path: root/drivers/pinctrl/uniphier/pinctrl-uniphier-ld4.c
2017-10-15pinctrl: uniphier: simplify input enable and delete pin arraysMasahiro Yamada
The pin data are implemented for old SoCs to specify the bit shift of the IECTRL register. They are not wortwhile given the required memory footprint. Delete all the pin data and enable all bits of the IECTRL register. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-06-01dm: Fix up inclusion of common.hSimon Glass
It is good practice to include common.h as the first header. This ensures that required features like the DECLARE_GLOBAL_DATA_PTR macro, configuration options and common types are available. Fix up some files which currently don't do this. This is necessary because driver model will soon start using global data and configuration in the dm/read.h header file, included via dm.h. The gd->fdt_blob value will be used to access the device tree and CONFIG options will be used to determine whether to support inline functions in the header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: Use dm.h header when driver mode is usedSimon Glass
This header includes things that are needed to make driver build. Adjust existing users to include that always, even if other dm/ includes are present Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-14pinctrl: uniphier: add System Bus pin-mux settingsMasahiro Yamada
This is needed to get access to UniPhier System Bus (external bus). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-07-24ARM: uniphier: use (devm_)ioremap() instead of map_sysmem()Masahiro Yamada
This does not have much impact on behavior, but makes code look more more like Linux. The use of devm_ioremap() often helps to delete .remove callbacks entirely. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-07-02pinctrl: uniphier: add Ethernet pin-mux settingsMasahiro Yamada
2016-07-02pinctrl: uniphier: avoid building unneeded pin-mux tables for SPLMasahiro Yamada
SPL does not use all of the devices, so we can save some memory footprint. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-07-02pinctrl: uniphier: support pin configuration for dedicated pinsMasahiro Yamada
PH1-LD4 and PH1-sLD8 SoCs have pins that support pin configuration (pin biasing, drive strength control), but not pin-muxing. Allow to fill the mux value table with -1 for those pins; pins with mux value -1 will be skipped in the pin-mux set function. The mux value type should be changed from "unsigned" to "int" in order to accommodate -1 as a special case. [ Linux commit: 363c90e743b50a432a91a211dd8b078d9df446e9 ] Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-07-02pinctrl: uniphier: allow to have pinctrl node under syscon nodeMasahiro Yamada
Currently, the UniPhier pinctrl driver itself is a syscon, but it turned out much more reasonable to make it a child node of a syscon because our syscon node consists of a bunch of system configuration registers, not only pinctrl, but also phy, and misc registers. It is difficult to split the node. This commit allows to migrate to the new DT structure. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-04-24pinctrl: uniphier: rename function/array namesMasahiro Yamada
Make function/array names match the file names for consistency. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-04-01pinctrl: uniphier: introduce capability flagMasahiro Yamada
The core part of the UniPhier pinctrl driver needs to support a new capability for upcoming UniPhier ARMv8 SoCs. This sometimes happens because pinctrl drivers include really SoC-specific stuff. This commit intends to tidy up SoC-specific parameters of the existing drivers before adding new ones. Having flags would be better than adding new members every time a new SoC-specific capability comes up. At this time, there is one flag, UNIPHIER_PINCTRL_CAPS_DBGMUX_SEPARATE. This capability (I'd say rather quirk) was added for PH1-Pro4 and PH1-Pro5 as requirement from our customer. For those SoCs, one pin-mux setting is controlled by the combination of two separate registers; the LSB bits at register offset (8 * N) and the MSB bits at (8 * N + 4). Because it is impossible to update two separate registers atomically, the LOAD_PINCTRL register should be set in order to make the pin-mux settings really effective. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-03-24ARM: uniphier: drop PH1- prefix from CONFIG options and file namesMasahiro Yamada
The current CONFIG names like "CONFIG_ARCH_UNIPHIER_PH1_PRO4" is too long. It would not hurt to drop "PH1_" because "UNIPHIER_" already well specifies the SoC family. Also, rename files for consistency. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
