path: root/drivers/pinctrl/nxp/pinctrl-imx.c
2019-01-28pinctrl: imx: Fix select input issueYe Li
The pinctrl supports to set any bit in input register on iMX6 if the MSB of input value is 0xff. But the driver uses signed int for input value, so when executing the codes below, it won't meet. Because this is arithmetic right shift. if (input_val >> 24 == 0xff) Fix the issue by changing the input_val, config_val and mux_mode to u32. Signed-off-by: Ye Li <ye.li@nxp.com> Reviewed-by: Fugang Duan <fugang.duan@nxp.com> Reviewed-by: Peng Fan <peng.fan@nxp.com>
2018-10-22pinctrl: Add pinctrl driver for i.MX8Peng Fan
Add pinctrl driver for i.MX8. The pads configuration is controlled by SCU, so need to ask SCU to configure pads through scfw API. Add pinctrl-scu to invoke sc_pad_set to configure pads. Add a new flag IMX8_USE_SCU to differentiate i.MX8 from other platforms which could directly configure pads from Acore side. Add CONFIG_PINCTRL_IMX8 as the built gate. Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Anatolij Gustschin <agust@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2017-08-23pinctrl: imx: Fix mask when SHARE_MUX_CONF_REG is setPeng Fan
when using SHARE_MUX_CONF_REG, wrong mask is used for writing config value, which causes mux value is cleared. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefano Babic <sbabic@denx.de>
2017-06-01dm: Use dm.h header when driver mode is usedSimon Glass
This header includes things that are needed to make driver build. Adjust existing users to include that always, even if other dm/ includes are present Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-18pinctrl: imx: fix memory leakPeng Fan
Each time set_state is called, a new piece memory will be allocated for pin_data, but not freed, this will incur memory leak. When error, the devm API could not free memory automatically. So need call devm_kfree when error. Issue reported by Coverity Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefan Agner <stefan.agner@toradex.com> Cc: Stefano Babic <sbabic@denx.de>
2017-03-17pinctrl: Add i.MX7ULP pinctrl driverPeng Fan
Add i.MX7ULP pinctrl driver. Select CONFIG_PINCTRL_IMX7ULP to use this driver. Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by : Stefano Babic <sbabic@denx.de>
2017-02-08dm: core: Replace of_offset with accessorSimon Glass
At present devices use a simple integer offset to record the device tree node associated with the device. In preparation for supporting a live device tree, which uses a node pointer instead, refactor existing code to access this field through an inline function. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-07pinctrl: imx: do not announce driver initializationStefan Agner
It is not usual that drivers announce when they have been initialized. use dev_dbg to announce device initialization. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-02-21pinctrl: imx: Introduce pinctrl driver for i.MX6Peng Fan
Introduce pinctrl for i.MX6 1. pinctrl-imx.c is for common usage. It's used by i.MX6/7. 2. Add PINCTRL_IMX PINCTRL_IMX6 Kconfig entry. 3. To the pinctrl_ops implementation, only set_state is implemented. To i.MX6/7, the pinctrl dts entry is as following: &iomuxc { pinctrl-names = "default"; pinctrl_csi1: csi1grp { fsl,pins = < MX6UL_PAD_CSI_MCLK__CSI_MCLK 0x1b088 MX6UL_PAD_CSI_PIXCLK__CSI_PIXCLK 0x1b088 MX6UL_PAD_CSI_VSYNC__CSI_VSYNC 0x1b088 >; }; [.....] }; there is no property named function or groups. So pinctrl_generic_set_state can not be used here. 5. This driver is a simple implementation for i.mx iomux controller, only parse the fsl,pins property and write value to registers. 6. With DEBUG enabled, we can see log when "i2c bus 0": " set_state_simple op missing imx_pinctrl_set_state: i2c1grp mux_reg 0x14c, conf_reg 0x3bc, input_reg 0x5d8, mux_mode 0x0, input_val 0x1, config_val 0x4000007f write mux: offset 0x14c val 0x10 select_input: offset 0x5d8 val 0x1 write config: offset 0x3bc val 0x7f mux_reg 0x148, conf_reg 0x3b8, input_reg 0x5d4, mux_mode 0x0, input_val 0x1, config_val 0x4000007f write mux: offset 0x148 val 0x10 select_input: offset 0x5d4 val 0x1 write config: offset 0x3b8 val 0x7f " this means imx6 pinctrl driver works as expected. Signed-off-by: Peng Fan <van.freenix@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
