bias-pull-up" "bias-pull-down" "bias-pull-pin-default" "input-enable" "input-disable" My main motivation is to support pull up/down biasing. For Pro5 and later SoCs, the pupdctrl register number is the same as the pinmux number, so this feature can be supported without having big pin tables. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-01-22pinctrl: uniphier: support UniPhier PXs3 pinctrl driverMasahiro Yamada
Add pin configuration and pinmux support for UniPhier PXs3 SoC. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-01-18pinctrl: uniphier: fix Ethernet (RMII) pin-mux setting for LD20Masahiro Yamada
Fix the pin-mux values for the MDC, MDIO, MDIO_INTL, PHYRSTL pins. Fixes: fc9da85c6059 ("pinctrl: uniphier: add Ethernet pin-mux settings") Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-10-18pinctrl: uniphier: fix unused-const-variable warnings for GCC 6.xMasahiro Yamada
Marek reports warnings in UniPhier pinctrl drivers when compiled by GCC 6.x, like: drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c:58:18: warning: 'usb3_muxvals' defined but not used [-Wunused-const-variable=] static const int usb3_muxvals[] = {0, 0}; ^~~~~~~~~~~~ My intention here is to compile minimum set of pin data for SPL to save memory footprint, but GCC these days is clever enough to notice unused data arrays. We can fix it by sprinkling around __maybe_unused on those arrays, but I did not do that because they are counterparts of the pinctrl drivers in Linux. All the pin data were just copy-pasted from Linux and are kept in sync for maintainability. I chose a bit tricky way to fix the issue; calculate ARRAY_SIZE of *_pins and *_muxvals and set their sum to an unused struct member. This trick will satisfy GCC because the data arrays are used anyway, but such data arrays will be dropped from the final binary because the pointers to them are not used. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reported-by: Marek Vasut <marex@denx.de>
2016-09-18pinctrl: uniphier: add UniPhier sLD3 pinctrl driverMasahiro Yamada
Add pin-mux support for UniPhier sLD3 SoC. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-09-18pinctrl: uniphier: support 4bit-width pin-mux register capabilityMasahiro Yamada
On LD4 SoC or later, the pin-mux registers are 8bit wide, while 4bit wide on sLD3 SoC. Support it for the sLD3 pinctrl driver. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-09-14pinctrl: uniphier: move register base macros from header to .c fileMasahiro Yamada
These macros are only referenced in pinctrl-uniphier-core.c, so they need not reside in a header file. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-09-14pinctrl: uniphier: add System Bus pin-mux settingsMasahiro Yamada
This is needed to get access to UniPhier System Bus (external bus). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-07-24ARM: uniphier: use (devm_)ioremap() instead of map_sysmem()Masahiro Yamada
This does not have much impact on behavior, but makes code look more more like Linux. The use of devm_ioremap() often helps to delete .remove callbacks entirely. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-07-02pinctrl: uniphier: add Ethernet pin-mux settingsMasahiro Yamada
2016-07-02pinctrl: uniphier: avoid building unneeded pin-mux tables for SPLMasahiro Yamada
SPL does not use all of the devices, so we can save some memory footprint. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-07-02pinctrl: uniphier: support pin configuration for dedicated pinsMasahiro Yamada
PH1-LD4 and PH1-sLD8 SoCs have pins that support pin configuration (pin biasing, drive strength control), but not pin-muxing. Allow to fill the mux value table with -1 for those pins; pins with mux value -1 will be skipped in the pin-mux set function. The mux value type should be changed from "unsigned" to "int" in order to accommodate -1 as a special case. [ Linux commit: 363c90e743b50a432a91a211dd8b078d9df446e9 ] Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-07-02pinctrl: uniphier: split pinctrl driver for PH1-LD11 and PH1-LD20Masahiro Yamada
PH1-LD11 and PH1-LD20 have much pin controlling in common, so I added a single driver shared between them in the initial commit. However, the Ethernet pin-mux settings I am going to add are different with each other, and they may diverge more as the progress of development. Split it into two dedicated drivers. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-07-02pinctrl: uniphier: allow to have pinctrl node under syscon nodeMasahiro Yamada
Currently, the UniPhier pinctrl driver itself is a syscon, but it turned out much more reasonable to make it a child node of a syscon because our syscon node consists of a bunch of system configuration registers, not only pinctrl, but also phy, and misc registers. It is difficult to split the node. This commit allows to migrate to the new DT structure. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-30pinctrl: uniphier: remove unneeded pin group nand_cs1Masahiro Yamada
This SoC does not support NAND CS1. This place-holder is no longer necessary. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-30pinctrl: uniphier: fix NAND pin-mux setting for PH1-LD11/LD20Masahiro Yamada
My mistake in the initial support patch. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-30pinctrl: uniphier: remove wrong pin-mux functions for ProXstream2Masahiro Yamada
These are pin group names, not function names. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-04-24pinctrl: uniphier: fix NAND and SD pin-mux settings for PH1-LD11/LD20Masahiro Yamada
I found many mistakes in the initial version. Fixes: 8a3328c209d0 ("pinctrl: uniphier: support UniPhier PH1-LD20 pinctrl driver") Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-04-24pinctrl: uniphier: rename function/array namesMasahiro Yamada
Make function/array names match the file names for consistency. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-04-01pinctrl: uniphier: support UniPhier PH1-LD11 pinctrl driverMasahiro Yamada
The pinmux of PH1-LD11 is almost a subset of that of PH1-LD20 (as far as used in boot-loader), so this commit makes the driver shared between the two SoCs. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-04-01pinctrl: uniphier: support UniPhier PH1-LD20 pinctrl driverMasahiro Yamada
Add pin configuration and pinmux support for UniPhier PH1-LD20 SoC. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-04-01pinctrl: uniphier: support per-pin input enable for new SoCsMasahiro Yamada
Upcoming new pinctrl drivers for PH1-LD11 and PH-LD20 support input signal gating for each pin. (While, existing ones only support it per pin-group.) This commit prepares the core part for that. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-04-01pinctrl: uniphier: introduce capability flagMasahiro Yamada
The core part of the UniPhier pinctrl driver needs to support a new capability for upcoming UniPhier ARMv8 SoCs. This sometimes happens because pinctrl drivers include really SoC-specific stuff. This commit intends to tidy up SoC-specific parameters of the existing drivers before adding new ones. Having flags would be better than adding new members every time a new SoC-specific capability comes up. At this time, there is one flag, UNIPHIER_PINCTRL_CAPS_DBGMUX_SEPARATE. This capability (I'd say rather quirk) was added for PH1-Pro4 and PH1-Pro5 as requirement from our customer. For those SoCs, one pin-mux setting is controlled by the combination of two separate registers; the LSB bits at register offset (8 * N) and the MSB bits at (8 * N + 4). Because it is impossible to update two separate registers atomically, the LOAD_PINCTRL register should be set in order to make the pin-mux settings really effective. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-04-01pinctrl: uniphier: use devm_get_addr() to get base addressMasahiro Yamada
Currently, fdtdec_get_addr_size() does not support the address translation, so it cannot handle device trees with non-straight "ranges" properties. (This would be a problem with DTS for UniPhier ARMv8 SoCs.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-03-24ARM: uniphier: drop PH1- prefix from CONFIG options and file namesMasahiro Yamada
The current CONFIG names like "CONFIG_ARCH_UNIPHIER_PH1_PRO4" is too long. It would not hurt to drop "PH1_" because "UNIPHIER_" already well specifies the SoC family. Also, rename files for consistency. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-03-09pinctrl: uniphier: guard uniphier directory with CONFIG_PINCTRL_UNIPHIERMasahiro Yamada
CONFIG_PINCTRL_UNIPHIER is more suitable than CONFIG_ARCH_UNIPHIER to guard the drivers/pinctrl/uniphier directory. The current CONFIG_PINCTRL_UNIPHIER_CORE is a bit long, so rename it into CONFIG_PINCTRL_UNIPHIER. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-03-09pinctrl: uniphier: set input-enable before pin-muxingMasahiro Yamada
While IECTRL is disabled, input signals are pulled-down internally. If pin-muxing is set up first, glitch signals (Low to High transition) might be input to hardware blocks. Bad case scenario: [1] The hardware block is already running before pinctrl is handled. (the reset is de-asserted by default or by a firmware, for example) [2] The pin-muxing is set up. The input signals to hardware block are pulled-down by the chip-internal biasing. [3] The pins are input-enabled. The signals from the board reach the hardware block. Actually, one invalid character is input to the UART blocks for such SoCs as PH1-LD4, PH1-sLD8, where UART devices start to run at the power on reset. To avoid such problems, pins should be input-enabled before muxing. [ ported from Linux commit bac7f4c1bf5e7c6ccd5bb71edc015b26c77f7460 ] Fixes: 5dc626f83619 ("pinctrl: uniphier: add UniPhier pinctrl core support") Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-01-25bug.h: move BUILD_BUG_* defines to include/linux/bug.hMasahiro Yamada
BUILD_BUG_* macros have been defined in several headers. It would be nice to collect them in include/linux/bug.h like Linux. This commit is cherry-picking useful macros from include/linux/bug.h of Linux 4.4. I did not import BUILD_BUG_ON_MSG() because it would not work if it is used with include/common.h in U-Boot. I'd like to postpone it until the root cause (the "error()" macro in include/common.h causes the name conflict with "__attribute__((error()))") is fixed. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-11-10Various Makefiles: Add SPDX-License-Identifier tagsTom Rini
After consulting with some of the SPDX team, the conclusion is that Makefiles are worth adding SPDX-License-Identifier tags too, and most of ours have one. This adds tags to ones that lack them and converts a few that had full (or in one case, very partial) license blobs into the equivalent tag. Cc: Kate Stewart <kstewart@linuxfoundation.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2015-09-25ARM: uniphier: rename CONFIG_MACH_* to CONFIG_ARCH_UNIPHIER_*Masahiro Yamada
I want these prefixed with CONFIG_ARCH_UNIPHIER_ to clarify they belong to UniPhier SoC family. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-09-25pinctrl: uniphier: add UniPhier PH1-LD6b pinctrl driverMasahiro Yamada
Add pin configuration and pinmux support for UniPhier PH1-LD6b SoC. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-09-25pinctrl: uniphier: add UniPhier ProXstream2 pinctrl driverMasahiro Yamada
Add pin configuration and pinmux support for UniPhier ProXstream2 SoC. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-09-25pinctrl: uniphier: add UniPhier PH1-Pro5 pinctrl driverMasahiro Yamada
Add pin configuration and pinmux support for UniPhier PH1-Pro5 SoC. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-09-25pinctrl: uniphier: add UniPhier PH1-sLD8 pinctrl driverMasahiro Yamada
Add pin configuration and pinmux support for UniPhier PH1-sLD8 SoC. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-09-25pinctrl: uniphier: add UniPhier PH1-Pro4 pinctrl driverMasahiro Yamada
Add pin configuration and pinmux support for UniPhier PH1-Pro4 SoC. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-09-25pinctrl: uniphier: add UniPhier PH1-LD4 pinctrl driverMasahiro Yamada
Add pin configuration and pinmux support for UniPhier PH1-LD4 SoC. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-09-23pinctrl: uniphier: add UniPhier pinctrl core supportMasahiro Yamada
The core support for the pinctrl drivers for all the UniPhier SoCs. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
